Question about Canon imageRUNNER 105 Copier
Ir225 error codes ir7105 sequence - Canon imageRUNNER 105 Copier
3 Suggested Answers
  • 39 Answers
SOURCE: i found error in canon ir7105, and i checked
According to the code, the problem is in the laser unit. It sounds like I'm talking to a technician, so I'll approach the problem that way. I personally would first reseat all the electrical connectors on the main PCB as well as the laser unit. Loose connections do sometimes cause codes like this one. The other thing I'd do before tossing the laser unit is to reset the error code because again, codes like this one do come up when the AC power fluctuates from time to time. This is accomplished by entering service mode and then resetting the error . . . your service manual for the ir105 will give you the same method for service model access and the general sequence is the same for resetting the error. Good luck.
Posted on Dec 18, 2009
IR 1018. What's the meaning of error code e000197?
The error code E197-0000 (laser scanner motor communication error) may be indicated during the wait state upon power-on.Cause:The tube protecting the crimp terminal on the end of the bias cable that is connected to the transfer guide in therear side of the Registration - Transfer Assembly [1] moves downward, and the uncovered metal portion of theterminal comes into contact with the screw [2]. This causes electrical noise, leading to E197-0000.
press the helpful button and check link below
canon ir7105 error code e000197 0000
Jan 23, 2016 | Canon Office Equipment & Supplies
202-001 what is problem this error modle no ir7105
This is a scan problem, Please check: scan switch, scan motor, or image processor board.
Thank you.
Jul 22, 2014 | Canon Gpr19 Ir7105/7095 Black Copier Toner
Canon ir 7086 error e012
DRUM MOTOR OR SOLID WAST IN DRUM UNIT (PROCESSING UNIT)....OR DISCONNECT AND CONNECT ALL DC CONTROLER JACS
Apr 15, 2014 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Canon ir7105 error codes 000602
TRy this link. Reading similar errors, similar machine = hard drive error. can ir7200 602 001 Archive Copytechnet com
Apr 09, 2014 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
E000225 0001
error code E000225-0001 on iR7105 .what can i do to remove this code?show me the steps.
Jan 23, 2014 | Canon iR3035 Copier
Error code e121
Reader controler cooling fan fault replace the fan or dc board
Jul 17, 2013 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Error code 51 is showing, have stopped and started machine several times, no luck
u've not stated make and model of machine. if it is ir225,ir330,ir335,ir400 , check horizontal registration sensor,sensor arm.
Dec 21, 2010 | Canon Office Equipment & Supplies
I found error in canon ir7105, and i checked
Dec 14, 2009 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER 105 Copier Logo
26 people viewed this question
old marine
old marine
