Question about DeLonghi Coffee Makers & Espresso Machines
Delonghi ec9 no froth, no steam milk
  • 1089 Answers
SOURCE: Cappucinatore won't pull milk through the tube
Hi
There should be a small pin on the top of the Cappuccinator. When it starts, twist the pin slowly until the milk flows up the tube. Then leave it where it is and it will work all the time.
Posted on Jul 09, 2009
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Posted on Jan 10, 2010
SOURCE: the steam wand is bubbling the milk, not frothing
THere is a little black tube inside - make sure its pushed out enough - about 1/16 an inch from the bottom. And you may have to clean it out. Happens to us too and after I do the above it works
Posted on Feb 14, 2010
Testimonial: "Thank you very much for the advice. I adjusted the black tube and the frothing is back!"
SOURCE: There is no milk coming out of the frothing part
If no milk comes out of frother, check the o-ring on the upper "plug" where the milk jar connects to the machine. There are two connectors; only the bottom one corresponds to the steam output while the upper one is a plug. Mine had a worn out o-ring on the plug, and this keeps the machine from frothing milk.
Posted on Jun 21, 2010
  • 906 Answers
SOURCE: kitchenaid artisan coffee machine - steam wand
good day,
hope this link below will solve your problem..
kitchen
Posted on Aug 04, 2010
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
THE FORTHED MILK NOT HOT
Try steaming less actual milk and allowing the froth and expansion to make up the volume you need for the size of the cup. This allows you to steam the milk longer achieving a hotter froth.
Dec 20, 2014 | DeLonghi Magnifica Coffee Makers &...
Delonghi perfecta milk not hot enough
Ummn - something in your Q. seems not right. The milk is not heated directly - its only heated by the steam as it passes by (and picks up) by the milk using a venturi effect - same as a spray bottle attached to a garden hose. You say you have froth - but you can only get that if you have steam... (it does not just blow air thru to create bubbles). So froth = steam & steam = heat... so milk must be hot.
Suggest you check manual for the 'heat' settings for your expresso as this may have been changed. While this is adjustable, the milk is not.
Also always heat your cups before using them - the silver cup 'holder' at the top does a reasonable job but boiling water does far better.
Cheers Mike
May 31, 2014 | DeLonghi ESAM6600 Espresso Machine
Coffee maker not frothing milk
The tube on the "ball assembly" which connects to the "milk" tank may be missing an O-ring. If this O-ring is missing, the steam will only siphon a little bit of milk because there is no seal. If it is working properly, the siphon can fill be expected to fill a cup in about 30 -60 seconds.
May 19, 2012 | DeLonghi EC Coffee Makers & Espresso...
I have just bought a delonghi ec220cd coffee maker - a replacement for the delonghi ec270 which started to leak badly. However, the milk doesn't seem to want to froth - just wet and may as well just pour...
Try removing the plastic steaming sleeve and just use the stainless pipe. Keep the pipe just below the surface to make the ffroth, then go lower to heat the milk to a max of 165F.
Apr 27, 2011 | Coffee Makers & Espresso Machines
Magnifier doesn't get enough steam to warm milk or froth milk
sounds like you need it stripped down and serviced ... bsc appliances bristol 07779933829 postal service too.fully trained by delonghi.
Feb 16, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
I have a Delonghi Prima Donna. Blows lots of stem but wont froth milk. The 3 orings have been replaced and the fittings cleaned, but still no frothing. I pulled the lid apart and it seems ok. Any...
Where is it blowing steam from? If it is coming from the milk spout then it most likely that the milk jug is blocked somewhere. If it is coming from where the jug connects to the machine (coupling) then you might need to change the complete coupling (assuming you used the correct orings). The biggest cause of frothing problems with these machines is lack of cleaning of the milk jug. Soak the top in quality milk cleaner for at least an hour and rinse thoroughly. Also run cleaner through it regularly using the milk only function.
Nov 19, 2010 | DeLonghi Prima Donna Avante ESAM6700...
There is no milk coming out of the frothing part of the Delonghi Coffee Maker, it just makes a noise and steam comes out.
May 17, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica 3500 not frothing
use cold low fat milk and keep the milk container in the frig.
Make certain that when washing water come out of both holes.
Jul 09, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee Makers & Espresso Machines Logo
133 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
