Question about Cooktops
Technika cooktop Piazzo ignition won,t stop clicking
catriver
  • 878 Answers
SOURCE: electronic ignition
Alien, one of your burner switches either got wet or shorted out. These switches are located on the burner valve itself. Sometimes you can take a hair dryer, pull the knobs of the control valve and dry out the switch. If this doesn't work, more than likley one of the switches gone bad. Catriver...post back.
Posted on Sep 24, 2006
  • 3 Answers
SOURCE: 1 burner wont stop clicking on miele cooktop km 344
We have an older Thermador Gas Cooktop type range. It was working fine until the cleaning crew came in, then all the burner igniters were clicking when turning on a single burner. I solved the problem by cleaning off the igniters. I first of course unplugged the power. Then I took a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. I then went ahead and scraped and brushed clean the mating surface where the spark travels. I then vacuumed up the mess. My burners all worked great after this. Hope this helps!
Posted on Sep 13, 2007
  • 409 Answers
SOURCE: Trouble with Kenmore Gas Cooktop
hi there,
the clicking noise is the spark module trying to ignite. i would get a technician to come and check it.
Posted on Sep 30, 2008
SOURCE: kitchenaid gas ccoktop electronic ignition continues to click
We called in an appliance repair technician. He said during the cleaning process of the cooktop, when the control knobs had been removed to thoroughly clean the cooktop, some cleaning fluid or water or moisture got into the ignition switch panel under the cooktop. Letting it dry for 24 hours should fix the problem and this appears to have done that.
Posted on Feb 18, 2009
SOURCE: Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Posted on Apr 28, 2009
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | KitchenAid Cooktops
The Viking gas stove - 6 burner - clicks constantly -- it won't stop. it has done this for years and usually goes off after a while but now it wont stop clicking. The burner that is not even on click.
The problem is one(or more) of the 6 switches that turn on the spark when that burner is turned on is shorted and stays closed (on) all the time.To determine which one it is the front face has to be removed,with THE POWER OFF a meter set to low ohms rating is used to check each switch by removing the wires to it and see which one has continunity (ZERO OHMS) when its off and that switch that slips on the burner valve shaft is the bad switch(s) and needs to be replaced to keep it from sparking all the time.
Please note though, in a perfectly working cooktop all burners spaks at the same time and only the only one that has the gas flowing to it will ignite,that part is normal.
I hope this helps you to repair your cooktop,
Gene
Aug 08, 2011 | Viking Professional VGRT362-4G 36 in. Gas...
Ignition stopped working (not clicking)
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jun 17, 2010 | GE 36 in. Profile JGP962 Gas Cooktop
Ignition is clicking all the time, whether the gas is lit or not.
The clicking is the igniter. If it is clicking and not lighting, then you may have to purchase an igniter kit and replace it. the relays can go bad, or igniter fails.
Sep 04, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Dcs igniters
clean the knob control by using vaccium,pull the knobs then clean it.make sure how to remove the knob,same position to returrn the knob
Jun 30, 2009 | GE Profile JGP636 Gas Cooktop
Igniter clicking when all four knobs in off position after water spill
It is possible that once the unit dries out the clicking will stop. If it doesn't, you will need to call someone to have the problem addressed. You will need a spark module and or an ignition switch(s).
Oct 28, 2008 | GE 30 in. JGP336 Gas Cooktop
hi there,
Sep 28, 2008 | Cooktops
Burners ignite simultaneously (clicking)
When you set a burner to light, all burners spark. This is normal. Move knob back off the spark position as soon as burner lights. All sparking will stop.
Sep 04, 2008 | DCS 48 in. CP486GDSS / CP486GDSSL /...
Clicking sound whenever I turn on a burner
There is no problem. The click your hearing is the spark module igniting the gas. The clicking will only occur while the know is turned to ignite and will stop after your turn the knog to any other setting.
Jun 17, 2007 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Cooktops Logo
27 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
