Question about Health & Beauty
Change wheel on mobility scooter
Wanting to change wheeles on mobility scooter to punchure proof wheeles split rim type how do i do this?
  • 36 Answers
Best price is eBay but remember solid give you a pain in the seat big time .you can get wheels and tyres from manufacture
Posted on Apr 30, 2013
gewiz
  • 1263 Answers
SOURCE: when turning on the charger for a bec sterling 3
what the charger is showing that ?, it has a digital display ? please supply more information
Posted on Jun 13, 2009
  • 175 Answers
SOURCE: The battery takes a charge, but will not power scooter
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
Posted on Jul 12, 2009
  • 177 Answers
SOURCE: Pride Celebrity Deluxe Mobility Scooter - Serial Number
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
Posted on May 27, 2010
  • 177 Answers
SOURCE: Back wheels make a loud clicking noise
Hi. Loud clicking noises from the rear wheels are usually caused by movement of the square steel key that fits into a groove on the axle inside the wheel hub. This is what drives the wheels.
You will probably get a click for each revolution of the wheels.
To fix it, remove the rear wheels and wipe a thin smear of grease on the key and axle, then replace the wheels.
The grease will allow the key to move slightly without making a noise, and help stop it from wearing.
It sometimes helps to also remove the front wheels, and wipe a thin smear of grease onto the front stub axles. There is no key in the front hubs, but the grease helps to prevent the bearings siezing on to the axles.
Good luck. Neil.
Posted on Jun 25, 2010
SOURCE: I have a Rascal 245 Mobility Scooter which is 3
Obtaining a 4-wheeled front section is the best way to improve stability. The 3-wheeled front section on rascal 235 and 245 scooters easily detaches and interchanges with the 4-wheeled front sections(235 models are a little shorter (less legroom).
Posted on Oct 03, 2010
How do I split the rear split rim wheel? Bolts came off easily but wheel is stuck together.
Hit the rim with a rubber hammer. Spray some penetrating oil on the holes of the wheels so it will get in between the wheel halves.
Jun 19, 2015 | CTM Homecare CTM HS-580 4-Wheel Power...
How do i repair a puncture on my mobility scooter
Depends on the model...... Most models have a split rim design .....
1 x Large Nut for attaching the wheel to the axle
4 x smaller nuts that hold the 2 sides of the wheel rim together.
Remove the wheel - Deflate tyre (if not already) - Remove the 4 split rim nuts - use a blunt instrument to gently tease the tyre off each rim to expose inner tube - Repair tube and reverse the process... Hope this helps .... Dave
Aug 28, 2014 | Health & Beauty
To change rea tyres on shoprider gk10
No special tools are needed. Centre bolt will be either 13mm 17mm or 19mm remove this then slide wheel off don't lose the key that sits in the wheel and on the drive shaft. Wheel should be a split rim. Undo the 5 bolts on the wheel and prise the run away from the tyre.
Aug 15, 2014 | Shoprider Health & Beauty
How do I put air in the tires?
It is possible that your scooter may have solid tires which means no air is required. You should be able to see a hole in the wheel rim where, if air tires were fitted, the valve would come out. No Valve=No Air. The rims are of the split type which you have to take the bolts out in the middle of the wheel to split the wheel to change the tires.
Jun 11, 2014 | Pride Mobility Products Maxima 3 Wheel...
I need longer studs for the wheel hub for puncture proof tyres i do not know the sizef
No you do not. Just use longer ones to squeeze rims together so you can tighten with the originals.
Apr 10, 2014 | Electric Mobility Mobility Electric Power...
Puncture in one of my front tyre how do l remove it
To remove wheel there is one center bolt in the middle of the wheel(13mm). The wheel is a split rim so on the inside of the wheel there is more 13mm nuts undo them and the wheel comes apart.(no need for tire levers)
Feb 10, 2014 | Electric Mobility Shoprider Electric Power...
Have a flat tire on a Chauffeur Scooter rear wheel.
I just removed the right rear wheel from my Chaffeur scooter. I first removed seat, plastic cover and batteries. Then removed wheel center bolt, set scooter on it\'s side and used a short 2x4 and rubber mallet to drive the wheel off. A shot of penetration oil helped. It is an extremely tight fit.Can\'t figure the two piece rim out though. Anyone have suggestions on why it is a two piece and how to remove tire from rim?
Apr 28, 2010 | Health & Beauty
How to take off wheel mobility scooter. Is it the allen key studs on outside or is it underneath silver cover on centre of wheel
The wheel should be held on by 1 nut (or maybe bolt) in the centre of the wheel so in your case it sounds like its inderneath a centre cover. The allen key studs on the outside of the wheel (probably 4 of them?) will be to split the wheel in half to change a tyre or tube. When removing the wheel, if it is a rear wheel, be carefull not to lose the hub key which is located in a slot on the axle.
Mar 18, 2010 | Electric Mobility Mobility Electric Power...
How do you remove the back wheel of a Pride Hurricane scooter
Undo the centre wheel nut and remove along with the washer, jack the rear of the scooter off the ground then slide the wheel off the axle. If it will not remove, it will need knocking off from the inside rim. Be careful not to lose the hub key (a small piece of metal that locates in a slot in the wheel and axle) as the scooter will not drive if this is missing. To remove the trye from the rim, undo the 4 bolts that hold the two wheel halves together. When refitting the wheel, be sure to apply some grease to the axle before sliding on the wheel.
Jul 30, 2009 | Pride Hurricane 4 Wheel Personal Mobility...
Health & Beauty Logo
140 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
