Question about JBL Audio Players & Recorders
Right earphone not working - JBL Audio Players & Recorders
How can I fix my phone cause now it let me listen through my left earphone only.
that should indicate to you that it needs to be properly diagnosed and/or repaired by a technician in a phone repair shop
Oct 04, 2016 | Cell Phones
Earphone-only left earphone works... how can u repair right earphone
Rotating the jack or twisting the wire joint on the headset might work.
Nov 09, 2012 | Bose Around Ear Headphones Earphones
My phones right earphone is not working.
The problem is obviously as a result of the fact there is a loop in the wire as a result of a breakage in the wire hence the right earphone is not working.
The solution is to replace the wire that connects to the right earphone,or better still get another earphone.
Thanks and take care
Dec 04, 2010 | Cell Phones
What can I do to fix a cable issue in my headphone? The right side doesn't work unless I move around the wire attached to the headphone.
Hi, what makes oneofthe earphones not to work,is because the wire inside the right side of the earphone hascut and will need to soldered back to it's position.
Open the right side of the earphone,and use a soldering iron and a lead to put back the wire properly.
after put back the wire,problem solved.
Thanks for using fixya..
Oct 27, 2010 | Skull Candy Ink'd Stereo Ear Bud...
Right earphone wont work.
It is very likely that the problem is in your MP3 player and not your ear phones. If it is still under guarentee, then take it back to where you bought it. If not it may be that the earphone jack plug is faulty? It is a trade off between the cost of repair against the cost of a new one. These things are often glued together so opening it could break it anyway - sorry
Jul 02, 2009 | Nextar MA933A MP3 Player
Earphones right side won't play...
I inserted a drill bit that fits the exact size of the aperture and twisted it around a few turns and it is working better.
Heath Robinson eat your heart out
Jun 07, 2009 | Audio Players & Recorders
Right part of the earphone is not working
THE RIGHT SPEAKER OF YOUR EARPHONE HAVE TO BE CHANGED
Aug 08, 2008 | Radio Communications
Only one earphone works
that means that the programing of your ipod is only on head phone or you did not insert the wire in correctly
Mar 25, 2008 | Apple iPod nano
Mp3 player problem
it might just be the way the song is configured. try listening to a different song, by a different artist. if that doesn't work, than i don't know how to help.
Mar 10, 2008 | RCA OPAL M4001 MP3 Player
21 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
