Question about Saws
I have a Milwaukee CP12 12V Pipe Cutter. How do I change the cutting wheel?
I have a Milwaukee CP12 12V Pipe Cutter. How do I change the cutting wheel for a new one. I have purchased 2 new genuine Milwaukee cutting wheels but there are no instructions anywhere about how to change this consumable part.
    Sergeant:
  • 468 Answers
I don't own pipe cutter but I have band saw. Just so easy to replace its consumable parts. Check this link . Hope that helps.
Posted on Apr 29, 2013
  • Colin Apr 29, 2013
    Thanks friend. Being a plumber, I took it apart and sorted it! LOL It involved the removal of a circlip, then the wheel shaft, remove the cutting wheel and replacement was this in reverse.
  • Jack Faire Apr 29, 2013
    That sounds great! There is always a great outcome on being analytical.
My tube cutter won't cut
Mate sounds like the gear box is gone
If it's still under warranty take it back
If it's not get a normal brand non battery type you never go wrong
Jan 13, 2014 | Milwaukee tools Milwaukee 2471-20 12 Volt...
Tip
How to Use a Pipe Cutter? Pipe cutters are really useful tools that can...
Pipe cutters are really useful tools that can be used in the house to cut pipes that are made from metal or plastic. You could always try using a saw of some kind but pipe cutters will give you a much straighter edge.
Here are some basic instructions to help you successfully use a pipe cutter.
1. Decide exactly where on the pipe you would like to make a cut.
2. Loosen the handle on the pipe cutter and place it around the pipe.
3. Now tighten the cutter until the blade is in contact with the pipe.
4. Turn the pipe cutter a few turns around the pipe and it will score a line into the pipe.
5. Keep turning the pipe cutter around until you've cut the pipe off.
6. In order to create a nice straight edge inside the cut pipe you need to take the bottom blade out of the pipe cutter.
7. Place it into the cut end of the pipe and turn it around a few times until it's nice and smooth.
on Nov 21, 2013 | Cutter Tools
Is it worth me buying a pipe cutter or is it not something i'll ever get round to using?
If you plan to do any kind of plumbing work in your house i would strongly recommend that you invest in a pipe cutter. They give a much neater and easier finish than a saw but if you don't do much DIY and are more likely to call in a plumber than to do it yourself, don't bother spending the money.
Dec 26, 2013 | Cutter Tools
Am i better off using a hacksaw or a pipe cutter to cut the metal pipe that runs through my garden?
Although pipecutters are generally seen as giving a much cleaner and better cut than hacksaws, they are a bit limited in what they are able to cut through. Hacksaws however can cut through all sizes of plastic and metal.
What is a pipe cutter? What can I use it for?
A pipe cutter is a tool that plumbers use to cut pipes. It gives a much cleaner and better cut than saws.
Copper pipe cutter not working
Replace the cutting wheel or the entire tool
Oct 05, 2013 | Plumbing
What is a double wheeled pizza cutter?
a double wheel pizza cutter is a pizza cutter that has 2 wheels - one behind the other. The advantage of the two wheels is that they go through the pizza in one motion and you don't have to go back and forth to get a clean cut through the pizza.
Feb 28, 2013 | Home
I cannot get off the abrasive cutoff wheel I put on the grinder
I believe the thread is left hand, but close inspection should verify. Also you should never over tighten cutoff wheels or grinding wheels. You should be able to remove with a gloved hand while holding button on top with the other hand
Dec 26, 2009 | Milwaukee Tool Milwaukee 6" Right Angle...
Pipe cutter is crushing the asbestoes cement pipe
I think you are supposed to rotate the cutter around the pipe. If this is so then use a small amount of pressure and then rotate, repeat until pipe is cut.
The cutters could be blunt in which case they must be replaced.
Mar 05, 2009 | Wheeler Rex Pipe Cutter No.29908
Saws Logo
181 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
