Question about Garden
Lithum power battery dead only 2 years old
    Sergeant:
  • 330 Answers
The most common causes of shorter than expected life on a lithium-ion battery is A) Letting it discharge too low before recharging. B) Condition of storage.
It's very important to read all the particular instructions about the product before use. The specs on these batteries are written if the conditions are ideal and most of the time, they are not. I still prefer them to NiCad batteries. Wikipedia have a very comprehensive table of all the new technology for batteries and the pros and cons. Good luck.
Posted on Apr 27, 2013
Testimonial: "Don"t you have a replacement program if you supply serial number?"
Camera shows no power with new batteriesAAA & Lithum
Is the camera turned on; okay simple question but sometimes that is all that is needed. Look in the battery compartment is it clean, does it have battery corrosion? Sometimes the wires in the battery compartment become corroded thus not making a connection. If so a CLA will be needed.
Feb 13, 2014 | Minolta Maxxum 7000 35mm SLR Camera
Re: hp compaq 6910p laptop start button stays lighted, as does volume indicator, and sometimes two colors on he ethernet plug-in. The start will not turn off. And it will not start computer. And...
Hi, please try first by unplug charger and then remove battery, after about 10 minutes, insert battery again and plug it charger, only the battery charging indicator should light on, if the status of other indicators keeps in the same way, maybe the motherboard is faulty and needs to be replaced, in such case, don't worry about your data, it can be recovered since hard disk can be taken apart from your computer to be connected to another one to access your data.
Nov 07, 2017 | HP Compaq 6910p Notebook PC PC Notebook
My acer aspire 7736G was working fine, it's about 2.5 years old, and is used mainly with the power cord plugged in. When using it the other day the computer just went dead on me. I took the batter
You have reached the end life of the battery pack. The battery must have some minimum charge to have computer function even with the AC power pack connected. So I suggest you replace the battery pack as a solution. Any local Radio Shack store can test this battery I am told free of charge.
Jun 20, 2012 | Computers & Internet
I need to install a thermastat
get new thermostat and Seal, Spray with white lithum grease and insert thermosat into new seal ring, clean and spray the seat of where the old thermostat sat. and spray with little lithum grease and install...tighten Cover bolts just dont whale on them ....i put my hand on the head of a 3/8" ratchet and double check them upon completion of the 2 bolts....Hey put a little Permataxte Never Seizee on the Bolts before reinstalling
Dec 16, 2009 | 1995 Buick Roadmaster
Panasonic base unit went dead
THROW IT AWAY.  I HAVE THE SAME PROBLEM AND PANASONIC AFTER SALES "SERVICE" PEOPLE  HAVE BEEN COMPLETELY USELESS!
Mar 10, 2009 | Panasonic KX-TG4500 Phone
Replace internal battery on garmin gps3
Hi - I have a Garmin GPS 2 plus unit which is around 10 years old. I haven't used it for about 2 years. Initally it powered up and eventually found satellites. I switched it on the following day and it will not power up. I have changed batteries but nothing works - tried a master reset but agin nothing - it appears to be dead ?
Ali
Aug 29, 2008 | Garmin GPS
Cpu Fans
your last lined is typed wrong, works, should be worked, (past tense) right?
I guess the screen is 100% dead and PC silent right? no text to the screen ever.
old laptops 15 long years old in fact (can be)
old pentium4 with a square 4:5 screen wow.
some fans are modulated, ever heard of PWM? (this one is)
so did you first remove relic old main battery first, it will be shorted now, and when shorted it overoloads power buses.
then the coin cell is NEXT , never seen one last 15 year, not me.
why wait get the HP RTC cmos coin cell. for 2 bucks and put it in.
dead PC 101, above done, fan dead.
1: power pack 19vdc, it must be at least 18.5vdc,
at the mobo not in hand by it self. the means under load testing.
normal load. we use a thing (20bucks) a voltmeter DMM to test all power packs. or replace it for $10 if you can even find one this old.
there is more lots more, if one component on the mobo shorts.
we can find that but , ill stop here, if you can get this far.
now the book on your PC, page 91 shows how to change the CMOS battery, here is the steps (compaqs are PITA)
this page. (Compaq then thought it lasted 20 years, hahahahaha)
https://www.manualslib.com/manual/273370/Hp-Evo-N1010v.html?page=91#manual
Keyboard cover(page 2-13)
Speaker (page 2-15)
Keyboard (page 2-16)
Switchboard PCA(page 2-19)
CD/DVD (page 2-20
Display (page 2-23)
Top case (page 2-26)
Floppy (page 2-32)
Heat sink (page 2-40)
Motherboard (page 2-50) bingo the coin cell.
the fan is modulated. (it is controlled at all times for speed)
at power on most laps it run real fast first. then slows.
this is by DESIGN to keep noise lower.
id the CD does not eject try on damand there is no power.
if fan is dead, to, power is gone
one guy asked what power means. ok
it means all 3 4 or 5 power regulators on board work
5v
12v
3.3.
1.8 and more, if any power reg shuts down the PC is DEAD.
Jan 18, 2018 | HP ze5560US (DP473U#ABA) PC Notebook
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
