Question about Acer Aspire One D255 Netbook
Power notebook Howdy. This machine has been running fine (provided I keep the processor cool) since it was given to me about 3 months ago. About an hour ago, I was watching streaming video from a tv station with the battery fully charged. (It won't run correctly just using the factory wall-wart. It's only good for charging. At least that's been my experience.) and the screen changed. It stayed lit but black with the DOS-type cursor immoveably on the top left corner. My first thought was to power down and perform a cold boot but now it won't even power down! I can also hear a fan quietly blowing and the blue LED in front is solid on. Any thoughts would be most welcome and greatly appreciated. I love this thing, I just it would behave. Also, in case it would be useful to know, regarding the sliding latches on the underside for (I assume) the battery (I don't know how to access the battery yet.), the "lock" side is immoveably with the red band showing, which appears to indicate being in the unlocked position (you'd know better than I) but the other slides back and forth in what appears to be a normal fashion. Thank ya very much.
  • Sammy Hooff Apr 27, 2013
    UPdate. I let the battery run down so it would at least shut ITSELF down. Then I let it get get a small enough charge to run. When I powered it up, it just behaved normally. Is this thing possessed?
sandrew
  • 2961 Answers
SOURCE: Cursor (pointer) Locks Up
Go to my computer, right click>properties>hardware tab>device manager, then look down the list for mouse and pointing devices, click the '+' sign and right click on your touchpad listing and select uninstall, and then restart the pc.
In Vista start control panel>classic view, then device manager
The touchpad will be reinstalled and then ready to use again as it should be back to normal
Posted on Sep 22, 2008
knotbeerdan
  • 413 Answers
SOURCE: acer aspire 5100 won't stay on when booting on battery
replace the battery. Batteries usually only last about two years and it sounds like it just cant hold any more juice. To find a battery go to google.com and type in the model of computer and push search. Sorry for the news but its an easy fix
Posted on Dec 30, 2008
sys_admin
  • 829 Answers
SOURCE: Acer Aspire 8 inch Laptop.
Hi , Boot the PC and keep pressing F . a screen pops up seletc the last known option and enter and then jst boot the system.
Posted on Jan 11, 2009
shakeelm
  • 224 Answers
SOURCE: my acer one netbook won't boot
This is a common problem with the Acer Aspire one. Apparently, the BIOS needs to be flashed using a flash disk with the required files.
Unfortunately, the files are not available at any website but you can take the Aspire one to any Acer service center and they should be able to flash the BIOS for you free of cost.
Posted on Mar 16, 2009
  • 457 Answers
SOURCE: Acer Aspire 3000 notebook: 1) monitor displays
Monitor: if the inverters were blown, you would be unable to use clamps as a workaround. I suspect a lose or broken contact to the display wafer caused by rough handling of the laptop. This is delicate stuff, you cannot repair without specialized tools and usually its simpler and cheaper to swap the panel for a new one.
Charger: try to remove the battery and connect the charger. Check if the laptop starts now. If yes, the battery probably reached its end of life and drains so much power during inefficient charge that the power supply has not enough extra strength to run the laptop on top. Only one hour of run time hints to a degraded battery, too.
Replace the battery with a new one and check if the problem persists.
If the laptop does not run with charger and without battery, the power regulation in the laptop is fried.
Since there is more than one defect already (replacement batteries are not cheap, too), you should consider to contact Acer repair services. In my experience they provide reasonable priced repairs; they give you a quotation for a small fee before they actually repair the thing, so you can decide how to proceed.
Check if they have a repair site in your vicinity. I went to Acer Hong Kong in 2005 with similar problems and a few days later picked up my machine, repaired to my satisfaction and with a full report what was wrong.
Posted on Feb 07, 2010
Testimonial: "Many thanks for the suggestions. Good advice and surprisingly quick, too. Keep up the good work!"
The fan in my computer is super load!!! i just got it 3 months ago
Win8.1 is very power hungry and increases the fan speed to help keep the processor cool. If the fan is very noisy, contact your supplier for an under warranty replacement fan.
Nov 04, 2013 | Sony VAIO Computers & Internet
Keeps frezzing when connected to mains power. when not plugged in works fine. charges as normal when switched off
It sounds like a driver issue. Check for any updates to drivers for your laptop from the toshiba website.
if you have a restore disk, you may wish to back up any important information and use it to reinstall your operating system to factory default. Since it charges when turned off properly, it does not sound like a hardware issue.
Apr 07, 2010 | Toshiba Satellite P205-S6287 Notebook PC
Switching on but only stays on for a couple of seconds before going blank. If switched off and on it will come on but only stay on for 2/3 second,
Most of the time, owners never clean out the inside of their desktop computer, nor have it done.
Hardware components inside the computer, need a steady supply of air rushing over them, to keep their temperature down. The main hardware component that requires this, is the Processor. If the processor becomes too hot, it is turned off. (BIOS program turns it off)
Without the processor running, there is no computer.
The processor has a Heatsink, and Fan, (Sitting on top of the heatsink), to draw away the heat given off by the processor.
The heatsink is a finned piece of metal, attached to a metal base.
As heat is given off from the processor, it is drawn into the base of the heatsink, and radiated out by the fins.
If the fins become clogged with dust, dirt, hair, and other foreign material, the cooling capacity of the cooling system, drops tremendously.
If the fan blades, center hub, and outside cage of the fan, become clogged with foreign material, the cooling capacity drops termendously.
This in turn, allows the processor to heat up beyond it's thermal operating range, and the processor is turned off. This is a Fail Safe option that is built-in, to keep the processor from burning up.
This is also why it is imperative to keep the heatsink, and fan clean.
Solution for this is to remove power to the computer, (Unplug the computer from surge protector), open the computer case, and use a can of compressed air for computers
There is a Thermal Paste compound in-between the Heatsink, and the Processor. This could have dried up.
The bottom of a Heatsink, and the top pf a Processor have rough surfaces. This cannot be seen readily by the Human eye, but can under magnification.
When the two surfaces, (Heatsink bottom, and Processor top), are mated together, there are Air pockets in-between them, or Voids.
The Thermal Paste fills these voids, and allows better heat transference.
Solution for this is to remove the old thermal compound, and apply fresh thermal compound, (Paste)
The rest of the inside of the computer, needs to be kept clean also. Dust and dirt, are 'magnets' for static electricity. Static will fry out delicate computer hardware components. (Can of compressed air for computers)
Also the Power Supply. The Power Supply has it's own fan to keep it cool, and this fan's blades, center hub, and outside cage, need to be clean. The inside of the Power Supply should be clean also. There are heatsinks inside a personal computer power supply.
The Dell Dimension 2400 has been around for quite a while, in computer rated time. Came out in 2004.
If this is the original power supply, the power supply could be bad.
Electroytic Capacitors may have gone bad. Rectifier bridge, and also IC's.
Solution is to replace the power supply.
Oct 15, 2009 | Dell Dimension 2400 PC Desktop
Won't power on all the way
Computer shutting off after a few seconds to a few minutes
This sounds like an auto shut-off signal given by the processor because of a possible over-heating issue. This usually happens when the laptop has been run for an extended time without having the dust, dirt and debris cleaned from its cooling vents and grills. After time, the thermal paste on the processor bakes under the extreme heat and starts to flake off and lose its efficiency at cooling the processor.
Get a few cans of compressed air that you would buy at an office supply store and using short bursts, blow out the dust and dirt from all the ventilation grills and vents first, make sure the laptop is powered down and battery removed. Then, open all the compartments and clean them out as well including the cd/dvd tray. There is a small black hole on the dvd bezel, just stick an open paperclip in it and it will pop the tray open. Blow a good blast in there to clean the dvd player.
There is the possibility that the thermal paste will have to be replaced, that means you need to gain access to the heatsink and remove from the processor, clean all the old thermal paste from it and apply a small thin layer of new paste to the top of the processor and replace the heatsink, securing it evenly with the attached screws. Below is the link to the service manual that should help....
http://h10032.www1.hp.com/ctg/Manual/c01295820.pdf
Oct 10, 2009 | HP Pavilion dv2000t Notebook
HP Pavillion DV9000
Howdy,
Like you said if you purchase it 5 month ago it should still be under the warranty. if i were you i will go that route
Dec 30, 2008 | HP Pavilion dv9000z Notebook
Processor noise on T61
it is happen when laptop become hot,there is sensor which tell fan to run faster if system is hot.try to get ur laptop in cool place and see.
Oct 04, 2008 | Lenovo ThinkPad T61 Notebook
Randomly Shuts Off
is it hot ?
if it is, it is overheating, try to clean the cpu fan.
Jan 19, 2008 | HP Pavilion zd8000 Notebook
Overheat?
your cooling fan may not be working propperly, check to see if the processor or rams are damaged
Try reformatting it and if it still stalls that your problem is your processor if it cant complete format propperly its your rams or hardrive..
BUT check your cooling fan, that system should not overheat unless the fan is not working propperly (spin fast enough or too small)
Dec 31, 2007 | Compaq Presario V2665us Notebook
Works only with AC power plugged in; battery is recently replaced
it is a loose or broken battery.
93% ? i think it's shorted out.
Nov 26, 2007 | IBM ThinkPad A31 Notebook
Compaq Presario V2000 keeps freezing up
It could be something as simple as a corrupt graphics driver. If you have currently run a Windows update for hardware, there is a chance that a generic Windows driver has been installed and is not working correctly. Go to your task bar, as there is normally a graphics programme running enabling you to set the external monitor etc. If it's there and you have lost all the usual tabs for changing different properties, then the driver will need to be downloaded from your notebook manufacturer. If all in that looks ok then click Start>Run then type 'dxdiag' and hit enter and let windows do a diagnostic test on sound and video. If it's an intermitent problem, this is normally down to overheating, so check the vents around your fan and gently give them a hoover out. Failing all; keep an eye on your processor temperature, you can download allsorts of different free programmes that will run in your taskbar.
Jan 02, 2007 | HP Compaq Presario V2000 Notebook
Acer Aspire One D255 Netbook Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
