Question about Cyberhome DVD Recorder - DVR1600
Cyberhome DVR 1600
When I try to play a DVD movie I get sound but no picture ( I previousley submitted this request but for some reasin I cannot send you an e-mail.)
  • 3 more comments
  • Peter Sciarabba Aug 08, 2007
    I have 2 DVD players, with my second player I get both video and audio (I can play a DVD.) With my Cyberhome 1600 I get only the audio. I can play a DVD but can only hear the voices, the screen remains blue. I tried changing the cables, but I get the same result. The problem is in the Cyberhome 1600 player. Cyberhome is out of business. I need someone who has encountered this problem before.
    Please see my request
  • Peter Sciarabba Aug 09, 2007
    I have had one possible answer that did not cure the problem. Hope there is someone out there that has an answer to help me.
  • Peter Sciarabba Aug 24, 2007
    please read what my problem is. It is not the T.V. or the cables ( using player #2 everything works fine ) The Cyberhome has an audio output but the video is a BLUE screen. It is possible that I may have entered an input on the remote that the unit did not like.
  • Peter Sciarabba Aug 26, 2007
    there is no on screen display at all, only a blue screen. I believe this happened when I inadvertantly pressed a button on the remote. I do not remember which button, it may have been CM SKIP
    Novelist:
    Scholar:
  • 114 Answers
It sounds like you have set video output to compost or s-video but you're using component video (or the other way around). You're going to need to try with a component cable, an s-video cable and a composite cable to find out what output the DVR is using. Unfortunately the manual is no longer available to download so I cannot tell you what button on the remote changes the output but if you have the manual still this is what you are looking for. It would be useful to know if you can see the DVR's onscreen display or if you are not getting any video output at all. If there is no display on any output unfortunately this suggests a physical fault, your DVR is essentially a minimal spec PC with a specialist graphics chip, it's not unknown for the graphics chip or it's DV decoder hardware to fail.
Posted on Aug 26, 2007
  • Anonymous Aug 27, 2007
    Try the "Source" button.
    Thinking about it, it is much more likely that you pressed the "Source" button and the DVR is trying to display from an input that has nothing connected to it such as the composite sockets on the front.
    try pressing Source (or it may be marked input) and giving it 3 - 4 seconds, if nothing happens try again, however if you try it 4 - 5 times and nothing happens then nothing is going to happen.
    By the way CM SKIP skips forward when recording, usually 30 seconds per press, and is normally used to skip commercials.
  • 944 Answers
First thing to check is to plug it into a different TV set if you have access to one. If still not working, then suspect the cable or the DVD player/recorder itself. If it works fine on another tv then all depends on which input you have it plugged into on your main set - get the right cables to try plugging it into a different input on the tv (post back with the TV make and model and the details of which input and which cable type you are using if you need help with this). If you have cable or satellite or another DVD/VCR/PC - do they work on the TV? on different inputs. If not then the problem is either the TV or possibly the TV settings. How are you trying to send an e-mail? perhaps with some details we can help. Hope this helps :)
Posted on Aug 07, 2007
SOURCE:
How can I get the diagram for dvr 1600?
You can download a manual from manuals online at the following address
http://tv.manualsonline.com/manuals/mfg/cyberhome_entertainment/1600.html?p=1
Jun 04, 2014 | Cyberhome DVR 1600 DVD Recorder
Universal remote codes for cyberhome dvr 1600
I have an extra 1600 remote.
I Frankensteined 2 dvrs together to make a working unit,
and ended up with an extra remote.
My unit finallt over heated and died, so let me know where to send the remote. You can send me a cd of music or starbucks tiny little gift card for my trouble if you so desire.
[email protected]
Nov 10, 2009 | Cyberhome DVR 1600 DVD Recorder
How to connect dvd recorder to tv????help
if youre going to be recording programs from the TV , it cant be , normally TV s have A/V
inputs and NOT outputs , the only way is to connect it thru a VCR A/V outputs , hope it helps , AJ
Jul 12, 2009 | Cyberhome DVR 1600 DVD Recorder
What format are you recording in?If the recorder is set for DVD +R, and your playback machine won't read the disc, you may need to record on a DVD-R, or a DVD +-R. Or vice-versa. Some DVDRW discs will record on one machine and won't play on another. The media are incompatible. Another problem - if you are copying a copy-protected disc, it might not play back either. Are you sure you are finalizing the disc? This process takes 4-5 minutes and requires two or three responses sometime.
Dec 03, 2008 | Cyberhome DVR 1600 DVD Recorder
Cyberhome 1600 dvd recorder
i need an operating manual . Where can i get one pls help me
Sep 16, 2008 | Cyberhome DVR 1600 DVD Recorder
Cyberhome 1200
I have a cyberhome 1600 dvd recorder and I need a code to program it to my bell remote but can not find any codes for the cybehome. can someone help with the codes
Nov 23, 2007 | Cyberhome DVR 1600 DVD Recorder
Disc playing on another computer help
It sounds like you need a firmware update but it may be too late now that Cyberhome is out of business. I suggest you buy a better unit but if you have some unfinalized or unreadable discs you want to try and recover I have instructions on how to do that on a PC that may be of help. www.drx9000repair.netfirms.com/
Jan 11, 2007 | Cyberhome DVR 1600 DVD Recorder
Cyberhome DVD Recorder - DVR1600 Logo
62 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
