Question about Charging & Starting Systems for Ford Fairmont
Reset smart lock falcon - Charging & Starting Systems for Ford Fairmont
    Novelist:
  • 157 Answers
Going to require more info than that. tell the whole story and identify what you are working on
Posted on Nov 20, 2013
Fitted smart lock module under dash now want to reset remote on au falcon
The official workshop manual Suggests:
  1. Close the doors.
  2. Turn the ignition key to the accessories position.
  3. Within 5 seconds of turning the key, hit the rear demister button (center console) three times in succession.
  4. The door locks will cycle once to indicate the special mode has been entered.
  5. Press any button on the remote you wish to program.
  6. The doors will cycle to indicate a new remote has been programmed.
  7. Continue steps 6 and 7 for all remotes (including existing ones) you intend to use on the vehicle.
  8. When you've programmed all the remotes, turn the ignition key off. The doors should cycle again to indicate the programming session has been completed.
Jan 25, 2015 | Smart Cars & Trucks
Ford Falcon Futura AU II 2000 Ignition will not turn over have cleaned all battery terminals, checked starter motor connection. Replaced start inhibitor switch on auto transmission. BASE coming up in dash...
the circle on the dash is smart lock..(ignition cut off like a kill switch immobilser) the only way to fix that is take it to ford or a macahnic its a module inside the ignition ,,,or the computers smartlock aint letting it go
Sep 24, 2008 | Ford Futura Cars & Trucks
Tip
1999 ford falcon left hand rear door doesn't locked
my 1999 ford falcon left hand rear door doesn't locked. though i locked the car that door still openend , i had checked the child locked but sstill doesn't work.
on May 01, 2010 | Ford Fairmont Cars & Trucks
Ford wont start
Is the fuel pump working? the fuse may be blown or the wire in the boot disconnected (on top of the fuel tank)
Jul 02, 2014 | 2005 Ford Falcon
Put in new starter in 2003 ford expodition and it still won't start what can my problem be won't even turn over?
Smart lock? do you have a picture of a red hand on instrument panel? With falcons quite common. Turn & hold key @ start posision, Hit dash upwards on left side of steering colum, If start = faulty smart lock module. I don't know if expodition has smart lock but probably does
Jun 15, 2012 | 2003 Ford Expedition
Ignition problem 2002 Ford Falcon XR8
check the immobilizer for operation
unfortunately the coil packs on the falcons are subject to failure so you may have to remove and have them tested
May 04, 2017 | Ford Fairmont Cars & Trucks
How to bypass immobiliser in 94 ford falcon after ignition barrel has been replaced ??
Your ford dealer visit may not be as expensive as you think, you need 2 pats keys and have them perform an ignition key code erase then they should be able to program your 2 new keys, The Ford Dealer I work at only charges 0.5hrs or approx $50.00 dollars Canadian.
Jan 12, 2012 | Cars & Trucks
Relacement of ford transmission
from late EA through to early AU with smart lock, stay away from smart shield found in late AU onwards because they are a major pain
May 19, 2009 | 1983 Ford Fairmont
Vehicle Parts & Accessories Logo
167 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
