Question about Radio Communications
How to clear "Busy" display when not transmitting
    New Friend:
  • 18 Answers
Adjust the sguelch level
Posted on May 14, 2013
Yaesu 3100 transmit problems
There are several reasons you may not be able to transmit with the FTM-3100R:
1) Your antenna is not matched to the frequency of use and presents a high SWR. The 3100 protects itself from high SWR by refusing to transmit
2) You have somehow enabled the busy-channel-lockout feature in the setup menu, and you are operating with an open squelch
3) Your DC power supply voltage is too low to support transmit current
4) You are transmitting with too low a power setting and the receiver cannot hear you
5) You are attempting to transmit to a repeater that uses a CTCSS squelch tone, and you do not have the proper squelch tone configured
Both of the LEDs to the left of the display should turn red to indicate you are transmitting. If both LEDs turn red, your problem is likely either #4 or #5.
May 21, 2017 | Yaesu Radio Communications
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
What does TOT mean on display?
TOT Penalty means: If the radio transmits more than a set time, it will beep an T-O-T error tone and the radio will only receive a signal for the penalty time. (TX inhibited for this time).
Under the above mode, press Up/Down buttons to select On or Off and then press Mode button or PTT button to set Busy Channel Lock Out. The radio will then save selection and exit to receiving stand-by
mode.
To DISABLE... navigate the menu to "PENALTY" in the display... press mode button... then use UP or DOWN buttons to select mode... to disable select "OF" (which means off).
Good Luck.
Apr 26, 2014 | Midland M222P (22 Channels) 2-Way Radio
Uniden uh65sx radio has constant busy sign on screen
The squelch control is too far open and results in it thinking the channel is busy.
Jun 13, 2013 | Radio Communications
Program garage door opener
With the car on, hold the outer two buttons release when display center says channels cleared, this clears stored codes. Then while holding the garage door opener 1 to 3 inches from the homelink buttons, press BOTH the garage door opener button and the desired homelink button, release when the display center says channel trained. Then test the button, it will say transmitting on the display center if it worked.
Jun 16, 2011 | 2006 Dodge Magnum
My red message indicator light is on, but i dont have any messages. How do i fix this? Panasonic KX-DT343
Press the MESSAGE button and look at the display. The red message light is lit from any phone pressing the MESSAGE button when they call you or (a Pana whoops) dialing 4 into the busy tone.
One of the soft keys under the display will be CLEAR. That clears the message from that phone.
Carl
Jul 29, 2010 | Panasonic KXDT343 Phone
Does anyone have serial pinout for mannesman tally mt645 printer.
Pin Signal
1 Chassis Ground
2 (TxD) Transmit Data
3 (RxD) Receive Data
11 & 19 (RTS) Request to Send
5 (CTS) Clear to Send
6 (DSR) Data Set Ready
7 Signal Ground
20 (DTR) (Busy) Data Terminal Ready
Feb 19, 2010 | Tally MT645 Printer
Have a Panasonic kx-e700m typewriter. I came back from vacation and the display reads "Machine is busy." I have tried to clear it by turning off the machine, typing "code+K" and have not been successf
hello sonya, this may or may not work, but leave power switch on, open your top cover, unplug machine and let sit for about 10-15 minutes. plug back in, close cover and see if you can type. if it still doesn't work, you're most likely looking at a "hard" failure that can only be repaired by a tech.
hth and good luck,
razors
Apr 13, 2009 | Office Equipment & Supplies
Sharp UXB700 Fax
Below is for when you are using machine in fax mode, is that how you use it or are you also using the answering machine function? ie TAD mode
If desired, you can change the number of rings on which the fax machine
answers incoming calls in FAX mode. Any number from 2 to 5 can be
selected.
1 Press FUNCTION once and 3 times.
Display:
OPTION SETTING
To select FAX mode, press
(with no document
in the feeder) until the arrow in
the display points to FAX.
RESOLUTION/
RECEPTION MODE
RESOLUTION/
RECEPTION MODE
FAX
A.M.
TEL
Using TEL Mode
58
2 Press once and once.
3 Press once.
4 Enter the desired number of rings (any
number from 2 to 5).
Example: 3 rings
5 Press to return to the date and time display.
Note: If you are using Distinctive Ring, the fax machine will answer calls after
two rings regardless of the above setting.
Oct 16, 2007 | Office Equipment & Supplies
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
