KFR-35GW/MA CAN YOU PLS TELL US WHICH GAS TO USE TO FILL THE COMPRESSOR? 410 or 404
2 Suggested Answers
  • 8 Answers
SOURCE: Display E4 code then only normal air blow in the room
check your cap also you may have a bad condensor fan
Posted on Mar 13, 2009
My Celestial KFR-36GW/C3 has stopped cooling. it just blows air! Please help ASAP!
hate to tell you this... but... it's a valve problem, one that requires depressurization of the freon to replace. Then the air dryer replaced and freon needs to be recharged by a licensed contractor. The intentional venting of freon is against Federal Law IAW the Montreal Protocols on Greenhouse Gas emissions. In some cases, it could be a bad compressor in the exterior unit. A qualified service person has pressure testing equipment to diagnose the problem quickly. (A bad compressor also requires depressurization... licensed contractors have freon recycling equipment.
Jan 25, 2015 | Heating & Cooling
Shinco fault code e2
I recently had the E2 error code on 2 units a KFR-35GW/BMVE and KFR-50GW/BMVE. I recommend checking the refrigerant. Our's was extremely low and having it filled/charged resolved the issue. In all of the Googling, this solution never came up.
Initially the error code would come on and flipping the breaker off for 10 mins or so would reset it and it would work. Probably did this about 10 times every so often (like over weeks). Eventually this did not work and researching online led us to believe that either the indoor pipe sensor or indoor PCB was bad. Spent lots of time online trying to find these replacement parts to no avail. Was finally able to get a friend of a friend that is an A/C person to check them out and discovered the Freon was too low. Hope this helps someone else out there stuck with these "unserviceable" units.
May 06, 2013 | Heating & Cooling
Fault codes for KFR-66GW
I guess it's signs of overheating compressor, raised the temperature a bit working in the refrigeration and pull out from the outdoor unit thermistors from the copper where it is hovering and let it.
Apr 13, 2012 | Heating & Cooling
I have an celestial air con unit model KFR-70GW/K it is blowing air refresh out but will not turn on to air con with the remote... help
Check temp setting minimum -3 degree than your room temp and also in cool mode. If while settings there any beep sound? If not transmission problem between remote and PCB. Replace batteries and check once again. If beep sound comes and no start, check compressor is working and also with proper gas pressure. Thanks.
Jan 22, 2011 | Heating & Cooling
KFR-12G New Compressor.....Draws too much amperage now. As though it is in the start mode all the time. New Capacitor too. Not overcharged either. Wiring is as it was originally. Thanks in advance.
Well, I looked at the date of post, doubt, you still need help, But, you can try a hard start kit. A generic one will do. It may decrease the life of compressor though
Oct 27, 2010 | Soleus KFR-12G Air Conditioner
HITACHI AIR COMPRESSOR
what type of air compressor you have,since when you maintained it
Sep 23, 2009 | Hitachi EC12 Portable Electric 2hp Air...
How mush air i need to put in my golf gti 2.0 year 2000
well that depends on how much air the tire requires if the tire requires 32 psi you will need at least that much to fill your tire and so on
Mar 24, 2009 | Air Tools & Compressors
Feb 21, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Soleus kfr 18gwda
The fan blade can be purchased by calling 1-888-8soleus.
Mar 11, 2008 | Soleus KFR-18 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
