Question about Saws
My stihl concrete saw will not tick over when i knock the choke off
When i start my stihl concrete saw it will run but when i take the choke off it just cuts out i have cleaned both filters and checked the spark plug could anyone help with this problem please.
  • 2,239 Answers
This is a fuel starvation issue, first thing to do is replace the fuel filter in the fuel tank, hook the hose out through the filler hole with a length of bent wire, once out pull the filter off and replace.
Posted on Apr 27, 2013
Testimonial: "thanks andrew will try this and the fuel filter is the only one not checked. "
  • 2239 Answers
SOURCE: i have a stihl saw ts400 change plug ands air filters but wont start please can you help
Check the compression, these machines work in very harsh conditions, as a compression test you should be getting a good 120 psi.
Posted on Mar 18, 2012
  • 23 Answers
SOURCE: changing spark plug on a Stihl 410 cut off saw,
right by the decompression valve is the spark plug. if you remove the one screw for the valve you will see that to get access to the plug is very easy,
Posted on Mar 04, 2010
ftw1952
  • 10319 Answers
SOURCE: Ts420 stihl cut off saw
the jets in the carburetor need to be cleaned out very well to operate this engine
the holes in the jets are very small and clog up easily with in a year or two
Posted on Jun 22, 2011
  • 2239 Answers
SOURCE: My Brand new Stihl ts420 cut saw wont run full throtle, smokes white, and leaks fuel out of exhaust filter. it runs like the choke is half on.
This sounds like the carb is flooding, there is a rubber tipped needle under the metering side of the carb, this may be leaking, before replacing the needle make sure the air filter is not blocked, replace with a new filter and try again
Posted on Feb 18, 2012
  • 2239 Answers
SOURCE: stihl ts 400 wont start
If there is good fuel in the tank and the plug gets wet with fuel, and there is a good spark stating the obvious it should go, if not there could be a mechanical issue, piston scored, rings worn etc,
Posted on Apr 17, 2012
Will only run on full choke
This is a fuel supply issue. Don't use the saw until you find the problem.
Things to check are:
fuel filter, fuel line crack, impulse line, carb needs work, air leak to engine. Etc.
May 20, 2017 | Stihl Garden
Model 026. when trying to cold start, why does the compression button pop out without starting?
Its ment to.!!! that's the job of a decompression button.
Procedure:
1.push on off switch into full choke position, depress the decompression button.
2.pull the saw over until it 'fires' once.
3. the decompression button would have popped back up, click the on/off switch up to half choke.
4.pull saw over and it should fire up, revving.! blip the throttle to return it to tick over.
Mar 11, 2016 | Stihl Garden
How to adjust oil pump 08s concret stihl saw
There is no oil pump on a concrete saw, only on the chainsaw.
Feb 17, 2014 | Stihl Garden
Saw runs for awhile then shuts off and continues to run.
i always have to start the saw and then pull the trigger like every 5 seconds for about a minute then it works for me
Sep 18, 2013 | Stihl Concrete Cutoff Saw Carburetor Ts...
Ts410 stihl saw stopped working
Starting procedure for Stihl.
(cold starting)
Place cutoff saw on floor (flat clear surface).
Hold throttle in, while pushing on switch all the way down.
Hold cutoff saw firmly.
Pull starter handle until saw fires, it should then cut out.
Click the starter switch up 1 click to half choke.
Pull starter handle again until cutoff saw fires up. note: it will be reving because the trigger is loched on, (blip the throttle once) and it should go to tick over.
There should be np need to keep playing with the choke when the saw is warm. No need to lock the trigger when starting warm..
Mar 31, 2013 | Stihl Ts410 & Ts420 Cylinder & Piston Kit
Throttle trigger will not lock
1. Make sure dead mans handle is fully depressed
2. Squeeze throttle in
3. Push choke switch all the way down
4. Pull saw over till it fires
5. Click choke switch up one position to half choke
6. Pull over saw until it fires up, saw should start running at high rev's
7 .'blip' throttle for saw to return to tick over.
If the choke switch doesn't stay down in section '3' check chokelinkage to carb.
Dec 31, 2012 | Stihl MS181 14" Chainsaw
Choke trigger on the handle will not lock to start the chainsaw
more information please..
To lock the choke on:-
1. depress dead mans trigget on top of back handle
2. squeeze throttle trigger fully in.
3. slide on switch fully down to 'full choke' position. 'it should stay there'.
4. Pull saw over until it fires once.
5. click 'on' switch up one position to 'half choke'
6. pull saw over again, saw should start running and be revving high.
7. 'blip' throttle, saw should stop revving and run on tick over.
I also have a stihl chainsaw model home light 240. I just had it sharpened and a new spark plug put in by the repair guy. I used it for 30 mins and it kept stopping until I couldn't start it again
(cold starting)
Place saw on floor (flat clear surface).
Make sure chain break is on.
Place right foot in the flat of the rear handle.
Place left hand on top handle.
Pull starter handle again untilsawfires up. note: it will be reving because the trigger is loched on, (blip the throttle once) and it should go to tick over.
Warm starting is performed by holding the rear handle between the thighs rather than on the floor.
Nov 14, 2012 | Stihl Garden
Looking for a short curcuit wire
If you are referring to the wire that kills the engine it will be attached to the coil at one end and the on/off/choke lever/switch at the other end. If you need to replace it then contact a Stihl dealer.
Aug 13, 2012 | Stihl Concrete Cutoff Chop Saw Clutch...
Saws Logo
227 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
