Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
Mitsubishi WD-52327 52 in. Rear Projection DLP
When I turn my TV on, the Timer light stays lit 'green' steady for approximately 1 min. After that, the Lamp light blinks 'green' for approx 2 min. then turns steady 'red'. The screen never turns on and I never hear any audio. This was an intermittant problem initially, then it quit doing it for about a week, now it will not come on at all, just goes thru the same cycle. I called Mitsu and they said it was the bulb. The set is barely over 1 yr old and I have a hard time believing it is the bulb. Is there something that 'tells' the set to turn on the bulb after x-amount of time? If so, I believe this may be the culprit. As stated earlier, the set just went past the 1 yr mark and the warranty is expired (of course). I have tried unplugging the set for several minutes, plugging back in and resetting the set. I have tried removing and reinstalling the bulb several times, and I continue having the same problem. I would hate to pay $200 for a new lamp only to find out that my suspicions are correct and it is not the bulb. Any suggestions?????
  • 2 more comments
  • David Brooks Sep 13, 2007
    As expected, I just shelled out $200 + bucks for a new lamp, and, big surprise, I have the same problem! This pisses me off to no end. The customer support folks guarantee that this is the problem. I had my suspicions all along that it was something else. There has to be something intermittantly messed up with whatever it is that 'tells' the lamp to come on. I do not get any audio unless the lamp comes on. I also found that when the lamp does 'decide' to come on, you can here a faint noise that almost sounds like an alarm prior to the light coming on....bwoop, bwoop, bwoop, then the audio and lamp come on. I have noticed that the noise doesnt happen everytime it 'decides' to come on, however, if I am having problems getting it to come on and I hear the noise, I KNOW it will come on and it does. Does ANYONE out there have any kind of clue what this problem is?????? Could it be a relay or a timer or something?????????? Thanks in advance.
  • Anonymous Jan 01, 2009
    I have a 2 year old wd 52327 had the same problem while under warrenty they replaced the light engine now it is doing the same thing & no warrenty i replaced the lamp no help now i guess i will have to repla bet it want be a mitsubishi any help out there???????
  • kenny lewis Jan 02, 2009
    I have a 2 yr old wd52327 the light will come on for about a minute then start blinking the tv never comes on I replaced the light engine last summer & the lamp 2 months ago after i un plugged it came on the next time i tried to turn it on same thing will not come on you can bet if i buy a new tv it want be a mitshubishi any help would be appreciate it
    ps i don't know if unplugging it helped or not?
  • Anonymous Jan 30, 2009
    I NEED A MANUAL FOR MY MITSU WD-52327 PROJECTION TV. I NEED TO REPLACE THE LAMP BUT DO NOT KNOW WHERE TO START TEARING IT APART AND WHERE THE LAMP IS LOCATED
I have a 2 year old Mitsubishi Rear Projection 52" model WD-52525. I recently experienced the same problem as you. My TV quit without any warning and the red lamp light came on. I bought a replacement lamp just like you did, did everything you did too, but it still didn't work either. Since it's past the 1 yr warranty (of course), I took it in to an authorized service center for an estimate. They determined the light engine failed and it will cost me $816.35 to repair. I already shelled out $240+ for a lamp, $48 for the repair estimate and I said "hell" no, I'm not going to fix it for another $800+ and bought a new TV. I'm writing a letter to Mitsubishi expressing my deep dissatisfaction (to put it mildly) with this faulty product and will be requesting reimbursement, which I probably won't get. I sincerely hope this is not the same problem your TV has, but if it is be prepared for a costly fix.
Posted on Sep 14, 2007
I had the same problem, started to come on..went to blinking red light then power shut down. Replaced lamp...same problem. Read about capacitor problems online, replace 3 on power board and the set has been working for 3 weeks now...give it a try, I'm not all theat techie but a few minutes with a soldering iron saved me at least $500.00 dollars that the autorized Mitsubishi dealer quoted.
Posted on Dec 06, 2008
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
You cut off before i could reply, heres a link for one on ebay. http://cgi.ebay.com/EXACT-REPLACEMENT-LAMP-MITSUBISHI-915P020010-bulb-only_W0QQitemZ260144858605QQcategoryZ61407QQrdZ1QQssPageNameZWINQ3aPOST0Q3aRECOQ3aBINQQcmdZViewItem
Posted on Aug 08, 2007
SOURCE:
My WD-65838 has a steady blinking green timer light and I cannot turn the set on. I have unplugged it, then reset it without success. Do you have a suggestion?
i am currently experiencing the same problem, luck for me the tv is under warranty. i will come back after the service center has repaired the tv.
Jan 15, 2011 | Mitsubishi WD-65838 DLP TV
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I have a mitsubishi tv model # WD 52525 DLP and the timer light just keeps flashing and the TV will not go on
i have a mitsubishi ws-55859 rear projection tv. the green timer light just keeps flashing and the tv will not turn on.
Aug 09, 2009 | Televison & Video
Mitsubishi wd-62725 rear proj green timer light will not reset
you need the V26 DLP DM repair kit at the following link. The kit contains the replacement capacitors and the cd with instructions.
http://www.tvrepairworld.com/
Jul 19, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Flashing Green "Timer" light on my Mitsubishi WD-62525
My Sony had the same problem. Unplug from the wall for 36 hours and it should solve the problem
Mar 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
WD-62725 DLP TV Automatically Turns Off
Its usually your DM control board!!! it needs to be replaced!!!
Mar 29, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-52725
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Nov 29, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
1,399 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
