Question about Fisher and Paykel Dishwashers
Fisher/p nemo dishwasher door
HI. I have notice a leak in the right side of the dishwasher near the door. On further examination, I noticed the door was not sitting flush - dropped on the left side and thus not sealing- or closing properly. (nb A peice of tape had solved the closing for quite a while however the leak is new.) Is this an easy fix?
  • Fisher and P... Master
  • 3,247 Answers
It is sometimes linked to the dishwasher not level or the spring tension on one side getting weak. Refer installation manual http://kitchen.manualsonline.com/mdownloads/c11d2c17-cb0a-489c-99bf-a61513fbf876.pdf to make sure the level is adjusted. May need to replace the door seal in case leak is too excessive.
Posted on Apr 30, 2013
textonor
  • 130 Answers
SOURCE: Bosch Dishwasher Door Leaking Steam
Pull the seal that is on the tank 1/2 way out then close the door. This will make sure the door is tight to the seal. This happens sometimes that the seal becomes flattened. I have been using this trick on Bosch dishwashers since this series came out in 1997.
Posted on Jan 06, 2008
commtech
  • 13 Answers
SOURCE: i bought a used 7 1/2 year old fisher paykel dd603
I have the same model F&P and just experienced similar problems. My top drawer was leaking due to that "not important" thin white tube. It really sounds like you called a general appliance guy and not a trained F&P repairman. The guy who fixed ours mentioned it provides strain relief for the drain tube & wiring loom when the draw is pulled in & out. So no, it is not crucial to the washer operating, however it may be causing all your problems. On mine, when the draw was pushed in, because this tube was broken it was poking straight in to the top drawer and stopping the lid from sealing causing a FLOOD. Also the flood sensor got wet and had started to corrode and was going to fail soon anyway so it really needed replacing. Additionally, my washer had always "groaned/ R-R-R-R-R-R'd" as it wound down the lids on each compartment. The Fisher & Paykel repairman recommended I get the "kit" for it to fix these issues on both drawers. The kit replaces several parts that have been found to cause common failures over the years. He ordered it and has just been back to install it. It cost nearly $300 all up but I reckon is good value. The machine now works like new, and all of the most likely problems that should eventuate have been addressed. It is now whisper quiet when closing/opening the lid too! The downside is that F&P took 2 weeks to arrive first off, then another 3 weeks before the part arrived. :-( If you decide to overhaul your dishdrawer - you won't recognise it! ( btw - I have no affiliation with F&P either, other than my missus loves her F&P DishDrawer and I love keeping her happy! )
Posted on Jul 02, 2009
SOURCE: Replacing LG Dishwasher door gasket/seal with Part # 3920DD3005A
Problem solved - it was not the gasket - it was the vent tube as defined in one of your on-line reported solutions. Thank you!!!
Posted on Oct 14, 2009
Testimonial: "Contacted numerous resources to try identify LG dishwasher leak problem, including LG. Found solution,vent tube right here on FixYa. Many thanks!!!!"
SOURCE: fisher n paykel nemo dishwasher won't go. Sounds
Check to see that the outlet pump (underneath) isn,t stuck eg sumething stopping the pump from turning.Also check that the outlet is clear where it connects to the sink outlet.Hope this helps.
Posted on Dec 13, 2009
omaharox
  • 166 Answers
SOURCE: LG Dishwasher (3850DD3006A) is leaking along left
Contact LG @ 1800 243-0000 this is a known issue and they may help you out.
The drying vent needs to be updated if this is a couple years old amoung other items such as the wire harness and inner door liner..
Posted on Jan 09, 2010
Why is our dishwasher leaking water
There are 4 places it could be leaking. 1) at the connection where the water line connects to the dishwasher. If the dishwasher has been in operation for a long time then this is not likely to be the problem. If this were the problem you would notice water even when the dishwasher was not running. 2) at the drain hose connection. You would notice the water during and shortly after a drain cycle. The drain outlet is usually a hard plastic over which the rubber drain tube is clamped. Either the plastic could crack or the hose could dry out and crack. 3) The seal around the pump could be leaking. 4) The door seal could be leaking, though this in not usually the problem. You can probably determine the problem by removing the bottom panel so that you can see underneath the unit, and then run a cycle. There are usually 2 screws between the door bottom and the lower panel (near the sides of the machine) and 2 more screws at the
bottom of the lower panel (the recessed part of the panel) near the sides. Don't stick your hand under there because you will have power to the unit and a wet floor. That is a bad combination which could be lethal. Just shine a flashlight under and see where the water is leaking from as it runs. Remove power at the circuit breaker before trying to do any service on the unit.
Aug 22, 2014 | KitchenAid Dishwashers
Fisher and paykel nemo door latch
actually to me it seemed pretty easy ,, i am sure u can do it .
Aug 30, 2012 | Fisher and Paykel Dishwashers
Fisher n paykel nemo dishwasher won't go. Sounds
Dec 13, 2009 | Fisher Dishwashers
Maytag Jet Clean leaking through right side of door during rinse
It is important to examine the leak to see where it probably originates.
If the water is leaking from the right hand side of the door on your dishwasher, it is time to replace the gasket that seals the door when the door is latched.
Aug 10, 2009 | Dishwashers
Leaking dish drawer
It sounds like your door seal is giving you a problem. Before you replace the seal try running the dishwasher on the highest heat cycle to help the seal conform to the door.
May 20, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwasher problem
i had the same problem with a fisher paykel nemo dishwasher beeping at end of cycle, as im a mechanic i was curious to pull it apart and see how it works, i pulled the main control board out and unscrewed the three screws holding it all together and inspected the circuit board, and what did i see, a dry solder on the blue relay box or something, resoldered it, reassembled it and now works a treat, hope that helps
Feb 01, 2009 | Dishwashers
Bosch SHV45M03UC dishwasher door leaking
the latching mechinisum is at fault or the door is bent.
Apr 07, 2017 | Dishwashers
Dishwasher Leak...
Below is the service manual
http://www.scribd.com/doc/6462163/DD601V2-Manual
read page 18 and put into diagnostic mode. The select P2 and drain the water.
Mat
May 18, 2007 | Fisher and Paykel 23 in. DD603H SS...
Dishwashers Logo
132 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
