Question about Behringer Eurorack UB1832FX-PRO Showroom Demo
My Eurorack's LCD screen is flashing
When I turn on the Eurorack from the switch at the back, the DSP's LCD screen is flashing 8 and every time it flashes it makes a clicking sound.
How do i turn off the dsp and run stereo mode?
Pressing the PROCESS button opens up the various screens that determine the signal path setup and that control processing parameters for the DSP modules: I/O, PEQ, XOVER, DEQ, DELAY, and LIMIT.
I/O
The I/O module sets up the signal routing inside the DSP from input to output. Press and rotate the SELECT encoder knob to choose between dual mono, stereo, bi-amped, or bridged routing options.
STEREO
STEREO mode routes the signal from both the A and B inputs through a single series of DSP modules. The parallel DSP modules process the A and B signals with identical, linked settings (only module "A" parameter settings appear on subsequent DSP module screens).
The manual is available at: http://www.behringer.com/assets/NU6000DSP_NU3000DSP_NU1000DSP_M_EN.pdf
Jun 02, 2014 | Behringer Inuke Nu6000dsp 6000-watt Power...
Had LG6700 8 weeks today a faded line ran down centre of screen 15 cms wide now screen won't show picture or turn on?
you can only replace lcd's not fix them, take the item back for a manufactures warranty replacement- it sounds like the lcd pixels dead or at least on its way, also a possibility the lcd controller is malfunctioning
Mar 30, 2013 | Televison & Video
Not turning on
The power supply has failed.
Nov 27, 2012 | Akai LCT3201AD 32 in. LCD Television
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
Apr 24, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
Hello. We were hoping that you can help. We have a Toshiba LCD, 40G300U3. When we turn the power on, the green power light turns on and we can hear sound coming from the speakers ... however the screen...
Take a flash light into a dark room with your laptop, and shine it into the screen when it is on. If you can see the screen then more than likely your back light is out.
If you do not see an image with the flash light, then more than likely your motherboard or LCD is going bad, this needs to be tested by a computer profession to see which is going bad.
Jul 17, 2011 | Toshiba Televison & Video
Let me clarify whats happening here. When I put it in Surround mode, or DSP mode, the buttons do light up, but there is no sound. If I push the Analog Direct button it does light up as well and it does...
With no specific model mentioned it's hard to look in a manual for recommendations or visualize what possible switch may be out of place.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Source Selection, Mute, Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Jul 12, 2011 | JVC Audio Players & Recorders
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Yamaha DSP-A2070
Check the 'front mix' switch on the back, set it in off; main level on max.
Feb 29, 2008 | Yamaha Audio Players & Recorders
Behringer Eurorack UB1832FX-PRO Showroom Demo Logo
37 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
