Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Mower riding no sark to plug
  • Craftsman Master
  • 7,482 Answers
Hi sven
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and cranking the engine or by pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Bud
Posted on Apr 27, 2013
2004 chevy z71 truck has new sark plug plugs and oil change and has no power like it is plugged
Catalytic converter is plugged . Need to have exhaust back pressure test done to confirm this . Videos on youtube showing how to do this .
Oct 27, 2016 | Cars & Trucks
CUB CADET RIDING MOWER HAS NO spark TO PLUGS
For some reason, our Cub Cadet riding mower 1046 will not start. The battery is o.k. Where are the spark plugs? What could be wrong with it?
Aug 15, 2012 | Cub Cadet Garden
How do I drain the oil on a Briggs and Stratton 8hp 191702 ride on mower ? I can't seem to locate the oil drain plug.
if you follow the dip stick tube down to the base of the engine there is a square head bolt that is the drain plug
Jun 27, 2012 | Garden
Wire seat so mower doesn't shut off
Put a piece of wire hooped in plug the seat switch plugged in to. It not good to jumper out safety items.
May 03, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
My unit runs fine until i hit long grass and the motor splutters slightly could this be a fuel filter i have had 100 hour service and had all the necesarry engine adjustments . i did run the tank empty...
Thank you for using fixya.
It would be pritty hard to get anything in the fuel tank unless you took off the cap and rode it that way.
Some tests you could try:
safety safety safety
REMOVE THE WIRES GOING TO THE SARK PLUGS PLACE THEM A GOOD DISTANCE AWAY.
remove the belt from the front pulley
raise the front end up a bit
lower the deck 1 notch to release the pully break
with a thick glove such as a welding glove grab a blade one at a time, raise it up and down making sure there isn't any movement. If there is then you have a bad pulley
Now push and pull the blade and make sure it moves freely. if it doesn't then you have a bad pulley or may have string rope fishing line ect spun around the shaft.
Now check the front electro clutch with the key off and pto not pulled, the pulley should move freely. Turn the key on (NOT THE MOTOR) pull the pto switch and the pulley should not be able to move.
If all of these are ok I would take it in and have it bench tested, compression mag needle or coil. A condencer that has gone bad can cause a loss of power, spuddering ect. under a load.
I hope these ideas help.
Terry
Jan 15, 2011 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Craftsman riding mower starts rides a few minutes then stops
Make sure that when you check the oil that the mower has sat I say for at least 5mins. Your mower might have an oil sencer. If not I think it might be the coil gettin hot and shorting out.
Aug 23, 2009 | Garden
Need spark plug gap for 2000 jetta
usually all brands recoment use platinum NGKs
those plugs are all set to install.
autolite is not recomented
Mar 17, 2009 | 2000 Volkswagen Jetta TDI
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
32 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
