Question about Bosch Classixx WFO 2466 Front Load Washer
Bosch 2467/GB/06 no display no go
Blew fuse, no display at all, capacitor problem? or control unit?
    President:
  • Bosch Master
  • 662 Answers
Check power on wall with some other gadget, check plug fuse....
Posted on Apr 28, 2013
Display not lighting up at all
The display / control units are sensitive to voltage surges and it was most likely damaged when the fuse blew.
Apr 28, 2014 | Bosch Classixx WFO 2866 Front Load Washer
Bosch wfo2866gb wont work
Possible that the control panel had failed, there is a fuse within the control panel which needs to be checked. Most probably if this fuse has blown there is a short within the board which need to be confirmed for a board failure.
check this link to remove the panel: control panel
Jan 10, 2013 | Washing Machines
Our microwave MH6150oxhq-1 has worked perfectly until yesterday when i went to press start the clock numbers started flashing and poof dead!! It seems like I have NO power to the unit, Is there a way to...
If it doesn't come back after you unplug it and plug it in again, you probably have a blown fuse or thermal protector. If it is a thermal protector, just replace it - they do sometimes break spontaneously. If it is a fuse, have the high-voltage capacitor checked to see if it shorted. Generally if the capacitor is shorted, it is a good idea to also replace the high-voltage diode since it carried the short-circuit current that blew the fuse.
I assume by "clock numbers ... flashing" you mean the normal timer countdown began. If there was abnormal behavior on the display you have a controller problem. This could be anything from a failed power supply capacitor (relatively cheap fix) to a bad controller chip (only available on a replacement control board that costs almost as much as the oven itself unless you get lucky enough to find one on a junker of the same model).
Sep 09, 2011 | Ovens
Going through full wash as normal but won,t go onto rinse or spin mode?
Most front load units must have two things, door must lock and must sense cold water for rinse. I would check the fill line for the cold water, if clogged with sand, it will not progress through cycle. If the unit doesn't drain it will not spin, is there water left inside the drum area?
I am here if you want more assistance
Aug 28, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
I just replaced the fuse with a lesser fuse now the amp just hums. The pots are all on low and it does this with or without a instrument plugged in
This is likely a power supply problem such as a bad filter capacitor. If the fuse blew before, probably one of the rectifiers blew due to a shorted capacitor followed by one or more diodes failing.
Take unit in for repair unless you are adept at electronics.
Dec 01, 2010 | Marshall Amplification Marshall AS100D 2x8...
GE JES1855 1100 Watts Microwave Oven not working. Display lights do not come on. Checked wall plug and it is ok.
Sounds like internal fault protection fuse blew. can be fixed by qualified technicians. their is very high voltage coils and capacitors within this unit and can cause harm or death instantly if not discharged properly.
Aug 12, 2010 | GE JES1855 Microwave Oven
Bosch shu5315 06
it sounds as though the circulating pump may not be operating. if so fault is often due to the pump capacitor being faulty and this is a cheap part.
Jun 05, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Exxcel WFX2467
try removing power from unit and re-applying about 15 minutes later
May 13, 2007 | Bosch Exxcel WFX 2467 Front Load Washer
Bosch Classixx WFO 2466 Front Load Washer Logo
81 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
