In the video you see how I hit I'm the code from the dealer they told me to hit seek didn't work hit a few other buttons still nothing please help call 313.802.6161 please if you know issue
SOURCE: Unlock Code
Get the serial number from your head unit, contact Kenwood. they will have an unlock code for you. OR if you still have the manual for the head unit, check that as someone my have written it in there.
SOURCE: Faceplate malfunctioning and scanning repeatedly
hi this meens the wohle panel is squashed on its buttons the seek button is main 1 and wont let anything work besides it take out the button release the screws all the way jiggle it a little bit, or even take a look inside that nothing is broke or loose tightened the screws but not hard(soo it wont happen again) good luck
SOURCE: I have a jvc kd-r311 radio in my car which has
If you have a multimeter, try checking the speakers and speaker wires for shorts and/or grounds. Make sure your speaker wire has no bares spots. If the speakers and speaker wires all check out good, you may have a bad internal output ic.
SOURCE: hi suddenly my car radio
There should be a button labeled ATT that is your mute button. Att is short for attenuation.
SOURCE: 1990 bmw radio unlock code
I have a Ke-83xbm. there should have been a serial number not on the same tag as the fcc#. Mine was a # on hte very back end of the radio by itself.
