Question about Hoover 24 in. HD72M Free-standing Dishwasher
Hoover 24 in. HD72M
Machine makes a noise as if it is starting to fill but the dial does not move from the number 3 position (or any other position).
4 Suggested Answers
SOURCE:
SOURCE: hoover quattro system 1100 ab power jet as 110
I had the same problem when i got my machine, if you slide out the powder and softener tray just behind the face of it on the right hand side you will see a white plastic tab about 2 inchs wide! That plastic tab slides out and has all the programme settings on it!
Posted on Jul 25, 2009
  • 884 Answers
SOURCE: Hoover 1200
Remove all excess water by draining to a bowl. Clear filter and drain pump blade and all will be fine.
Posted on Jul 15, 2012
BADBOYJAY
  • 274 Answers
SOURCE: hoover htc 243 not turning on
you main bord is faulty that will cost more then a second hand machine ok
Posted on Oct 17, 2012
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
Machine filling up with water but not starting hoover 750la
Did you try with temperature setting to the minimum?
Normally the machine needs to heat the water at programmed temperature before starts, it fails to do it because some issue on the heating system it would not start....
Nov 30, 2015 | Hoover Washing Machines
How to set date on it?
Thank you for contacting FixYa.
Pull the crown out to position No. 3, turn clockwise to go to hour and minutes hands; the small dial showing days of the week will move, and the 24-hour dial will also move correspondingly.To set the date, pull the crown out to position No. 2 and turn clockwise until you have set the desired date; push the crown back to position No. 1.
Multifunction watch:Pull the crown out to position No. 3, turn clockwise to go to hour and minutes hands; the small dial showing days of the week will move, and the 24-hour dial will also move correspondingly.To set the date, pull the crown out to position No. 2 and turn clockwise until you have set the desired date; push the crown back to position No. 1.
Aug 25, 2010 | Fossil BQ9177 Wrist Watch
Hoover 700LB - fills as per normal and washes but cycle knob does not move, click or progress towards the next cycle therefore washes forever...timer perhaps and if so is it worth fixing?
Hi just read your posting.Does the timer move at all from the original position that you started it from?If it does not move at all then you need a new or reconditioned timer.If it does move but stops at a specific spot,What position does it stop at?Are you in Australia? If so I can give you the contacts on where to purchase a timer.Please reply and I can guide you on how to get the correct timer number for your machine.Looking forward to your reply.
Jul 24, 2010 | Hoover HTC243 Top Load Washer
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
Indesit wia111 stuck on spin cycle
OK - Try this:-
1. Position the dial on number 0 (off) and then unplug from the wall.
2. After at least 24 hours plug back in - hopefully the thing should have reset.
3. This is really important. Select a wool wash program (No 9) and allow it to complete the entire wash until the door lock light starts flashing to say it's finished.
4. Turn the dial back round to position 0 and all LEDs should go out.
That's it - The control board is reset and all should be well
In order to prevent re-occurance, try to avoid canceling programs mid-cycle. It's also a good idea to switch the dial to number 0 and switch the machine off at the wall when not in use if at all possible.
Please let me know if this works for you :)
Jul 30, 2008 | Washing Machines
Washing machine problem
I have a performa 1100. No 4 is the 40 degree is the normal cottons cycle which is the one I use. Tip- only fill the drum 3/4 full otherwise it struggles to drain and spin- I know!
Jan 21, 2008 | Hoover PE235 Front Load Washer
INDESIT WIA 101
Press "end of cycle" for 3 seconds, & tell me what happened.
You will rate me also.
Jan 19, 2008 | Indesit WA 115 Front Load Washer
Hoover 24 in. HD72M Free-standing Dishwasher Logo
Top Hoover Dishwashers Experts
Philip Postlethwaite
Vitally Alcher
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
