Question about Panasonic PV-M1349 Combo
Picture too dark
The picture is too dark. Is there a "brightness" adjustment or is the set just getting old? The only possibilities I see are on the back (Tech adjustments) "Screen" & "Focus". What does "Screen" do? Thanks
  • Barry G2044 Aug 06, 2007
    I don't have the remote or the owner's manual.
    Is there a way of doing functions w/the front controls on the unit?
    If not, I guess I need to track down a remote.
    Thanks,
    Barry
If u hav a remot for it it shoud hav a screen ajust. ther is a pictur of a sun press it 2 times. if that dosnt work press it agn
Posted on Aug 06, 2007
SOURCE:
How do I lighten a dark picture
Hi Richard,
Please try reducing the contrast a little and increasing the brightness till the dark shots are clear. Please also check the back light setting. It should not be too low.This should make all the dark scenes clearly visible if it only a setting problem. In case the overall brightness has reduced, please consult a local TV Tech.
Aug 11, 2015 | Sharp Aquos Televison & Video
Why is sony bravia dark screen
If your TV seems to be darker than you think it should be, it is possible that the problem is with the light sensor. The light sensor will automatically adjust the picture brightness based on the ambient light that is in the room, (i.e. if the room is bright the picture will also be bright, if it is dark the picture will also be dark).
To turn this feature off go to Settings > General Setup > Light Sensor.
Feb 27, 2015 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My tv screen is to dark how do I lighten the picture
If your TV has already fully adjusted in brightness set up?, and there will be no good picture results?...try to adjust the "SCREEN-Screw" at the flyback slowly. If the picture still dark'?. the picture tube has need to rejuvenate.
Oct 24, 2014 | JVC Televison & Video
Picture Dark with brightness at maximum
No lamp as set has 3 picture tubes. You might be able to find the access on the net to the tech mode where sub bright etc can be adjusted.
Did problem happen instantly or gradually over a period of time?
Aug 30, 2012 | Panasonic PT-47WX42 47" Rear Projection...
Zenith pvr6069 rk is out of focus for letters and picture not very bright
First this set should have a production date on the rear of around 1995--fairly old.
If letters outlined in red etc--a convergence problem--either adjustment with remote (in menu) or a circuit problem in same area.
If picture dull and darker--locate the 3 large lens inside from the rear and wipe them clean--they are the light source for the sets picture and if dirty will cause a dark dull picture.
Let me know if questions.
SD TECH
Apr 22, 2012 | Televison & Video
Tv picture is too dark- worked with contrast and
This sounds like low screen voltage(A1)try adjusting the a1 voltage bottom control on flyback transformer if you have a voltmeter, voltage on crt base possible market screen or A1 shoud be beteen 350/500 volts when making adjustment remember to take into account current taken by meter If voaltage will not adjust flyback transformer will have to replaced
Mar 06, 2010 | Televison & Video
How to adjust brightness
You don't say anything about the brand, but most have a menu or setup button on the remote (and TV) which give an on-screen display of functions available. You should see one for picture adjustments. Perhaps the projection bulb is getting old and dim. This is another possibility.
Oct 14, 2009 | Televison & Video
Picture get dark than light
On your remote control, press the huge circle, which should be settings or menu, there, go on brightness, put it up to max if u want bright, and low if u don't .If the problem still happens, ask customer service to help, or return it!!
Feb 19, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Screen is too dark
with a flashlight at the back of the set often times there is an adjustment you can make WITHOUT having to open the set!!!
look for a little hole in the back of the plastic cabinet labeled SCREEN then with a flat screwdriver holding only the plastic handle, insert it into the hole and SLOWLY rotate until the screen brightens up until it is watchable.
This is compensating for age in the picture tube. you may get a few day or a few more years! of a much better picture.
If you start seeing some thin lines on the screen then back off you have gone too far. Do this adjustment with the brightness and contrast controls on the menu turned up all the way.
it is also safe to play with the focus adjustment right next to the screen if thing seem a little blurry. you will need two people one to watch from a distance for best picture.
Feb 10, 2009 | GE 31GT660 TV
Panasonic PV-M1349 Combo Logo
219 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
