Question about Car Audio & Video
FUSION POWER PLANT 4 CHANNEL AMPLIFIER fp4-500x
2 Suggested Answers
etirbynnor
  • 655 Answers
SOURCE: my fusion power plant fp1404 is in status mode
Hello carlosvandan,
According to the Fusion troubleshooting guide, there are three possible conditions that would result in the amp not working, but the status LED on:
1) Fuse on the amplifier blown - replace fuse with correct type and amperage.
2) Amplifier too hot - move amplifier to vented area - turn head unit down.
3) Speaker wires shorted - check that there are no speaker wires shorted to another wire or to the vehicle chassis.
Hope this helps.
Posted on Apr 29, 2009
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
http://www.audiobahn.com/index.php/help/tech-support/manuals/category/1-amplifiers
Feb 26, 2014 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Is a Adcom GFA-7500 5 channel power amplifier bridgable?
no this AMP is not bridgable to get more power out of this amp you need 4 ohm speakers.
Power rating
1 - 150 watts into 8 ohm speakers
1 - 225 watts into 4 ohm speakers
Feb 23, 2011 | Adcom GFA-7500 5-Channel Amplifier
Can i connect a subwoffer and 2 6 inch 3way speakers to one 2 channel amplifier?.
No, it wouldn't sound the same, because your subwoofer speaker, works and sound's differently from your 3way speakers, and 3 way speaker's mostly, the wattage are lower than the subwoofer in this way you'll just blow-up your 3way speakers.
Jul 24, 2010 | Fusion REAM45020 Two Channel Car Amplifier
I mixed up connections of battery pole with ammplifier pole
check the fuse protection of your amplifier then replace it if blew up..but if still blow again some parts in you amplifier was damaged...like choke filter coil in DC section of your amplifier...look for elec..tech..to repair your amplifier.
May 25, 2010 | Fusion REAM45020 Two Channel Car Amplifier
Fusion amp soild bold red when the radio comes on
The amplifier is in protection mode.
3 reasons for this...
  1. Improper Load/overheat - wrong impedence voicecoils or wired improperly below rated impedence.
  2. Grounded Power - speaker wires touching, power wire touching ground,
  3. Internal component failure.
if the amplifier will still not go out of protect mode after removing the speakers and jumpering the remote wire to the + terminal - your amplifier needs professional repair.
Thanks for using FixYa - a good rating is appreciated for taking the time to answer your FREE question.
Jul 08, 2009 | Fusion Digital designs EN-AM6004 Car Amp
What amplifier should I use for 2 650W Subs?
HI DUDE .. I JUST GIVE suggestions Boss Car Audio D5504 "Diablo Series" 4-Channel Car Amplifier 2200 Watts ITS REALY GOOD FOR SOUND SYSTEM DUDEaaf1faf.jpg
Jun 10, 2009 | Pioneer GM-6300F Car Audio Amplifier
My fusion power plant fp1404 is in status mode why?
Hello carlosvandan,
Hope this helps.
Apr 29, 2009 | Fusion Car Audio & Video
Connecting 4 bass speakers to one amp?
If you have a 4 channel amp and 4 speakers and each speaker is connected to each of the 4 channels you are just fine.
A stereo amplifier has 2 channels, typically labeled left and right and each channel has an amplifier. A 4 channel amplifier has 4 amplifiers. With one speaker on each channel, there is one speaker on each amplifier. Audio amps are referred to as amps or amplifiers, although if they have more than one channel it would be more correct to call them something like 'multi-channel amplifier' or 'multi amplifier speaker driver'. Semantics.
May 25, 2008 | Tomtom GO 700 GPS NAVIGATION BRAND ONLY...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
