Question about Home
Problems with Villeroy and Boch Subway compact wall hung toilet and TECE in wall cistern
I have just fitted a villeroy and boch Subway compact wall mounter toilet to my TECE inwall cistern unit. The toilet fits well but move on the frame so does not feel securely fitted and feels like it will buckle the plaster is the toilet compatable with the cistern and any suggestions as to what might be wrong and how to fix it thanks B
3 Suggested Answers
olddewsons
  • 38 Answers
SOURCE: Villeroy Boch subway toilet cistern filling up to much
On this model am not sure if it come apart. But if you have a air compressure try and blow though it. when you have it off toilet. sounds like its dirt caught in it.
hope this helped. :)
Posted on Jul 07, 2009
miket756
  • 2702 Answers
SOURCE: We have a v illeroy and bch cistern that cracked
yes i can,,,he done the scews up to tight that hold then down and the move ment in them is cracking the screw holes out, undo the screws a little that hold them down and maybe put in some rubber washers as well,,,you only sit on them, its not a jig your doing
so they realy dont need to be done down tight only just to hold them thats all,
Posted on Jan 12, 2010
Tank Cover
online by asking same question on web.
Mar 31, 2014 | Villeroy & Boch Villeroy-Boch Colani...
Villeroy and boch toilet parts
attach 2X4s behind it to ensure its stable. I had same problem but used that wood to reinforce it (covered with hardy board & paint) and reattached it and wall is very strong and toilet does not move.
Apr 27, 2013 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
Villeroy & Boch Sunberry close coupled pan and Subway cistern newly installed at the end of July 2010. When flushed the internal mechanism does not always drop down to stop the inlet water....
Your chain is probably metal that snags under the flap (verify by taking top off tank and looking) and you should switch to a plastic chain.
Easy just replace the flap that stops the water after handle is down and toilet flushes and also replace the chain that connects from handle to rubber flap. New chain should be plastic one so it can be reattached and problem is fixed. Should cost less then 5 bucks from Home Depot or Lowes. They can happily step you through the process. I should take about 2 minutes to install ...if that.
Remember to remove excess links of plastic chain with a pair of scissors. Its doesn't require a rocket scientist.
Oct 06, 2010 | Villeroy & Boch 6610 11 Subway...
Hi i am looking for Villeroy & Boch seat product no: (9955 S1 01). Kindly, provide me Quotation
V & B US customer service number used to be 877-505-5350 it has been a while since I used it, but they were very helpful when I did. Hope this helps.
May 11, 2010 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
My Villeroy and boch toilet's water level inside the toilet is always low. I was seeing if there was a way to increase the level inside the toilet, not the tank.
V & B toll free number was 877-505-5350. I hane only worked on one in 25 years and they were very helpful. Hope this gets you in the right direction.
Feb 09, 2010 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
Jan 12, 2010 | Villeroy & Boch 6610 11 Subway...
How can I replace toilet seat for the Subway model? It does not seem accessible without taking the toliet down
There are little toggle bolts hidden at the back underneath the seat. The location and the image is shown in this PDF:
http://www.villeroy-boch.com/fileadmin/picdb/produkte/bad/daten/XX/9955Q1.PDF
It's difficult to describe how to disconnect them but pretty easy to figure out just fiddling with them once you find them.
Good luck.
Aug 02, 2009 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
Jul 07, 2009 | Villeroy & Boch 6610 11 Subway...
My V and B toilet suddenly stopped flushing today, what's the problem?
It won't drain? Is the tank draining? Is the water turned off? Or is it just plugged up?
Jun 19, 2009 | Villeroy & Boch 6610 11 Subway...
Home Logo
48 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
