Question about Reptile
Cookson controls RS-1-WL16
I was wondering how to know where each wire goes when wiring up the thermostat
There should be a wiring diagram on the inside of the cover. It is imperative though that you get the wiring done by a qualified electrician.
The thermostat has a single pole changeover contact and two separate terminals that go to each end of a 240V neon pilot light which you can wire up in any configuration independly of the switch contacts.
Contact us at Cookson Controls in Adelaide if you have any more questions.
Posted on May 23, 2013
I upgraded my Jandy RS controller to run Jandy epumps and installed a new Pentair Mastertemp 400HD heater. Prior to connecting the pool heater thermostat all worked perfect. all instructions stated to...
bad info firemans switch is continuity only if hooked up to firemans switch run new wire from each end of firemans switch to pins 1 and 2 of long plug along top of PCB board make sure to read inside schematic for dip switch positions firemans switch to control heater on and off you will have to turn heater all the way up max setting for temp
Jan 16, 2015 | Jandy AquaLink RS OneTouch Wired White...
Multiple heaters and thermostats on 1 breakere
Mains wiring is dangerous and can kill you if you do not know what you are doing. For your safety I suggest you get a electrician to wire up your heaters.
Nov 29, 2012 | Heating & Cooling
My aprilia rs 125 battery keeps going flat i charge the battery up and last round about 1 mile then gose flat my engine then cuts out i leave for 10mins then it gose again im thinking the magneto as ive...
Hi, Swiftb152 and the usual suspects are:
1. Voltage regulator/rectifier not grounded.
2. Engine ground wire loose or broken.
3. Faulty voltage regulator/rectifier module.
4. Loose or broken wires in charging circuit.
5. Faulty stator and/or rotor.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
DOWNLOAD 1999 Aprilia Rs 125
Mar 16, 2011 | 1999 Aprilia RS 125 Extrema
I have ran my 12-2 wire from breaker box to thermostat from the thermastat i ran a 12-2 wire to first heat. question 1) do i run another 12-2 wire from heat 1 to the next heater i want on this thermostat?...
There are so many questions. WHAT IS THE MODEL number of the unit that you are wiring The thermostat and the source voltage are two different things. What voltage are you wiring this to?
Apr 30, 2017 | Marley Electric Hydronic Baseboard Heater,...
Yamaha RS 100 wiring diagram
Hi, Randy for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha Motorcycle Wiring Diagrams
Yamaha RS 100 wiring diagram Google Search
Yamaha RX 100 Workshop Manual
Yamaha Rs100 1975 Usa parts lists
Yamaha RS 100 Manuals Support and Troubleshooting
Dec 10, 2009 | Yamaha Motorcycles
I have a singer wall thermostat. I am replacing
You have to know what the wires go to.
(1) wire will come from the transformer and it connects to the r/c and r/h
(1) wire will go to the gas manifold and goes to the g
(1) wire goes to A/C and connects to y/o
(1) wires goes to the fan
Oct 21, 2009 | Heating & Cooling
I need wiring manual for goodman mini split.
outside unit L1 and L2 are load (input 240vac)
then you have control voltage, usually yellow and blue (24vac) this connects to some 18/2 thermostat wire which goes inside as white and red.
note: this unit may only need 24v control which is 2 wires from the inside unit and also 3 wires 2 hot 1 ground for line voltage.
STANDARD WIRING
on the inside unit you have green, white, blue and red control wires.
on your thermostat you have white, red, yellow and green
you run the wire from the outside unit to the inside unit. then run a 18/4 wire to the thermostat if wired and join the following wires.
inside unit thermostat outside unit
green------------------------green
white-------------------------white
red----------------------------red
blue-------------------------------------------------------blue
yellow--------------------yellow
Oct 08, 2009 | Heating & Cooling
Thermostat wiring
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Thermostat wire color codes explained.
Please note. Not all installers use the proper color codes when they install or replace equipment. It may be necessary go go to the furnace or outdoor unit to verify what wires are for what purpose. Also be sure there are no splices in the wire that could change the wire colors between components.
  • R (red) or Rh (Red heat) 24 volts from equipment.
  • Rc (Red cooling) 24 volts from transformer in cooling equipment.
Note: If only furnace has a transformer and cooling equipment does not jumper Rc and Rh.
  • W (White) sends 24 volts to furnace control to start the heating cycle.
  • W2 (no standardized wire color, usually whatever wire color is available) controls second stage heat.
Note: W2 is most often used for heat pumps to control what is called emegency heat or Auxillary heat, and most often will use the white wire.
  • Y (yellow) often (blue) is used, controls cooling unit (outdoor condensing unit) also is used for heat pump heat.
  • Y2 (no standardized wire color, usually whatever wire color is available) controls second stage cooling.
  • G (Green) controls the fan "on" operation of the furnace/air handler. Also often is used to start the blower for many electric furnaces.
  • C (common) most often brown but can also be black or other color available to installer.
  • O (orange) Energizes heat pump reversing valve for cooling (Trane and most other brands).
  • B (Blue) Energizes heat pump reversing valve for heating (Rheem, Ruud and Weatherking).
Jun 02, 2009 | Carrier Heating & Cooling
Trying to hardwire my mini fridge in my popup. I have a blue and a gray wire coming from the condenser and a black and a white wire coming from the thermostat control, and a white and a black wire coming...
ok the black wire from the powersource goes to the (-)negative terminal in the converter, the white wire goes to the (+) positive.
From the converter the white wire goes to the white wire on the termostat.
the thermostat black wire goes to the grey wire on the condenser
the blue wire on the condenser goes to the black wire on the Conveter.
Mar 27, 2009 | Refrigerators
Wiring of gas central heating
you have a link pin on 3-4 or 1-5 or seperate 2 pin connector,thats were the stat goes,any way round with wires
Mar 05, 2009 | Honeywell Programmable Thermostat Heater
Open Questions:
Reptile Logo
551 people viewed this question
Top Reptile Experts
windryder
Level 1 Expert
john h
Ned Halaweh
Ned Halaweh
Are you a Reptile Expert? Answer questions, earn points and help others
