Question about DIRECTED Smart Start Module DSM100
Request could not be authenticated
When I tried to access my remote started the message said. Your request could not be authenticated. If this condition persists, go to mysmartstart.com for help (5)
What do I do to fix it
Posted on Jul 22, 2014
When trying to download zorin os, i always get message: access denied,access control configuration prevents your request being allowed
Does this happen only on ONE computer,
e.g., a computer at your school/college/university,
or one supplied by your employer?
Try a different computer.
Feb 26, 2015 | Computers & Internet
Need to find password on facebook \
You will also need the primary email address for the account. Submit a request for a password reset. A message authenticating the request will be sent to that address. Follow the directions to authentic the request and change the password to something you can remember or record with a secure password organizer.
Feb 11, 2014 | Computers & Internet
Hi. I'm having Nokia C7 mobile.When i request for GPRS(BSNL Postpaid) setting, the settings sms comes to my inbox as "Trusted server settigns received but not saved. Message could not be authenticated...
Go to Access Points under Settings and manually add a new access point. The settings for your service provider are given below: Connection Name: BSNL Internet Data Bearer: Packet Data Access point name: bsnlnet User name: Leave blank.
Thats all. Save the access point and use it with your applications.
Mar 15, 2011 | Nokia E75 Cell Phone
How do I secure?
WIRELESS To configure the Router as a wireless access point for wireless clients (either stationary or roaming), all you need to do is define the radio channel, the Service Set identifier (SSID), and security options.ADVANCED SETUP 47 Channel and SSID You must specify a common radio channel and SSID (Service Set ID) to be used by the Router and all of your wireless clients. Be sure you configure all of your clients to the same values. SSID: The Service Set ID. This should be set to the same value as the other wireless devices in your network. SSID Broadcast: Broadcasting the SSID on the wireless network for easy connection with client PCs. For security reasons, you should disable SSID broadcast. (Default: Enable) Note: The SSID is case sensitive and can consist of up to 32 alphanumeric characters. Wireless Mode: Set the communication mode for the Router. Default: Mixed (11b+11g)Configuring the Wireless Barricade g Router 48 Transmission Rate: Set the rate of data transmitted from the Router. The lower the data rate, the longer the transmission distance. (Default: Fully Automatic.) Channel: The radio channel through which the Router communicates with PCs in its BSS. (Default: 6) Note: The available channel settings are limited by local regulations. g Nitro: In a crowded 2.4 MHz frequency, the connection speed is much lower than the promised 54 Mbps. The g Nitro implemented by Intersil's Prism Nitro technology dramatically enhances your wireless network speeds. It provides up to 50% more throughput in 11g only environment, and improves network throughput by 3 times in mixed mode.ADVANCED SETUP 49 Security If you are transmitting sensitive data across radio channels, you should enable wireless security. Configuring the Wireless Barricade g Router 50 WEP Wired Equivalent Privacy (WEP) encryption requires you to use the same set of encryption/decryption keys for the Router and all of your wireless clients. WEP mode: You can choose disabled, 64-bit or 128-bit encryption. Key Provisioning: Select a key type of static key or dynamic key. Static WEP Key Setting You may manually enter the keys or automatically generate encryption keys. To manually configure the keys, enter 10 digits for each 64-bit key, or enter 26 digits for the single 128-bit key. (A hexadecimal digit is a number or letter in the range 0-9 or A-F.) For automatic 64-bit security, check the box of Passphrase, enter a passphrase and click SAVE SETTINGS. ADVANCED SETUP 51 Four keys will be generated. Choose a key ID (1-4) from the drop-down list or accept the default key. If you use encryption, configure the same keys used for the Router on each of your wireless clients. Note that Wired Equivalent Privacy (WEP) protects data transmitted between wireless nodes, but does not protect any transmissions over your wired network or over the Internet. WPA Wi-Fi Protected Access (WPA) combines Temporal Key Integrity Protocol (TKIP) and 802.1x mechanisms. It provides dynamic key encryption and 802.1x authentication service. With TKIP, WPA uses 48-bit initialization vectors, calculates an 8-byte message integrity code, and generates an encryption key periodically. For authentication, it allows you to use 802.1x authentication for an environment with a RADIUS server installed on your network. Selecting the Pre-shared Key enables WPA to use the pre-shared key in a SOHO network.Configuring the Wireless Barricade g Router 52 Field Default Parameter Description Cypher suite TKIP One of the security mechanism used by WPA for frame body and CRC frame encryption Authentication 802.1X Select the authentication mode. • 802.1X: It is for an enterprise network with a RADIUS server installed. • Pre-shared Key: It is for a SOHO network without any authentication server installed. Pre-shared key type Passphrase (8~63 characters) Select the key type as in pass-phrase or in 64-Hex characters Pre-shared Key none Specify in pass-phrase style or in 64-Hex characters. Group Key Re_Keying Disable The period of renewing broadcast/ multicast keyADVANCED SETUP 53 802.1X Management access will be checked against the authentication database stored on the Router. If an authentication RADIUS server is used, you must specify the secret key of the Message-Authenticator attribute, i.e., Message Digest-5 (MD5), and the corresponding parameters in the RADIUS Server Parameters field for the remote authentication protocol.Configuring the Wireless Barricade g Router 54 • General Parameters • RADIUS Server Parameters Field Default Parameter Description Enable 802.1X Yes Starts using 802.1x security control. Session Idle Timeout 300 seconds Defines a maximum period of time for which the connection is maintained during inactivity. Re-Authentication Period 3600 seconds Defines a maximum period of time for which the RADIUS server will dynamically re-assign a session key to a connected client station. Quiet Period 60 seconds Defines a maximum period of time for which the Router will wait between failed authentications. Server Type RADIUS Selects the authentication server type. Field Defaults Description Server IP 192.168.1.1 The IP address of the RADIUS server. Server Port 1812 UDP port is used for RADIUS authentication messages. Secret Key none Defines a text string on both the RADIUS client and server to secure RADIUS traffic. The RADIUS server requires MD5 Message-Authenticator attribute for all access request messages. The 802.1x authentication scheme is supported by using the Extensible Authentication Protocol (EAP) over the RADIUS server. NAS-ID none Defines the request identifier of the Network Access Server
Source: http://www.smc.com/files/AK/2804WBRP-G_MN.pdf
Please leave feedback for this answer, thanks.
Mar 10, 2011 | SMC Barricade g SMC2804WBRP-G Wireless...
What is a wep key?
In Shared Key authentication, the WEP key is used for authentication. A four-way challenge-response handshake is used:
  1. The client station sends an authentication request to the Access Point.
  2. The Access Point sends back a clear-text challenge.
  3. The client has to encrypt the challenge text using the configured WEP key, and send it back in another authentication request.
  4. The Access Point decrypts the material, and compares it with the clear-text it had sent. Depending on the success of this comparison, the Access Point sends back a positive or negative response.
for details kindly visit the link
kindly rate this solution
thanks and regards
Feb 14, 2011 | Computers & Internet
How to unblock friend requests & messages
my friend request block 30 day plz unblock
Jan 30, 2011 | Facebook Social Network
Error 401
SYMPTOMS
Internet Explorer may not post data from a POST request and you may receive a "Page cannot be displayed" error message. This problem may occur if the following conditions exist:
  • You perform the POST request on a new connection with a target page that requires authentication.
  • The server immediately replies to the POST request with a "401 Access Denied" response and closes the connection.
CAUSE
The server closes the connection without reading the whole request body, and the server resets the connection when it receives frames that involve the entity body for the POST request. Because the connection is reset, Internet Explorer (Wininet.dll) cannot read the "401 Access Denied" response and process it.
RESOLUTION
A supported hotfix is available from Microsoft. However, this hotfix is intended to correct only the problem that is described in this article. Apply this hotfix only to systems that are experiencing this specific problem. This hotfix might receive additional testing. Therefore, if you are not severely affected by this problem, we recommend that you wait for the next software update that contains this hotfix.
If the hotfix is available for download, there is a "Hotfix download available" section at the top of this Knowledge Base article. If this section does not appear, contact Microsoft Customer Service and Support to obtain the hotfix.
Note If additional issues occur or if any troubleshooting is required, you might have to create a separate service request. The usual support costs will apply to additional support questions and issues that do not qualify for this specific hotfix. For a complete list of Microsoft Customer Service and Support telephone numbers or to create a separate service request, visit the following Microsoft Web site:
http://support.microsoft.com/contactus/?ws=support (http://support.microsoft.com/contactus/?ws=support) Note The "Hotfix download available" form displays the languages for which the hotfix is available. If you do not see your language, it is because a hotfix is not available for that language. The English version of this fix has the file attributes (or later) that are listed in the following table. The dates and times for these files are listed in coordinated universal time (UTC). When you view the file information, it is converted to local time. To find the difference between UTC and local time, use the Time Zone tab in the Date and Time tool in Control Panel.
Date Time Version Size File name ------------------------------------------------------- 27-May-2003 14:57 6.0.2800.1204 586,752 Wininet.dll
Jan 24, 2011 | Computers & Internet
Every time i go 2 youtube it says 400 bad request.
CauseThe 400 Bad Request error is an HTTP status code that means that the request you sent to the website server (i.e. a request to load a web page) was somehow malformed therefore the server was unable to understand or process the request. Resolution
  1. Check for errors in the URL. The most common reason for a 400 Bad Request error is because the URL was typed wrong or the link that was clicked on points to a URL with some kind of mistake in it.
  2. Though it's rare, the 400 Bad Request error could be an issue with the web site's server that you are trying to access. You may want to attempt to contact the webmaster or another site contact and inform them of the error message. The webmaster of most Internet sites can be reached via email at webmaster@website.com, replacing website.com with the actual website name.
Sep 01, 2009 | YouTube Videos
DIRECTED Smart Start Module  DSM100 Logo
134 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
