Model# GLSC2WHW1SC I am looking for a manual to see how to clean it to get the bacteria
Tip
How to clean dog toys
Different types of dog toys require different cleaning due to their materials and the type of germs that they attract.
Plastic and rubber toys- these are the easiest type of dog toys to clean. They can be either hand washed with soap and water or in the dishwasher. If you do choose to clean them in the dishwasher, make sure it is without a detergent.
Rope toys- these toys attract lots of bacteria. In order to clean them, it is advised to put them in a microwave for a full minute. Another way to clean them is just like with plastic and rubber toys, to put them in a dishwasher without a detergent. These two methods will kill the bacteria.
Stuffed animals- these toys attract lots of bacteria as well. In order to clean them, put them in the washing machine. In most cases, they will come out fresh and clean. If the stuffed animal is made poorly, then it will not survive the washing machine.
on Aug 26, 2012 | Dogs
Bacteria in water lines
Water comes straight from your supply via a clear hose then through a filter that should stop all bacteria & germs, I would check that first, might need changing.
Nov 24, 2013 | Samsung Refrigerators
White vinegar can be used on the outside of a water bed mattress to clean it, can it also be used inside the mattress to keep it bacteria free?
I watched a magic school bus cartoon once where they shrank down and went into a pickle jar. The show mentioned that the friendly bacteria was fighting off the harmful bacteria. Hence it is never bacteria free. I don't see any harm of vinegar being inside except that it is an acid and acids slowly dissolve anything.
Nov 09, 2013 | Plumbing
2when I open refrigerator door there is a terrible odor from the refrigerator. Have removed anything in the refrigerator that could possibly be smelling. got any ideas?
Have you removed the bins and cleaned under them. Sometimes the overflows and drips accumulate there.
It the refrigerator is clean, then baking soda usually helps with absorbing the odor.
But if you still have odor being produced and the unit is clean, you need to look further. If it is a chemical smell you might want to roll the unit out and check to make sure that there isn't a creamy looking liquid on the floor, which COULD be freon.
But the most likely item is that you have some bacteria growing in the drain line that is producing the odor. Suggest you mix a 50/50 mix of bleach and water and pour that down the drain to kill the bacteria. Do that several times over a day or two and see if the odor goes away.
Jun 12, 2011 | Kenmore 53642 / 53644 Side by Side...
I have a GE Dehumidifier Model AHW50LMG1. Am trying to find out how to clean the container that the water is collected into. After use the container contains residue from collected water that I am...
Vinegar is the proper way to clean all parts of a humidifier. It stops scale and kills bacteria and fungus. It can be processed through the heating element without any adverse effects.
Thank you,
James.
-------Please vote 4 thumbs up 4 me!!!----------
Apr 24, 2010 | GE Dehumidifiers
I have the same model HDC3655. My problem is
Mould is a bacteria
Clean out the unit and wash the area with a strong soda solution.
Also wash the bottles which will carry the same bacteria
Dry throughly
Dec 31, 2009 | Franklin Industries FBC360D Beverage...
The screen seems dark and blurry
take off the front panel carefully, usually 2 screws around the controls. Next, stick your head in and look at the red green and blue tubes. see if they are dirty? if, not look further into the tube using aflaslight and see if there is a white pasty looking substance inside. IF so, you need to clean as you have bacteria growing in the cooling fluid. A big job and you need the gaskets, can order from Mitsubishi tech support..good luck be careful.
Mar 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Cleaning filter
Link to Manual online:
http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
I don't think you would have to clean it weekly, for me every other week or once a month works, but our water is pretty low on minerals and bacteria.
Feb 26, 2009 | Crane Frog EE-3191 1 Gallon Humidifier
White looks blue
usually there's a HUE setting for color problems. try to go and play with the HUE whih is usually beside the contrast, brightness....etc.
if that didnt work, then there's a problem with the deflection coils focusing, either from shipping or a hard hit. if its still under warranty send it back for repair.
let me know if that helped, good luck :)
Jan 05, 2009 | Philips Magnavox 51MP392H Rear Projection...
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
