Question about Pitco Frialator 35CD Deep Fryer
Friar heats up to correct temp but doesn't maintain
After friar reaches desired temp app.350 degrees and turns off the burners will not relite, in another words it doesn't cyle on and off or maintain the temp. Turn it off and let it cool off and it will heat up and repeat as above.
    Sergeant:
    Champion:
  • 234 Answers
The first thing I would check is the hi limit.If that not out then I would try to a temp. gauge that will read above 350 degrees.maybe the thermostats is not right. Reading to low for the temp.
Posted on Mar 14, 2009
I need plum plant which has a very sweet dark in colour having very small seed.
Friar black plum has dark skin, small seed, and is very sweet. Flesh of the plum is amber.
Varieties of Sweet Black Plums
Friar Plum Dave Wilson Nursery
Sep 29, 2017 | Garden
Pilot and burner light then gas shut off model 7900
How many degrees before it reaches desired temp, does it shut off? A thermostat is designed to shut the furnace off a couple/ few degrees before it reaches set temp. It has what is called a heat anticipater, which shuts the burner down, and lets the blower use the remaining heat from the heat exchanger to bring it up to desired temp making it more efficient. If it is more than a few degrees, replace the thermostat. You can jump out the red and white wires to confirm the faulty thermostat. If by doing this, the furnace never shuts down, until you separate the red and white wires. That confirms a faulty thermostat. Hope this helps someone.
Oct 06, 2014 | Coleman Propane Forced Air Heater...
Flame goes off when temp. reaches 250 degrees, use to stay on 350 degrees without problems an them started acting up and won't reach that temp any more, disconnect the pilot automaticly
Hi limit device trips prematurely (should only trip when oil temp reaches 450F). Check if the hi limit sensing bulb (located inside the fryer tank, between fire tubes) is not touching the fire tube because if it does, it will sense the heat from burner flame which is much higher than oil temp.
Feb 21, 2011 | Pitco Frialator 45C Deep Fryer
Should the burners go off and on
yes this is totsly normal
they are really not burners, they are elements, and you dont really cook from the heat of the burner, on this design, you actually cook from the heat of the glass, so as the glass cools through convection, the element will cycle, on and off to ensure the glass maintains a temp +- 25 degrees to the set temp
hope this helps
Oct 29, 2009 | Jenn-Air JES8850 Electric Kitchen Range
My oven heats up, but then does not maintain the temp.
If it has a pilot then I would say the thermal couple is bad. If it has a glow type ignitor then the ignitor is bad.
Sep 02, 2009 | Whirlpool GS460 Gas Kitchen Range
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
Temp stuck on 100 degrees
try unplugging the range for at least 30 minutes
Feb 08, 2009 | Amana ACF3355AS Gas Kitchen Range
Oven temp set at 350. only heated to 310 after 1 hour! Set to 390 before reached 350. What to do?
Use an oven thermometer Try to figure out if by setting it to 390 it will maintain 350 accurately. (A 25 degree change while it cycles is normal. It will probably overshoot before going off and undershoot a little before cycling on.) If so the thermostat has just drifted. Pull off the control know and look usually there is an adjustment on the shaft to change the temp showing on the knob. set it up 50 degrees. If the knob can't be changed just know that you have to adjust yourself. If it won't maintain a steady temp the thermostat is bad and will need to be replaced. The thermostat will be over $100 it may not be worth it. If this is a computer controled unit (pushbutton temp selection) the sensor needs to be replaced. This is a lot cheaper than a thermostat.
Jul 03, 2008 | KitchenAid Kitchen Ranges
GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Sep 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Pitco Frialator 35CD Deep Fryer Logo
158 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Dan Webster
Dan Webster
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
