Question about Dell Vostro 1510 Laptop
Dell vostro blinking 9
Blinking 9 and display are not show
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 63 Answers
If there is no display showing at all you may want to reset the CMOS of your motherboard. to do this try undoing the ram panel from underneath the computer. make sure the computer is turned off and the battery unplugged. remove the ram, turn the computer on and you should hear some beeping. turn the computer back off, replace the ram and then turn it back on again, this should give you video output if the screen isn't faulty
Posted on Apr 27, 2013
babes_ganda0
  • 381 Answers
SOURCE: "[9]" labeled status light blinking and no display
open the case then locate the memory and make a clean all pin connectors of memory using a paper eraser..
Posted on Jul 08, 2009
SOURCE: I have a dell vostro 1520 the number 9 display
flashing" problems in Dell Vostro 1510 Laptop
Posted on Mar 24, 2011
reyjoshua07
  • 1157 Answers
SOURCE: dell vostro 9lock button blinking
Hi sarwankuma5,
The easiest way to fix this problem is to perform a power drain. Please follow the instructions below.
1. Turn off the system completely.
2. Unplug the AC adapter from the power outlet.
3. Remove the battery from the unit.
4. Now, press and hold down the power button for about 15-20 seconds.
5. Put back the battery in and plug the AC adapter.
6. Reboot and observe the system.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 29, 2011
  • 3940 Answers
SOURCE: dell vostro 1510 front panel
http://www.bay-wolf.com/portpostcodes.htm
from what you describe, it may be a faulty motherboard
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Posted on Aug 01, 2011
  • 1542 Answers
SOURCE: my dell laptop - vostro
Hi
some dells you have to press the FN+F2 keys to activate the wireless switch
some have a switch on the left side near the rear and that needs to be activated with the FN = that switch
most wireless switches has a picture of what looks like a mini satalite
so normally press the FN key plus the key with the satalite picture on or beside it
good luck
Posted on Aug 20, 2011
I have a panasonic plasma tc-p50x1 that had the red led blink 9 times
9 times blinks denotes Panel Config. SOS.If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/. Standby LED blinking codes and fault locating procedure to Panasonic Plasma Displays are described in detail.
May 09, 2013 | Sharp LC37SB24U 37 in. LCD TV
Tip
USING THE CLOCK 1. NORMALLY THE LCD CLOCK DISPLAY (6) SHOWS THE HOURS AND TIlE...
USING THE CLOCK
1. NORMALLY THE LCD CLOCK DISPLAY (6) SHOWS THE HOURS AND TIlE MINIJTES.
2. BY PRESSING SET (9) ONCE THE MONTH AND DATE WILL APPEAR.
3. BY PRESSING SET (9) TWICE THE DISPLAY SHOWS THE SECONDS.
4. TO RETURN TO THE NORMAL DISPLAY PRESS SET (9) ONCE.
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
Jun 10, 2011 | Sangean RCR-1 Clock Radio
My 40" toshiba tv nexxtech
Please let me know if this works for you! would love positive feedback! if this doesnt work let me know as well will continue to help
toshiba codes are 0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
an to reprogram it you have to follow these directions if found from an online manual for this model
Turn on the device you wish to program the remote to, point the remote at the device and press the key for that particular device (TV, etc.) on the Nexxtech remote. For TVs combined with a VCR or DVD player, use the "TV" key, and for VCR/DVD combination units, both "VCR" and "DVD" will need to be set up if your particular remote offers both.
  • 2 Locate the code (or possible codes) for your brand and type of device in the list supplied with your remote. Press and hold "P" until the display light blinks twice and then enter the first code. The display light will blink with each digit and blink twice if the code was accepted; repeat using the next code if it was not. Press "Power" once the code was accepted to see if the device responds by shutting off. Repeat the steps for all the codes listed under that brand name.
  • 3 Search for a code if none of the listed codes were accepted or if you do not have the list by pressing the appropriate device key, pressing and holding "P" until the display light blinks twice and pressing "9-9-1." Press "Power" to see if the device responds, and press "CH+" to try more codes if it does not. Press "P" again to lock in the code when successful.
  • 4 Point the remote at a programmed device, press the device key, press and hold "P" until the light blinks twice and enter "9-9-0" to learn the code for that device. Press "1" to see the code for the first digit; count the number of blinks on the display light and write down that number. If the number is 0, the light will not blink at all. Repeat for the next three digits by pressing the number key for that digit (2 through 4).
  • 5 Press "9-9-2" after pressing "P" to reassign a device key if, for example, you have two DVD players and no VCR and want to program the "VCR" setting to the second DVD player. In this example, follow "9-9-2" by pressing "DVD" and then "VCR", and then program in the code for that device.
  • Mar 17, 2011 | Toshiba Televison & Video
    How do you set stations and clock
    1.Select the radio band and tune in a desired radio station you wish to store in the preset memory.
    2 .Press and hold any one of the Preset buttons (1 through 6) for at least 2 seconds until the station frequency on the display blinks.
    3. Press the Preset button into which you wish to store the station while the frequency display is blinking (within 5 seconds). The display stops blinking once the station has been memorized. The display shows the band, preset No. with a triangle (9) and station frequency memorized
    http://vault.alpine-usa.com/products/documents/OM_CDM-7854.PDF is link to full manual
    Mar 03, 2011 | Alpine CDE-7853
    Sony 9 blink problem
    9 blinks shows problem in power supply (G Board) and service manual suggest to check D6116 or D6301 that could be open on G Board.
    Thanks.
    Sep 01, 2009 | Sony KP-57WS520 57" Rear Projection...
    Jul 08, 2009 | Dell Vostro 1510 Laptop
    9 blinks,won't turn ON, but I can make it turn on with diagnostic
    I'm suprised with nine blimks the set will turn on at all. You are in the service menu; be careful, you can render the set totally unusable if you change something. Try unplugging the set for a few minutes and plug back in.
    Mar 30, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
    9 blinks
    D6117- Change switching Regulator on G board you can also do Self-Diagnostic Mode Press display ,5 . vol- ,power. this should turn set on and show other codes telling you what else maybe wrong. TO Remove codes and clear back out Press display,5,vol+,power Now Press 8 and Enter.
    Jan 05, 2009 | Sony KP-46WT520 46" Rear Projection...
    Screen blinking
    flash u r phone with software before flashing change display socket witch is on board u rproblem will solve send me u r rply on yesh.raj77@yahoo.com
    Aug 12, 2007 | Nokia 1600 Cellular Phone
    Dell Vostro 1510 Laptop Logo
    136 people viewed this question
    Alun Cox
