Question about Home Security
Hormann supramatic e
Door opens only half way. how do i reset it?
I have a Hormann 5500 series. The door closes but automatically reopens when it touches the ground.
I do not know, but I guess that a "bad" handling of the machine during a move may have maligned parts.
This is only a guess.
Jun 28, 2017 | Washing Machines
How do i operate the old espressomatic coffee machine
I assume you mean the expresso machine by Supramatic? Give me a correct manufacturer.
Try this link:
Espresso Machines by Supramatic Super Automatic from Schaerer Saeco Jura...
Feb 17, 2015 | Coffee Makers & Espresso Machines
Programming a Hormann HSE2-868 Remote Control
Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 12, 2014 | Televison & Video
Hormann garage door
If the courtesy lights on the motor unit aren't turning on, there may be no power getting to the machine, or there may be a fault in the control board. If the opener is getting mains power, I would suggest calling a Hormann dealer.
Sep 17, 2013 | Building Materials
How do I reset hand held door opener for horman silent drive 5500 series
The instructions for programming are on page 34 of your owners manual. If you do not have the manual you can go here.
http://www.hormann.us/assets/1/Page/SilentDrive_TR10H004D_0710.pdf
May 12, 2012 | Sears Craftsman LiftMaster Chamberlain...
The auto clean was pushed while the door was half open, the lock engaged and will not reset.
If you can open the door since it wasnt fully closed when the lock engaged..open the door,push in and hold the oven light switch, and push the cancel button and the lacth should open
Aug 28, 2011 | Kenmore 95410 Kitchen Range
How do i reset the system that tells me when my door is open in my 1995 jeep grand Cherokee
if its telling you the door is open when its not there is no reset
but what happens on those is the seat belt gets accidently closed in the door and it colapses door door ajar switch it could be any of the four doors.remove the switch from the door jamn and grab the body and pull on the corragsted shat until it extends a half inch or so [ maybe less, been a while]put it back in the hole ,plug it in first then close the door gently that is how they automatically adjust
Mar 20, 2010 | 1995 Jeep Grand Cherokee
RH power sliding door stops half way.
you need to have it reprogramed , usually works perfec after reseting, goodluck.
Aug 02, 2008 | 2004 Dodge Grand Caravan
Home Security Logo
26 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
