Question about Car Audio & Video
1999 Mercury Mystique Sedan With STEREO printed on door speaker grill ? How and where do I find this out?
I have a 1999 Mercury Mystique and am looking to install a new cd/stereo player. It still has the factory radio/tape deck hehe. On the website im using to find the parts I need, it asks if my car has STEREO printed on the door speaker grills or not. I have never heard of this. Can someone help me figure out this? Thanks!
  • Car Audio & ... Master
  • 16,181 Answers
It would be unheard of to not have stereo in modern car. The thing to be careful about is the wire harness. DONT CUT IT!! Get an adapter for the new stereo
Posted on May 06, 2013
3 Suggested Answers
wdwbusiness1
  • 4 Answers
SOURCE: car stereo installation speakers
Yeah, rewire that.
Posted on Aug 19, 2008
geo_tech486
  • 27 Answers
SOURCE: install a Pioneer- 50W x 4 MOSFET CD Deck and 6-1/2" Car Speakers
you someone to do it for you or you want help doin it
Posted on Dec 11, 2008
99 mercury cougar radio wiring diagram
1999 Mercury Cougar Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange/Black
Car Radio Accessory Switched 12v+ Wire: Yellow/Green
Car Radio Ground Wire: Black/Green
Car Stereo Dimmer Wire: White/Green
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): White/Purple
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
1999 Mercury Cougar Car Stereo Wiring Diagram ModifiedLife com
Feb 08, 2017 | Mercury Cougar Cars & Trucks
Do 6x9 speakers fit in a 1999 mercury mystique?
Your car is made to fit 6x8 speakers. 6x9's will fit, but you will need an adapter for them to fit correctly.
Oct 10, 2012 | Car Audio & Video
How to check timing chain wear on 1999 mystique mercury
i go by how much play it has. if it moves to the side more than 3/4 of an inch u should get it tightened or replaced
Apr 19, 2012 | 1999 Mercury Mystique
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
Removing the fuel tank, the plastic clip or clamp that prevents the gas from coming out of the tank broke , what is the name of that part, it is the extention that goes into the fuel tank.1999 mercury...
go to a dealer and ask the parts guy to show you the illustrated parts breakdown of the gas tank on your car. it will be on a screen and he can print it out for you. then you will have the name, the part number and the cost. this is most likely not a parts store item, something you can get from only a ford or mercury dealer or used out of a junk yard.
Nov 23, 2010 | 1999 Mercury Mystique
What size is the alternator belt for a 1999 mercury mystique with an air conditioner
For the 1999 Mercury Mystique with AC.
Belt Dimensions:
For the 2.0L In-Line 4-Cylinder Engine: 83.1 inches.
For the 2.5L V6: 71.5 inches.
May 13, 2010 | 1999 Mercury Mystique
On my 1999 mercury mystique (4 cyl) the interior dome light has a delayed shut off of about 10 seconds or so. Last week the delay has gone to infinity (the dome light just won't go off at all). I had to...
sounds like a bad door switch ,also make sure dimmer switch is not all the way up that truns inside light on, if dimmer is not on then i would say driver door switch is no good. hope this helps.
Oct 25, 2009 | 1999 Mercury Mystique
POwer windows won't work
The drivers side relay is in the door, left of the speaker. I took my whole door apart because the window would go down but not back up. All I would hear is a clicking noise coming form the relay. Do you have the same problem?
Jun 18, 2009 | 1996 Mercury Mystique
Car Audio & Video Logo
87 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
