Question about Electrical Supplies
Motor starter I have wired a star delta starter panel to drive 55kw motor that is driving a pump. The fitter changed an old pump to go repairit and installed a new pump, now the pump is not pumping so the fitter is pointing the starter as a problem. What effect might a starter have on this problem? The starter is pulling 20 Amps on star and 40 Amps on delta
    Problem Solver:
  • 8 Answers
Verify all three legs of the power are on. You could have a single blown fuse that would cause the motor to single phase and not run.
Posted on Aug 24, 2013
5 Suggested Answers
freetek
  • 5568 Answers
SOURCE: high amp start up draw
I don't care what kind of stories Craftsman tells, their numbers don't add up.
One horsepower is ~ = 740 watts of energy.
2.5 hp equates to a steady-state power consumption of  ~1850W and this could be 50% higher during the first second or two after turn-on.  Your 15 Amp circuit is pushed to the limit by that power level; 15 Amps X 120 VAC = 1800W And, motors aren't a breakeven game; part of the power they draw is wasted in heat.
9 amps steady-state would be a power consumption of over 6kw which cannot be right. Either your measurements or the motor is faulty.
Posted on Dec 15, 2008
SOURCE: correct wiring for delta wired motor
check & confirm the following
1. delta connection of the motor is done properly, with the combination of different windings.
2. check the quality of the 3 pole mcb or check with other one.
you can call me in 00971508105450 or mail me a00971508105450@hotmail.com
Posted on Mar 13, 2009
  • 4350 Answers
SOURCE: Is my trolling motor is pulling to many amps? The
WEll, maybe, but what happens is the connectors loose their spring tension, teh resistance goes up, the heat goes up, looser....and fail. the only solution is to cut out all heat damaged material and install somthing heavier. Not always an easy task, but it will keep happening until you do.
Posted on Oct 01, 2010
  • 3289 Answers
SOURCE: I need to wire up a baldor 3 phase motor 208-230/480 15hp and dont have the wiring diagram to know what wire is what or where to hook it to?
Hi Casey, I'm an electrician and can help you with this problem.
First, a disclaimer. Without the catalog number of the motor you have, or a wiring diagram for it, no one can tell you how to wire this motor with any certainty. With that said...
Nearly all single speed 3 phase motors have 9 leads (numbered 1 thru 9) and can be wired for either "high" or "low" voltage. Most of the time, high is 480 volts and low is 208/240 volts. Given that you posted the amperage as "41-38 / 19", I am 99% confident that 41 amps is at 208 volts, 38 amps is at 240 volts and 19 amps is 480 volts. Further below is the way to wire unless the motor manufacturer or name plate indicates differently. You will need to determine the voltage of the appliance this is going to be installed into. You should be able to find this on a name plate of the appliance - but it may provide a dual voltage spec here, too. If this is the case, you will need to *carefully* measure the voltage with a meter, or find out the voltage of the electric panel that feeds the appliance.
Once you have learned the incoming voltage, you will connect the motor as such when L1, L2 and L3 are the line voltage supply wires and wires 1 thru 9 match the numbers on the nine wires from the motor.
208/240 or "Low" volts:
Motor leads 4, 5 & 6 connected together and wirenut.
Motor leads 1 & 7 to L1 and wirenut.;
Motor leads 2 & 8 to L2 and and wirenut and lastly,
Motor leads 3 & 9 to L3 and wirenut.
480 or "High" volts:
Motor lead 1 to L1 and wirenut,
Motor lead 2 to L2 and wirenut,
Motor lead 3 to L3 and wirenut,
Motor leads 4 to 7 and wirenut,
Motor leads 5 to 8 and wirenut and lastly,
Motor leads 6 to 9 and wirenut.
The motor should be operated briefly or "jogged" to determine the direction the motor turns. If the motor rotation needs to be changed, simply swap any two "L" wires (swap L1 and L2, or L1 and L3, or L2 and L3). Test once more to verify rotation and when correct close the wiring compartment and complete the installation. Swapping the L wires will likely be much quicker and easier to do at the magnetic contactor instead of the the motor's wiring compartment. Either location is acceptable.
You should try to obtain the name plate data for this motor - if at all possible to to make sure of the voltage and wiring method. I hope this helps & good luck!
Posted on May 14, 2012
My delta table saw keeps blowing the circuit breaker on the saw. It does not sound quiet and smooth like usual. I got a good blade its on tight what could this be?
a bad centrifugal starter or inside capacitor and or the electric field if an old type with induction motor , but if it has carbon brushes in the motor instead of an induction motor the commutator on the armature short brushes or a bad bearing(s) on the motor or other gearbearings on the saw drive are worn , it must have a smooth turn if turn on the armature if remove the field /motor house.. look in the motor if running at the end if the carbon brushes you see are make to much sparks a worn bearing without the balls or bad armature collectors or electric field . watch if the bearing is worn by blue hot it can have melting the seat in the motor house replace it all.
Mar 28, 2015 | Delta Saws
Can I Run 3 Phase Motor On Y Or Star Connection Without A DELTA?
Some motors need a Y and Delta, with a special switch, to start up, you start with the Y. the motor starts turning, but does not give full power. after a few seconds (depends what the manual says) you switch to delta, to get full power. To let it run on full power in Y you need 1,4 times the voltage.
If everything runs fine, you won't have damaged anything.
Jul 13, 2014 | Baldor RM3120 HVAC Fan and Blower Motor,...
2006 Yamaha V Star 1100 Silverado the starter motor is working but the bike won't turn over
Hi, Anonymous your starter motor is not/was not the problem that dubious title goes to the starter drive/Bendix/clutch which is a separate component that is activated by the starter motor it is a mechanical gear driven part that engages the clutch pack to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Starter spins but doesn turn over the engine Yamaha Star Forum
Yamaha VStar 1100 starting problem
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 21, 2013 | 2006 Yamaha V Star 1100 Silverado
Who to wirie star delta starter
This site gives an excellent explanation of the star connection and the delta connection.
Answers.com - How do you wire a star delta motor
Then this site shows the wiring of the motor windings and the star delta starter and what occurs when the starter switches from star to delta.
Moeller - Star-delta switching of three-phase motors - Automatic star-delta starters SDAINL
Good luck.
Dec 20, 2010 | Air Tools & Compressors
What is the use of wye delta?
I don't know why your question is bound to this special breaker.
If your question is common, the wye/delta is a way to reduce the starting current of a large three phase asinchronous motor.
When a three phase motor is first connected in wye (star), the starting (peak) current is about 3 times less than this in delta. When already in motion the electromotive force will make the peak current when turned in delta much less, than that with a stopped motor.
Aug 08, 2010 | RTO Telemecanique Gv2 Ls22 Magnetic...
Need star delta control wiring daigram
49fb442.jpg STAR/DELTA MOTOR WIRING.
This is the wiring you need to follow.
Feb 11, 2010 | Siemens Seimens Arc Fault Breaker
I have a 15kw motor driven off a siemens micromaster 440. I cannot get the motor to run in delta. I have to run it in star. I have similar drives on site and these motors are connected in delta. what...
Why do you want to run the motor in the delta configuration? The VFD will change the speed to anything you want to do. The delta and Wye connections are normally used to change the speed of a motor. That's what the VFD is for...??
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 28, 2009 | Inverter Siemens Micromaster 440
Electrical
there are 2 or three fusible links in the main power cable i would check the ones from the starter
Aug 22, 2009 | 1988 Oldsmobile Delta 88
Electrical Supplies Logo
104 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
