Question about Garmin StreetPilot c340 GPS Receiver
Garmin C340 startup
I have had the C340 unit for a couple of years and has been workin fine. Since a couple of weeks ago it takes about 2 minutes to find the satellites and start navigating. Also, the voice becomes very slow and low pitch! Any ideas?
  • 1 more comment
  • Sangwin May 25, 2008
    I have the satellite connection problem, but not the slowing voice. I wonder if it is the same issue. I have tried to reset the unit, and it does the same thing. I wonder if it is a software issue or a hardware issue. I have not yet downloaded new maps although the unit is up to date as far as updates go. If anyone has any ideas please let me know.
  • Kevin Miller May 11, 2010
    Is the battery showing it is properly charged? Any issues with the unit turning off prematurely?
  • Anonymous Jun 10, 2017
    pry the front bezel off the unit and press the semi-hidden MASTER RESET button. (sotware / menu reset function will not correct this) make sure the GPS is charged up or plugged into a good external power source before doing this, especially if you have a questionable battery. you 'should not' lose any of your data - but I removed my SD card just in case. That should fix it. This happened to me after my GPS holder developed a battery connection issue and ran the battery all the way down before I realized it.
    Scholar:
  • 52 Answers
The clue is that the voice is slowing and low pitch. The main processor time base has slowed... which means everything will be buggy.
First try would be to Reset the unit. Remove the face cover (GENTLY pry it loose by the fingernail groove directly under the GARMIN logo), press the RESET button, then reattach front cover... this is covered in the owners manual, available online.
If not, then it sounds like a hardware failure... time for a 1-800-800-1020 call (their customer service number)
Posted on May 04, 2008
SOURCE:
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
My garmin c340 will no longer connect to satellite
Hi
Try updating at Garmin Here
This can resolve sat problems
Regards.
Apr 15, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin street pilot
I had the same issue with mine during a trip. Probably needs to bereset. See page 31 of the users manual on Resetting your c340. Once Idid this it worked fine.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Nov 01, 2008 | Garmin StreetPilot c340 GPS Receiver
My Garmin C340 is dead!!!!
I had the same problem on a trip. Required two fixes and once I did this the unit worked fine.
1. Replace the fuse in the car adapter (reason it wasn't charging when I used it in the car).
2. See the users manual on page 31 regarding resetting your C340.
Jul 21, 2008 | Garmin StreetPilot c340 GPS Receiver
My Garmin c340 turns on then shuts off even when plugged in
I have the same problem. I have had it for only 4 months.
Jun 23, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin C340 GPS - Will Not Power On
Thanks. This helped me fix the problem.
Apr 02, 2008 | Garmin StreetPilot c340 GPS Receiver
Display problem
Have you tried resetting the unit? It sounds like you may have a problem that Garmin needs to address. I would try to reset it first, then make sure you have the latest firmware loaded on the unit. If you still have the problem, it may have to be sent to Garmin for repair.
Feb 07, 2008 | Garmin StreetPilot c340 GPS Receiver
Deceptive information given when unitr bought 2 weeks ago.
What kind of problem are you having? What do you mean it won't guide you there?
Dec 27, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 gps freezes up
Avoid buying Garmin GPS. Their units have a non user replaceable battery that last about 2 years. After that, you have to send the unit to Garmin to replace the battery and be hit with at least $150 plus shipping. Possibly more if they need to fine tune something else. Look at other brands with easier battery replacement such as Sony, Navigon, etc. Garmin is a total rip off.
Sep 08, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
304 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
