A picture of circuit board
I need a picture of KK-9912L Radio's circuit board. on of power supply wire cut and I don't know where solder it. can anybody help?
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.
Posted on Apr 27, 2013
  • 298 Answers
SOURCE: help
The Power Supply Board is listed below. Please note, there are 2 models with the same beginning number (PDP4294). Verify your model number before selecting the Power Supply Board as each board is different depending on the model number.
For PDP4294LV use:
Akai PDP4294LV Power Supply Board Replacement
For PDP4294LV1 use:
Akai PDP4294LV1 Power Supply Board Replacement
Posted on Apr 16, 2008
SOURCE: need circuit diagram for bush
Diagrams i am sure as you know are not always easy to come by, at least for free. I see that there are available boards online and a company that will rebuild this model of power board for you in UK. ohmsupplies.co.uk is where it is at. looks like $80
Posted on Oct 16, 2008
  • 2318 Answers
SOURCE: Does anyone know which connector to plug into on power supply
Double check all the connections from the AC line and from the power supply to the other circuit boards. The connectors you are mentioning are identical as per the picture below.
If you need a new power supply, you can find one from this link.
Posted on Dec 04, 2009
Testimonial: "I have a few more questions that I would love to ask Jaime867. He produced a drawing of my circuit board within minutes and was a big help. Thanks"
budmrtn
  • 11361 Answers
SOURCE: Lightning strike nearby caused momentary power
Main AC fuse is encased in the black shrink tubing, labeled with Fx next to two pin white AC input terminal; http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sj1av4u20c17400.jpg
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=Sanyo+DP42848+&stock=all&limit=100
Posted on Jun 17, 2010
SOURCE: Samsung power supply & IP board BN44-00264B &
For anyone else with this problem...I ended up getting a replacement transformer from ebay and swapping it out myself.
You have to remove the back panel of the TV, unplug the board from the harness going to it, unscrew the board (both via the set of screws going directly through the board and the set going through the plastic piece on the opposite side that, as far as I could tell, the board is glued to). This plastic piece (running the length of the board) has receptacles for the backlight bulbs, so be gentle getting it in and out. Don't forget the screw in the middle of the board.
De-soldering was a little tricky. My soldering skills are not great, so maybe it was me. But it certainly seemed to be a little challenging to get it all out. Having so many terminals probably didn't help (a capacitor would have been easier). Eventually though, I did get it out. Soldering in a new one was easy. Be sure to check continuity between the terminals of the new part and other parts of the board using the traces as a guide once you're done.
After that, simply re-install the board and put all hardware back in. Like I said before, be sure you re-engage the receptacles of all the backlight bulbs by pushing down at each notch on that plastic part of the board.
Hope this helps someone else...
Posted on Dec 19, 2011
No power to the air pump
Power board is defective and needs replacing
Jul 07, 2013 | Keurig Special Edition B60 Coffee Maker
1994 saturn
cc586a3b-2b8a-4401-8de1-6433fe458f03.jpg56ba0348-dd82-4a98-8e39-7e6c5867908d.jpg4b456812-9396-483c-b510-76c31f63a06f.jpg1044231d-f68b-41dc-98a0-091271efc103.jpgActually the yellow wire is the key on (ACC) power. Above in the first picture is the wiring diagram which as you can see the wire I marked with the yellow arrow (the yellow wire) goes through the ignition switch and only supplies power with the key on. The constant power wire is going to be the orange wire (I marked that wire with a orange arrow). I continued to the next picture below the first picture marking the same wires and colors from the first picture to the radio. The fuse for the yellow wire is in the fuse panel inside the vehicle (see location in the 3rd picture and marked the fuse panel with a red arrow). and will be the one marked radio either on the cover or the panel itself but should be a 7.5 amp fuse. Now the fuse for the orange or the wire that should be constant power is a 5 amp fuse and will be marked "Chime". Now in the last picture (bottom right) is the wiring diagram for the lighter which is kind of a separate circuit. It does have one fuse in common but that fuse feeds power to the fuse panel inside but if that one was out you wouldn't have tail lights, parking lights and a number of other things so I doubt its the main 30 amp maxi fuse in the fuse panel under the hood. The fuse for the lighter as far as a dedicated fuse for the lighter is in the fuse panel inside the vehicle and will be marked "lock" and is a 20 amp fuse. Sorry I don't have a fuse panel diagram as far as the fuse layout but I hope this helps you.
May 02, 2013 | Car Audio & Video
My philips tv shuts off after about a minute.
If it's a flat screen, you may be looking at a bad power supply. Today's HDTV's usually have nothing more than a power supply and a small circuit board to drive the screen. You may be able to order the part from the manufacturer, but out of warranty, it may cost a pretty penny. The same thing happened to me with a Vizio HDTV, and when the tech arrived, I knew exactly what he had in his box. Even he didn't know which it was and had to replace the circuit board, he admitted if that didn't work, he would install the power supply. If you get a picture, your circuit board is likely okay, but if it just shuts off, check that you don't have too many devices plugged into an older outlet, if that's not the case, Power Supply would likely be the culprit.
Aug 25, 2012 | RCA HD52W59 HDTV Projection Television
1995 Oldsmobile Cutlas Ciera
I guess the short answer is I don't know.
There really isn't a guide to tell you want the fuse equivalent is for a fuseable link. The car companies use the link because it will carry more amps than a regular fuse, and take longer to blow.
You are supposed to replace-repair the wire by using a fuseable link repair kit where you splice another fuse link into the circuit.
The headlights use a 20amp circuit breaker, and the other circuits are probably 10amp or so. You might get away with using a 30amp fuse but I can't say for sure. In reality the circuits are fused after the link so its not likely your computer would be damaged, but a short in that main circuit could blow several fuses at one time.
Aug 21, 2012 | Cars & Trucks
How to install jensen 40w+40w a-80
I have one of these new, in the box, with no instructions.
Specifications:
Power Output: 40W/Chan Maximum, 18W/Chan RMS
(20hz-20khz into 4 ohms at less than 1% THD)
Freq. Responce: 20hz-30khz, +/-3dB
Signal to noise ratio: 80dB, A-weighted
Input Sensitivity:
Low Level, 100-500 mV
High Level, 1-5v
Input Impedence:
Low Level, 10k ohms
High Level, 27 ohms
Load Impedence: 4-8 ohms allowable (4-8 ohm speakers)
Power Requirement: 14.4v DC (10.8-15.6 allowable)
As you can see the RMS wattage output of these units is only about 18W maximum.
I am planning on using the amp I have on a low power factory car radio. A low power factory radio output should be somewhere between 6-12 watts rms/channel. I will be using the "High Level" inputs for this. DO NOT connect a radio with a higher output power. If your radio says "High Power", 25W/channel, etc, do not connect to this amp. (exception: you can use the "line out" connectors, if so equipped, See Below). I don't have the connector for the high level input so i don't know what I'll do to hook up to it. I'll probably just run wires out of the amp, in lieu of the connector.
The "Low Level" inputs are for an unamplified, line level signal ("line out" connection of a radio, portable CD player, etc). Do Not connect a greatly amplified signal to these connections.
I don't know much about the "Input Sensitivity" control (pot). I'll be leaving it on "Low" for my initial test.
The grey wires are the right speaker wires and the white wires are the left speaker wires. The grey wire with a black tracer mark is the right speaker positive (+) wire. The white wire with a black tracer is the left speaker positive (+) wire.
The blue/white wire is for attachment to your radio's "Auto Ant" (power antenna) connection (usually a orange wire, I said USUALLY). If you have a power antenna on your car, simply splice into the wire running from your radio to the antenna. This blue/white wire activates a relay in the amp which, in turn, completes the circuit through the yellow (+) power wire (See Below). - Alternative 1: You could run this wire directly to your battery with a switch to turn the amp on. You would need to place an in-line fuse of 2amp. - Alternative 2: You could connect this wire to the accessory fuse in your fuse box. If this is done, again, attach a 2amp in-line fuse for extra protection. (Note: if attached to your fuse box accessory fuse, the amp will be on even if you're not using the radio. You could have a switch here also). These are just suggestions. The most common way to connect the blue/white wire is the "Auto Antenna" wire of your radio.
The large black wire is main Ground (-) for the amp. The large yellow wire is Positive (+) power to the amp. Ideally, these should be connected straight to your battery's (+) and (-) terminals. The yellow wire on your amp should have an integral in-line fuse holder with a 7amp fuse. If not, add one. Of course, the black ground wire could simply be attached under a screw, into the body of the vehicle.
Hope this helps !
Aug 12, 2012 | Jensen Car Audio & Video
How can i replace 1991 maxima radio system?
The original radio is a BOSE system and it has a buit in amp. So if you replaced the deck you need to replace the speakers all so. Don't cut the wires to hook-up the deck buy an addapter KIT. It's not just the stereo that runs though that harness the factory alarm does all so and that will cause you problems. Anyway back to the stereo you need to add an amplifier and problem sovled.
Jul 23, 2012 | 1991 Nissan Maxima
Hi my plasma just cut off and will not come back on. I know my plasma needs oil to work, do you know where i can purchase oil from?
NO oil in a plasma set and only circuit boards can usually be purchased.
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
May 16, 2012 | Samsung Televison & Video
What is the wireing colors for the radio in a 92 jeep cherokee larado
All vehicles wiring is the same.
To do it right make sure you buy a wiring adapter so you don't have to cut your factory wiring plug off. Below is a wiring picture. Not all the wires in be required to hook up because some vehicles don't use them.
Blue/White (Remote Turn on): Used if sub woofer and amp system is being installed
Orange (illumination): Not every vehicle has this .. This is used to dim the radio when the head lights get turned on its own.
Blue (Power Antenna): Only used if you have one
Feb 07, 2012 | 1992 Jeep Cherokee Limited
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Rca L32hd31 lcd no picture blank screen.
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | RCA L32HD31 32 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
