Question about Brother MFCJ220 All-In-One InkJet Printer
Bagaimana mengatasi unable to clean 50 brother mfc-j220..?
  • 58 Answers
Check the description of your problem.
bagaimana mengatasi unable to clean 50 brother mfc - b35b3645-934f-494b-9685-2b0e7f18f22c.png
Posted on Apr 27, 2013
cene765
  • 787 Answers
SOURCE: I have a brother mfc-420cn. I am getting a unable to clean messa
Do you mean "unable to clean"?If it this follow this instruction.
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If numberis over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Posted on Nov 02, 2009
pineworks
  • 4041 Answers
SOURCE: Brother MFC-420cn Message appears,
Hi you can try this is for your error and please call back and let us know if it worked for you so others can do the same.Solution:
  • Machine off
  • Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
  • Press 80
  • Press the “mono start” button several times until you see “purge: xxxx”
  • Press “2783” in order to reset the purge counter. You will see: “purge:0000”
  • Press the "stop" button.
  • Press “99” to exit the maintenance mode.
All the Best: Pineworks
Posted on Jan 30, 2010
kakee
  • 1268 Answers
SOURCE: unable to clean brother MFC 215c
You can try to press the power button for 30 secs, unplug the power for 10s while holding the power, plug the power back in and wait for 10s then release it.
Posted on Jul 26, 2008
pineworks
  • 4041 Answers
SOURCE: Unable to Clean 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
SOURCE: brother mfc-215c unable to clean?
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
Posted on Apr 30, 2010
How to clean UNABLE TO INIT.50 mfc j220?
just simply remove purge unit on your machine then remove also cam sensor found on purge unit end clean by water.
Jul 09, 2016 | Brother MFC Office Equipment & Supplies
How to reset ink absorber full for brother mfc-j220
https://www.google.co.uk/search?es_sm=122&q=BROTHER+PRINTER+MFC-J220+INK+ABSORBER+FULL&spell=1&sa=X&ei=L7HgVMfAA5HLaJP-gJAD&ved=0CBwQvwUoAA
Feb 15, 2015 | Brother MFC J220 Multifunction Printer
Unable to clean50 brother mfc-j220
You need to do the following. Enter maintenance mode by pressing Menu * 2864 in less than 2 seconds. Press Stop and retry if you dont see the lights blinking. Then press, 80, 2864, 4460, 99. It should work, otherwise its a fault service station pump
Jan 07, 2015 | Brother MFC J220 Multifunction Printer
Brother MFC J220 unable to print 73
The cap lift cam switch is defective. you will need to replace either maintenance unit or the ASF motor assy
Aug 17, 2014 | Brother MFC J220 Multifunction Printer
Unable to clean 5A for brother printer MFC J220
check for ink levels and also check for rollers and usb connections drivers etc
Apr 05, 2014 | Brother Office Equipment & Supplies
Cannot print 50
please follow ALL the steps on link below: How do clear the message Unable to Unable to Chang Brother Please let me know if the issue is solved or not, so we can continue troubleshooting. Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC J220 Multifunction Printer
UNABLE TO init48 BROTHER MFC-J220
I think the printer head need to be replace
Jul 09, 2012 | Brother MFCJ220 All-In-One InkJet Printer
Brother MFCJ220 All-In-One InkJet Printer Logo
569 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
