Question about HP LASERJET P1005 Printer
IDLE MODE SAYS ITS IN IDLE MODE. HOW DO I FIX IT?
  • 58 Answers
Check the status light pattern maybe the printer has a problem. but if there is no error on the printer itself then you have to check for the connection between the machine and PC. re-install the correct printer driver.
Posted on Apr 27, 2013
I replaced the MAP sensor AND the MAF sensor. the car now has a rough idle. did those replacements cause the rough idle?
Did you disconnect the battery negative cable for 5 minutes after the parts were replaced? If not do so then drive it at least 20 miles in varying conditions of idle cruise and so on. See if that helps the rough idle. also rerun the fault code test and see if any codes reappear, I have a feeling you did not fix the problem but just threw parts at it.
Sep 29, 2016 | 2004 Buick LeSabre
1995 chrysler new yorker looses coolant today added BENS headgasket fix-all into radiator.stopped white smoke alot.Rough idle still.what next?
Sounds like head gasket is blown. Unless the car is mint or sentimental to you, it's time for a new car.
Jul 03, 2016 | Chrysler Cars & Trucks
Why won't it idle above 1000 rpm?
no supposed to idle higher than that , usually even less .
Sep 24, 2015 | 2006 Ford Five Hundred
What controls the a/c stepup in 2004 vitara j20 engine
happy new year.
WHAT IS THE RPM>?
hot or cold engine? both key factors.
the a/c puts a large load on the engine
the engine J20 is powerful, and has idle controls
so now those controls are dead.
1: if engine has full power then its not due to lean bogging at idel
2: idle controls failing, ISC failure or failsafe mode.(pcm)
3; Seizing a/c compressor.
idle controls are suspended in fails safe mode
idle controls will fail of engine is real lean.
idle controls will fail if the engine is overloaded.
we check the a/c by hand to see if its ok.
we scan the PCm see if DTC ERRORS. SEE RPM AT 800
See coolant at 180F
we then make sure the engine at hot idle is at closed loop status
if not, we fix that first.
idle is last to fix, all else must be correct or idle will or can fail.
eg: running real lean, running rich and misfiring. etc.
Egr VALVE STUCK OPEN
AND lots more..... ask
Dec 31, 2014 | 2004 Suzuki Grand Vitara
How to take off sleep mode
Sleep Mode
Setting the Sleep Mode reduces power consumption while the machine is idle.
You can choose how long the machine is idle (from 00 to 99 minutes) before it
drops into sleep mode. The timer automatically resets itself after the machine
receives a fax or PC data, or makes a copy. The default setting is 5 minutes.
1 Press Menu, 1, 8.
2 Use the Dial pad to enter the length of
time the machine is idle before it drops
into sleep mode (00 to 99 minutes), and then press Set.
3 Press Stop/Exit.
Oct 10, 2011 | Brother Office Equipment & Supplies
How I can fix Canon mx 868 service mode idle problems?
My MX870 Canon Printer is in idle status. How do you activate the printer?
Mar 29, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Jet S8000 Cell Phone: How do I put my phone in Idle Mode so that I can c...
You need to use:
Menu
Settings
Phone Profiles
Offline (which is "Idle Mode")
Might be more helpful if they just called it that :)
May 16, 2010 | Samsung Jet S8000 Cell Phone
Idle mode
Idle Mode is when your phone shows the main screen with the lights off (in most cases). For example, when you turned on the phone, it will go through Power Cycle mode, if you do not touch it for a minute or so, it will go into Idle Mode.
Mar 09, 2008 | Samsung SCH-u740 Cellular Phone
HP LASERJET P1005 Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
