Question about SENAO High Power 200mW USB WiFi 802.11bg Adaptor with External Antenna (655216003026) Wireless Adapter
SENAO wireless adapter not working
I've been using senao before and it was working well, but i gave my adapter to my cousin and purchased a new the same unit. when i tried using the new one it always give the note that limited or no network coverage... but the signal shows excellent strength.. i also tried uninstalling the driver and installed it again but the same problem i am getting.. can you help me on this? thank you very much.
    President:
  • 2,961 Answers
I assume you have the unit set to alocate ip addresses automatically in other words the dhcp is set to enabled in the settings. If so it maybe that the address is registering wrong, you can either click start>run> then type ipconfig /flushdns, or uninstal your wireless network card in device manager then restart the pc to automatically install it again as this will set it back to default, but remember to make sure obtain ip address automatically is enabled in the adapters properties on the tcp/ip properties.
Posted on Aug 06, 2007
SOURCE:
Noy finding ip address senao wireless AP
Hi. Here is the manual.
http://www.senao.com/images/www.senao.com_English/NL-2611CB3-PlusDelx-Manual-V1-0.pdf?CATNO0=D&CATNO1=D3&CNT=1
Set your PC to use the static IP 192.168.1.10, netmask 255.255.255.0.
To login to the web manager, go to http://192.168.1.1. Leave the username and password blank. You can now configure the device and assign IP address etc.
Jul 18, 2009 | SENAO NL-2611CB5 PLUS (NL2611CB5PLUS)
Reset password for senao unit
pci adapter don't have password password have in the router or modem or access point device
Apr 07, 2009 | SENAO NMP-8602 (NMP8602) Wireless Adapter
Drivers for windows vista 64 bit
i want wireless senao engenius driver vista to HP laptop
Dec 10, 2008 | SENAO High Power 200mW USB WiFi 802.11bg...
Senao USB wifi 802.11
I am afraid that I have had to make an assumption as to the precise modle that you have but the following link should be correct, it gives you the option to download drivers for the
Senau NUB362 (Ext)
http://www.senao.com/English/Default.aspx?TYPE=test.htm&PT=searchDownload1&sf1=D331&sf2=NUB-362(EXT)&sf3=&tv_TCAT_POS=0&CATNO0=D&IDX=3.2&CNT=1&CATNO1=D3
numerous drivers for different operating systems seem to be avaliable.
if I have chosen the worng type a pull down list is avaliable showing the differnt Senao product drivers avaliable.
Nov 14, 2008 | SENAO High Power 200mW USB WiFi 802.11bg...
Reconfigure wireless card
I believe he's wrong. But the wireless card which only does B needs to match the router which could be A,B, or G. And B has some serious range limitations. You also need to manually address the card or the router has to be configured for DHCP. Get past those issues and it should setup normally.
Oct 15, 2008 | SENAO High Power 200mW USB WiFi 802.11bg...
Problem with Senao and Vista
port forwarding...
low download speed....
Dec 05, 2007 | SENAO High Power 200mW USB WiFi 802.11bg...
Problem in SENAO High Power 200mW USB WiFi 802.11bg Adaptor
There are a few things you can do in this case. First, I would check to see if you have your network profile set up correctly. This is done by going in to your wireless properties and checking the profile to see if the encryption password is correct as well as the encryption type and so on. Next, you can go in to the device manager and make sure the wireless adapter is recognized and enabled. If you need help doing these things, let me know.
Aug 07, 2007 | SENAO High Power 200mW USB WiFi 802.11bg...
SENAO High Power 200mW USB WiFi 802.11bg Adaptor with External Antenna (655216003026) Wireless Adapter Logo
89 people viewed this question
Top SENAO Computers & Internet Experts
Ekse
Alun Cox
Are you a SENAO Computer and Internet Expert? Answer questions, earn points and help others
