Question about Marvin Dryers
Asahi fan motor problem
Why is it the motor won't drive faster when i press the button no.3?
  • 4736 Answers
SOURCE: my dehumidifier full light is
This is generally causes by improperly installing the water collection bucket after removing it to empty it. Or the float valve in the top ow the water bucket s stuck in the "UP" position. Some Maytag models have a float control that moves from left to right, depending on how much water you want it to collect, before having to empty it. It may be stuck in the center position and needs to be moved left or right.
When installing the bucket, be sure that it fits into the holder "squarely" from top to bottom and makes contact with the bucket removal safety switch at the back of the bucket holder. When installed properly, the bucket should not tilt down at the bottom.
Hope this helps you and thanks for choosing FixYa.
Posted on Aug 06, 2011
  • 15 Answers
SOURCE: 1998 intrigue motor knocking, using oil, and
As a temporary fix,use "Motor Honey" instead of oil. But you need an overhaul or a used motor from a salvage yard.
Posted on Sep 24, 2011
redds55
  • 2620 Answers
SOURCE: loses pressure when driving forward and backwards. It won't go any faster than 25 miles per hour
Sounds your catatylic converter is clogged.You will need to have the exhuast pressure tested.Or the next time you drive it for a little while stop and look under at the converter to see if its cherry red.Also put your hand behind tail pipe and feel how much pressure is coming out at idle.
Posted on Jan 14, 2012
  • 5685 Answers
SOURCE: WHY WON'T THE CONVERTIBLE TOP MOTOR ENGAGE. WHILE DRIVING TOP BUTTON BLINKS RAPIDLY.
The top should not work above a certain speed or at all if the vehicle is moving. The top can easily rip from the wind if deployed at too fast a speed and even make the car unstabile while rolling.
Most tops will raise above the windshield height when they deploy and can fail to clear carports or drive-thru facilities. The tops can catch low hanging light fixtures or even garage door openings.
Posted on Apr 04, 2012
bronk50
  • 27725 Answers
SOURCE: emachine won't start up when i press the power button.
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
If you are not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
hope this helps
Posted on Jul 20, 2012
Computer won't come on. light is blinking in back of hard drive.
Try unplugging from wall socket then press on button (this clears out extra electricity in PC). Plug back in then try to turn on again. If PC is older, try blowing out the dust inside tower especially around the CPU fan.
Aug 04, 2012 | Compaq Computers & Internet
Fan motor won't cut off when driving my linclon
The fan motor is already defective, that is why it cuts off.
Jun 14, 2012 | Cars & Trucks
Console lights up but when I press any of the buttons it won't start
I am having same problem. The console lights up but none of the button works, including TV and the fan.
I actually took everything apart, unplugged and re-plugged the connectors on the PCBs of both side of the console, it still didn't help. Looking at the electronic configuration, TV, fan, left and right panels are relatively independent. I believe the driver/motor module is still working, the most likely cause of this is the controller CPU.
Jun 05, 2012 | Reebok Vista Treadmill - RBTL13305
I want to download pictures from the internal memory and I attached the camera with the usb cable and it does nothing. I've tried pressing the shutter button nothing
The only way is copy pictuers from internal memory to the external memory using the camera Copy pictures or videos:
1 Press the Review button, then press the Menu button.
2 Press to highlight Copy , then press the OK button.
3 Press to highlight an option:
PICTURE or VIDEO-copies the current picture or video.
EXIT-returns to the Review menu.
ALL-copies all pictures and videos from your selected storage location to the
other location.
4 Press the OK button.
NOTE: Pictures and videos are copied, not moved. To remove pictures and videos from the original location
after copying, delete them
May 19, 2012 | GE X500 Digital Camera
Dryer won't stay on when let go of start button.
One of two things is wrong. Either the start switch has gone bad or the start winding in the motor is failing to switch over to the run winding. You'll need to get a multimeter and before starting unplug the dryer. Once thats done, get behind it, remove the back cover to the control panal and disconnect the two wires that are connected to the start button. With your meter set for checking continuity, place a meter lead on start button pins where the wires were connected, one lead on each side.With leads in place have someone press the start button, if continuity shows when pressed and stops when its not, the button is good and the motor is bad. Personally, I think the motor winding has burnt, and the motor should be replace, but I also think that the start button should be changed as well because its in direct series with the motor, and could have taken damage that may not show up until further down the road, plus its an inexpensive part.
Apr 28, 2012 | Kenmore Dryers
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
Teac A170S won't play, RW, FF, or record.
Hello
Can you hear the motor running, when you press any of the Play, Rew or FF buttons?. Just place your ear very close to the player and listen to it. If the answer is 'yes', the drive belt is broken or slipped off. You have to replace the drive belt. If the answer is 'no' the motor of your device's drive mechanism has damaged, and should be replaced. OK.
WISH YOU A PROSPEROUS 2012.
Gopakumar G, Kerala State, South India.
Dec 25, 2011 | Audio Players & Recorders
Dryers Logo
27 people viewed this question
Top Marvin Dryers Experts
Are you a Marvin Dryer Expert? Answer questions, earn points and help others
