Question about OKI MICROLINE 3320 Matrix Printer
Setting Oki3320 page feed
I have a new oki ml3320, everytime i change the paper & load it, i have to move the paper back before i can start printing. How do i set it to stop at the correct place?
  • Anonymous Mar 13, 2014
    NOT FEEDING CORRECT AMOUNT OF PAPER WHEN PRINTING MULTIPLE PAGES
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 68 Answers
If you need Okidata Printer Customer Service, then you can contact with us, okidata printer support 1877-778-8#9#6#9.We are always here with tech team for your help. For further Info Click:https://goo.gl/Ltis3S
Posted on Apr 20, 2017
    Novelist:
    Champion:
  • 254 Answers
Try Okidata's online site http://my.okidata.com/home.nsf/solutions%26support?openframeset I didn't see that specific model, but a similiar model should setup the same.
Posted on Aug 09, 2007
SOURCE:
How to install paper in oki microline 320 turbo printer
Paper Loading
Rear Feed, Continuous Forms
Use the rear-feed path for printing on single-thickness,
continuous-form paper.
Use the single-sheet path (top feed) for graphics or charts.
! If you have paper in the paper path, be sure to remove it
before installing rear-feed paper.
1 Lock Lever
2 Upper Tractor Cover
3 Pins
4 Lower Tractor Cover
32T-26.eps
1 Move the paper lever to the position marked "REAR."
32T-11.eps
2 Grasp the tabs lift off the paper separator.
3 Pull up on the lock levers and open the tractor covers.
Then, move the right tractor to fit the width of the paper.
32T-27.eps
4 Place the first two holes in the paper over the tractor pins
on either side. Close the tractor covers.
32T-29.eps
5 Move the left tractor to align the edge of the paper with
the appropriate reference mark (1). Then, push back the
lock lever.
32T-29A.eps
6 Adjust the position of the right tractor to center the holes
in the paper on the pins. Then, push back the right lock
lever.
32T-29.eps
7 Install the paper separator. Place the wire guide (1) on the
pull-up roller assembly (2).
32T-31.eps
8 Press FF/LOAD. The paper feeds into the printer.
! The factory default setting for the Top of Form (where
the printing should begin) is one inch down from the top
of the page. To change the setting, see "Using Your
Printer, Top of Form (TOF)."
Top Feed (Single Sheets)
Use the single-sheet path for letterhead stationery, memos,
and individual envelopes.
! If you have continuous-form paper in the path, press
PARK to remove it before loading single sheets.
1 Make sure the printer is on and deselected (SEL light off).
2 Place the paper lever in the position marked "TOP."
32T-12.eps
3 Open the carriage cover. Raise the paper separator to the
single-sheet position.
4 Make sure the wire feed guide (1) is secured in the sheet
guide.
5 Adjust the paper feed guides (1) for the width of the paper.
Place a sheet of paper in the separator. The paper will feed
into the printer.
32T-15.eps
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 04, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
OKI Microline 591 prints extra page of paper everytime
There is a setting on most printers to print a separator page at the end of print jobs. You can check the settings of your printer by going to the control panel and clicking on printers. Select your printer, right click and go into properties. The setting for this is usually located in the advanced settings. See if the printer is set up to print a separator page, if it is, uncheck it, press apply/ok button and close out printer window.
Jul 10, 2009 | OKI MICROLINE 591 Matrix Printer
OKI 24DX - Press ONLINE button to print each page
you have to open your printer icon in CONTROL PANEL
CONTROL PANEL
THEN
PRINTERS AND FAXES
RIGHT CLICK ON YOUR OKI PRINTER
select PREFERENCES
under SET UP and MEDIA size change it to A4
I think this might help you. I'm guessing that you have the wrong size paper selected. And each time the computer needs you to confirm you want to print with a different size paper
I wouldn't phone OKI help line..I was on hold for 15 minutes, then just gave up.
Jul 01, 2009 | OKIPAGE 24 Led Printer
Kyocera 3800N Defaulted To MP Tray
paper guide was set at A5, then this allowed menu to change feed tray selection
Apr 29, 2009 | Kyocera Mita FS 3800 Laser Printer
Print fragmented documnts
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Aug 14, 2008 | OKI MICROLINE ML-395 Matrix Printer
Oki Pacemaker 4410
I assume you are trying to use the front path? If so simply press PARK and then press the PATH button to change it back to FRONT FEED.
When it runs out of paper it changes paper paths automatically looking for more loaded paper (AUTO-PATH feature).
Anyway, that's what happened to us.
Aug 08, 2008 | OKI Pacemark 4410 Matrix Printer
Printing
I have found that the printer will automatically feed out the back if you have the "paper catcher" pulled "OUT". Try pushing the back "paper catcher" "IN".
Apr 14, 2008 | OKI B4350 Laser Printer
OKI Margins
Are you using compatible ribbons which maybe to tight try geniun OKI ribboms.
Hope this helps,
Dezzi
Apr 14, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Page advance problem
print out your menu of the printer and load the IBM Proprinter driver in windows ,your printer default driver is IBM Proprinter this will sort out the problem.you have probably loaded a OKI driver while the printer is set for IBM.Hope this helps.
Dezzi
Oct 16, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
Top print margin shrinks.
It's a software problem, you have to uninstall the printer and reinstall it then it will be ok.
Oct 10, 2007 | OKI MICROLINE 390 Turbo Matrix Printer
OKI MICROLINE 3320 Matrix Printer Logo
1,028 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
