Question about Spark Plugs BR4HS Plug 10/BX #3322
1974 mini 1000cc spark plug gap - Spark Plugs BR4HS Plug 10/BX #3322
    Top Expert:
  • Ngk Master
  • 42,623 Answers
Normally around .025" using a wire gauge. Up to .030" will ok
Posted on Jul 29, 2013
For 2011 mini cooper hatchback I bought the racing spark plugs. What is the gap?
The ideal gap will probably not be the one quoted in the Mini data.
You should refer to the spark plug manufacturer's catalogue which will provide the information you need.
Mar 12, 2017 | Mini Cars & Trucks
Spark plug gap settings chart
Standard plug gap is .044 inch.
Jul 27, 2014 | 1974 Ford Maverick 2.8
Spark plug gap 1973 351c with v2 heads
Just like a engine sample...
The 351 Cleveland V8 Engine was introduced in 1969 as Ford's new performance car engine and was built through the end of the 1974 model year.
Part Number: RV17YC
GAP: .035" (Original Equipment Manufacturer and/or Original Equipment Equivalent)
Hope this helps (remember to rating ans leave an testimonial about this free answer).
Sep 30, 2011 | Pyramid (In49) Universal Mounting Kit for...
My 1974 Yamaha 250 Enduro wont start I have cleaned and redone the carb. I have changed the coil pack and spark plug. Any suggestions will help Im not a mechanic by any means so not sure where to start...
you need good compression ( at least 90 psi , kicking it with the throttle open) , good crankshaft seals for sucking the fuel/air into the botton end, proper point gap and timing set for spark ( spark should be big and fat,if not the source coil is weak,, this is a flywheel magnito ignition and it needs no battery to fire the plug) if you clean the carb, make sure you also clean the choke pickup tube or it wont choke. also make sure you have the slide installed in the right direction ( not backwards and the idle is not set too high at first...compression/****-good spark at the right time-proper fuel/air ratio and it will run
Jul 04, 2010 | 1974 Yamaha DT 360
Any one know the spark plug gap spec for A 1982 honda 200E atc three wheeler
most of the atv plugs are gapped at the factory. .024 to .028
Jun 22, 2010 | 1974 Honda CB 200
Wont start up. seems electrical 1975 Yamaha dt 400 What should I check?
check for spark at the spark plug.. if no spark at the plug check the coil for spark where the plug wire plugs into the coil. that bike probably has points. check the points gap.
Dec 12, 2009 | 1974 Yamaha DT 360
What is the recommended spark plug gap setting for 2005 Mini cooper S and should it be the same for Iridium plugs
the standard plugs are NGK bkr 6 equp, you can buy iridium ones (BKR6EIX) the gap should be 0.8mm
Dec 05, 2009 | Mini Cooper S Cars & Trucks
What is the spark plug spec for a 1984 big red 200es?
Most spark plugs already come pre gapped.
Sep 12, 2009 | 1974 Honda CB 200
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
42 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Ian Kime
Ian Kime
steve morris
steve morris
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
