Question about Cherokee Radio Communications
PLL Err This error message comes on. What does it mean, and how do I fix the problem? Thank you
    Master:
  • 623 Answers
The frequency reference circuits have a problem. You cannot likely fix it yourself.
Posted on Nov 05, 2013
I'm getting a error message that says, "ERR 99".
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks
Apr 18, 2011 | Canon EOS 30D Digital Camera with 18-55mm...
My name is Madhu. I use the camera Canon EOS 400D / Digital Rebel XTi. When the inbuilt FLASH is on then a message pop up as "busy now", when i tried to click the camera to take a photo then...
Welcome to Fixya
Thank you
Apr 04, 2011 | Canon Rebel XTi / EOS 400D (body only)...
99 error, CF memory card was removed to download pix. put CF card back in camera, but now get error message. removed battery and card several times, including replacing with another card. still get same...
Thank you for using Fixya!
Feb 13, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Image Class D860 - Error message E003. How do we correct?
Under service mode ( MENU and # ) find CLEAR, and select ERR ( if you cant find err, select ALL ), and OK.
Restart machine.
If that does not help change the whole fixing assy.
E003 means that you have temperature problems in fixing assy.
If clear does not help, that means that you have bad thermistor or fixing ceramics.
Jun 29, 2010 | Canon imageRUNNER 400S Copier
Error message E00001*000
It means that you have fixing problems, try to enter the service mode * 2 8 * and under clear select clear err or all.turn off and on. If doesnt help you need to change the lamp or thermistors.
Pls. rate
May 10, 2010 | Canon imageRUNNER 2000 Copier
Walgreens HD303 Blood Pressure Monitor error 3
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
How do i get rid of er2 message on realistic htx404
This is taken from an in-store Rad Shark memo concerning the HTX-202.
ER1 indicates an internal RAM error. It appears when the memory backup battery is dead, when something has caused the memory contents to become corrupt, or as a result of physical or static electric shock. To clear this error, turn off the unit. Then turn it back on while holding down the "function" and "D" buttons. This clears the memory. If the error returns after you clear the memory, service is required.
ER2 indicates a PLL unlock. The radio gives this error if the PLL alignment is off or if the transmitted signal interferes with the internal PLL frequency. This error has been reported most frequently when using the supplied "rubber ducky" antenna with either a high-power battery pack or with an external DC source.
According to the memo, the fix for this is to use an external antenna when using external DC power.
Feb 25, 2010 | Radio Shack Radio Communications
What does it mean whirlpool adp6000wh err 4 message code
Error 4 means" too much inlet water", turn inlet water tap down.
Aug 25, 2009 | Whirlpool Dishwashers
Error message on Olympus
Hello evrybody,
I had the same problem but i fix it.
This is the solution :
1- When the "ERR" message is shown, press Disp/Menu Buton for Two seconds and at the same time "Stop" Buton.
2- The "FOR" Message is shown
3- wait for some minutes
That's all
PS : All the recrded messages will be deleted
Mar 01, 2008 | Olympus VN-2100PC Digital Voice Recorder
Error: Invalid Dim
this happened to me as well. i looked it up and heres what i found:
http://www.prenhall.com/divisions/esm/app/graphing/ti83/faq/faq.html
basically you have a stat plot on so to turn it off, press 2nd and then the Y= button to get to "Stat Plot"
one of them is turned on so press enter and select OFF. this should fix the problem!
Sep 18, 2007 | Texas Instruments TI-83 Plus Calculator
Radio Communications Logo
100 people viewed this question
Top Cherokee Radio Communications Experts
ka4iup
ka4iup
eradiostore
eradiostore
Mike Charette
Are you a Cherokee Radio Communication Expert? Answer questions, earn points and help others
