Question about Sewing Machines
Needle clamp tragedu
The needle clamp fell off and I can't get it back on these are the two pieces I have please help
  • Sewing Machines Master
  • 627 Answers
The needle clamp usually has a screw on the back that is tightened to prevent the needle holder from falling off. The screw on the back should be very loose. Place the holder on the arm (moves when you rotate the wheel by hand) with the screw towards the back and the hand screw on the side. Tighten the screw in the back and it shouldn't come off. Now, place the wire on the side where the hand screw on the inside of the hole along with the arm and place your needle in. Now you can tighten.
Posted on May 05, 2013
mohammed387
  • 1952 Answers
SOURCE: My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Posted on Aug 31, 2008
Totally happened to me last week. I discovered that the metal piece that fell off and holds the needle has a small screw that holds it in place. It needs an Allen wrench (tiny one) to tighten it back into place. I just lucked into figuring it out.
Posted on Feb 17, 2009
SOURCE: needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Posted on Feb 21, 2009
SOURCE: needle clamp fell off. got a new one, but need
I have an XL6452 and the same problem. I figured out that you can use a tiny screw driver (or an allen wrench might work). I tried using the screw that tightens the needle but it didn't seem to work. The screw looks like it just a hole. It took a lot of turns to get it loose enough so you can put it on. You will see it come out.
Once you get it on you can tighten it.
Posted on Feb 13, 2010
  • 183 Answers
SOURCE: Sewing Machine Model SA2200 How can
Best advice is to take the sewing machine to a repair center, where you can buy a new needle and and ask the service person to install for you. If you bring your own needle, you may get charged for the installation.On the other hand, if you buy a needle from them, you might get a free installation.
Try that.
Posted on Jan 26, 2011
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
Metal boot shape piece goes inside needle bar then needle they keep falling out. Metal fell out trying to change
Would you please say what model you have? I gather that there's now a problem with your needle clamp, and it won't hold needles? Those clamps can be replaced inexpensively--you just slide the old one off and the new one on--but I could be more specific about where you can buy a replacement if you supplied the model number.
Jul 02, 2015 | Singer Sewing Machines
How do I reattach needle threader parts on Singer Futura XL 400?
I've done this, and it's a pain, but can be done. Let me also tell you that quite a few users have broken theirs and just used the machine without it, but others said that they had to replace theirs. First of all, the wire guide is held UNDERNEATH the needle clamp, and what you have to do is insert them back in one piece. That is, remove the clamp, insert the end of the guide, then push them together on the shaft as one unit. The end of the thread guide sticks up over the top of the clamp in the back. There is a very tiny screw there that's supposed to hold it, but most machines are produced without the end going underneath that screw--they just let the needle clamp hold it. That screw is VERY tiny and VERY difficult to access, and will come out completely after only a few turns. Worse yet, it serves as a "stop" for the end of your needle, so if you lose it, you'll have to use something like a toothpick to "stop" the end of the needle until you can replace it. ASK ME HOW I KNOW! It is easier to deal with if you put the machine on its side when you do this.
Sep 21, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
I have a Brother XR-65. The needle bar fell out as I was sewing. I need a repair manual or some instruction on how to secure the needle bar in the machine. I have the bar itself and a pin sized piece of...
This was happening to me also - you have to tighten a different screw than the one that holds the needle in.
http://www.sewingpartsonline.com/needle-clamp-screw-brother-ls-2125-sewing-machine.aspx
My husband thought the screw was missing - it is actually a plastic screw with a hole in it for a tiny allen wrench.
You can see it in this picture also
http://www.sewingpartsonline.com/needle-clamp-babylock-brother-xz0001051.aspx
If you look at the photo of the screw I attached, you can zoom in and see it has a hexagonal hole.
It is above the flat head needle clamp screw (the one that holds the needle in)
It is REALLY annoying that this screw is mentioned nowhere in the manual, and the hex allen wrench is not included with the machine.
Kind of an important little detail, considering it holds the needle assembly together... you'd think that they would have told you about it.
Sep 09, 2011 | Brother Sewing Machines
The needle on my sewing machine literally just fell off. Not kidding. I'm holding an unbent and otherwise pristine needle. Oh brother SE-270D! I'm not sure how to put the needle back in. I think it just...
when you put the needle in the needle clamp holder the flat side of the needle goes toward the back of the the machine when you tighten the needle clamp screw make sure it's holding the needle,,make sure you can't pull the needle back out of the clamp,, if you can something is wrong with the needle clamp or the screw
Dec 06, 2010 | Brother SE-270D Computerized Sewing...
The thing you put the needle in and their is a wire thing that goes in there...that piece fell out and needle won't stay in...it's a brother XR-35
What fell out was the needle clamp gib - a small wedge-like part that presses on the needle to hold in place.
You may be able to get it repaired or replaced.
Search online for parts, or ask a sewing machine service tech for an estimate for having the machine repaired.
Mar 19, 2010 | Sewing Machines
this sounds like the needle guard it is usually held on by the same screw that holds the needle clamp it should fit so that it comes across the needle at the front to stop your fingers being sown but not interfere with the needle try turning by hand before turning back on.
Jun 05, 2009 | Brother XR-65t Mechanical Sewing Machine
Sep 11, 2007 | Brother XR-65t Mechanical Sewing Machine
Sewing Machines Logo
192 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
