Seagate replacement power supply PN 9ZH9p9-RAA
NO POWER to unit
4 Suggested Answers
shadow5599
  • 51 Answers
SOURCE: power supply for Seagate 400GB
Ebay or seagate.com may be a solution.
I've used those Seagate portables and 2 have caused problems.
Or disassemble the unit, remove the drive and buy a portable case or USB adapter.
Posted on Oct 16, 2007
  • 21 Answers
SOURCE: seagate hard drive will not power up
You have to be running NT, XP or Vista to access the drive. I take the power cable out, then plug it back in. Or try rebooting with the hard drive plugged in. Also purchase a USB Extension port so you can unplug the USB when not in use to stave off overheating. Go to Seagate and download Seatools. Also Download the source code for the drive while you are there.
Posted on Jan 27, 2009
SOURCE: Maxtor personal Storage 3200 Power Supply [K01PWR3200]
i own the exact same drive. i'm looking for a spare power supply, came across this website, and saw your problem. the power supply is 12 volts dc at 2 amps. the connector that gets plugged into the hard drive: center pin is power (positive) and outer "shield" is ground (negative). hope this helps.
Posted on Jul 17, 2010
Tip
Cyberhome CH dvd-300
Power supply problems. There are many reports on this site for problems related to the cyberhome dvd player, one of them mine. Here is what I found. The dvd drive was ok it was the power supply that failed after a power surge. The power supply is a flyback power supply using the viper22 switcher by STM Microelectronics. you can download the specs with a schematic diagram simular to the one in the cyberhome unit. I wound up replacing the shunt regulator (TL431) Optical coupler (PS2561-a-1) , the 2200uf cap and the 1000 uf cap. this brought the 5 volt output to 5 volts which was the problem. The parts can be ordered from Mouser Electronics.
1000uf @ 10 volts PN UHE1A102MPD
2200uf @ 25 volts PN UFW1E222MHD
TL431 PN 512-431CLP
PS2561 PN 551-PS2561-1-A
Warning: The high voltage side of this power supply has 120 VAC and 161 volts dc when energized. thak precautions when measuring the voltages on the output. Good luck
on Oct 07, 2010 | Cyberhome CH-DVD 300 DVD Player
What is the AC DC adapter spec for SEAGATE 9NK2AE-500. i lost the original adapter that came with this external seagate freeagent harddrive.
most of these external hard drive units work with a 12V 3 amp DC power supply like this one
OEM AC POWER SUPPLY SEAGATE 9NK2AE 500 Free Agent HDD
Make sure you get the correct power connector for your country.
Aug 17, 2014 | Computers & Internet
Cannot connecy power supply to unit
You need a USB cable to connect the seagate drive to the PC and you need to plug the seagate's power supply into the seagate drive and the wall.
Jun 17, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hi, I have a Compaq PSU (PN: 230822-001) from a HP Proliant server. I am try to test the output of the unit but need to 'enable' it using the pins on the back... Do you have any information...
OUTSIDE of a redundant PSU - The power supply is very inexpensive and can most likely be bought from any of your computer retailers, Amazon - Just make sure to confirm the right model type of power supply. BEST to have it tested before replacing it. To make sure that is the issue.. Many computer shops will test for free.
Sep 16, 2011 | HP (230822-001) (230822001) Power Supply
The power supply o my TEM model CM30 is burned. I need to buy 2 of them. Here is some spec. type : PE1148/22 AC 110/230V 47-440Hz, 500 VA DC 50V 6A
Call FEI @ 866-693-3426 and order PN 4022 268 00415.
This is a replacement for the Obsolete PE 1148/22.
This replacement takes teh place of TWO PE 1148/22 units.
Some Wiring modifications may be required.
Jul 13, 2011 | Philips Computers & Internet
Need a replacement power supply, or at least need to know what input (volts and amps) the drive itself will take
Generic replacements for Seagate external drives are are pictured with a circular cross section plug with a yellow tip. They are rated at 12V 2A. They can be found on both eBay and Amazon.
If they look the same as your old supply, anything with that rating should be suitable.
There should be a sticker on the old unit with it's electrical characteristics, power ratings in and out.
Jan 31, 2011 | Seagate ST3500641CB-RK 500 GB FireWire 400...
Please i need the power adapter rating for seagate
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Nov 20, 2009 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
Maxtor basics 500gb PN-9NZ2A4-500 will not power up. cannot access data on the drive
Have you tested to connect your HD with another cable (power cable)?
Is it an internal drive or external drive?
The following link is useful to do some tests with DiscWizard.
http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/std_adp.php?p_faqid=4934&p_created=1192999723&p_sid=Csx_ENbj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NDEsNDEmcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD05TloyQTQtNTAw&p_li=&p_topview=1
Aug 20, 2008 | Computers & Internet
Dec 29, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Computers & Internet Logo
809 people viewed this question
David Payne
David Payne
