Question about Lands Phones
Kx tga131cx caller ID does not indicate date and time of call
SOURCE: Caller ID is not working in India.
For people who have purchased cordless phone in usa and caller id is not working they should purchase fsk to dtmf converter at any local phone shop and caller id will start working.
Here is the article on various frequency used by various countries for caller id.
Hope this will help you out.
Detailed Product Description
There are 3 major caller ID specifications in the world: DTMF, ETSI FSK and Bellcore FSK. When users buy a foreign telephone devices(such as cordless phone, fax machine or computer telephony interface), may encounter the problems of non-match for caller ID standard. This will cause the device unable to display the caller ID. EX220 can solve this problem easily. This product can receive all 3 kinds of caller ID format, and convert to FSK(Bellcore or ETSI selectable) to match foreign telephone's standard.
EX220 has a rechargeable battery inside the device, during idle status, it gets power from the telephone line and recharge the battery, so no need to use or replace battery. Just plug one end to telephone line, and the other to the telephone device.
For example, if you live in Netherlands, Saudi or India, the caller ID standard is DTMF. You purchased a cordless caller ID phone from US(which uses Bellcore FSK standard), or from Germany(which uses ETSI FSK standard). You won't be able to use the caller ID feature. In this case, just get one EX220 and connect it between the telephone line and the cordless phone, your cordless caller ID phone will display the caller's number immediately.
Remark:
1. Telephone sets for UK and Japan standard are not applicable.
2. In some countries, users must subscribe to Telecom for caller ID service
Feature List
Caller ID Format Conversion --- Convert 3 kinds of caller ID(DTMF, Bellcore FSK or ETSI FSK) to ETSI FSK or Bellcore FSK(selectable)
Date/Time Stamp --- The DTMF caller ID doesn't content date/time stamp. User can set up clock of EX201, so each call will be sent with actual date and time stamp
Area Code Setting --- User can set up the area code, so the dial back feature can easily applied
Rechargeable battery powered by line --- Just connect to the telephone line, the built-in rechargeable battery can get power from the telephone line, no need any external battery nor power supply
News
Now, Multi-Line caller ID converter is available.
Posted on Jan 08, 2008
  • 65 Answers
SOURCE: Time and Date wrong on caller ID
I would check with your service provider. It maybe just a programming error in the switch from there.
Posted on Feb 02, 2008
SOURCE: Caller ID Light Won't Stop Blinking on Base of KX TC1713 Phone
Solved this myself simply by scrolling through all the Caller ID entries from recent calls . . .
Posted on Mar 02, 2008
SOURCE: KX-TG6052 two handsets. Can't get Talking-Caller ID to turn off!
to turn the talking caller id off go to the menu press 0 then * then 4, then press 0 again to select off.
to turn the ringer on the handset back on, go to the menu, prees 1, 1, then press 1 for a low ringer, 2 for medium and 3 for high.
Posted on Jul 27, 2008
  • 30 Answers
SOURCE: How do you turn on caller ID on a Panasonic KX TGA181AL
Is your phone operated off a panasonic system? is so you need a caller id card. if not then you would need to inform your phone service provider that you need caller id. if you have caller id and you do have the caller id card you would need to get a hold of a panasonic tech who could turn on your c.id as long as it is being provided from your phone service and the card is installed.
Posted on Feb 21, 2009
No Data Sent keeps appearing on Caller ID box and date and time does not change , can you help?
Make sure your "Date" and "time" are set on the phone in question and if it still doesn't work make sure your telephone provider has Caller ID activated if that is the only caller ID phone.
Aug 26, 2014 | Lands Phones
Southern Telecom Large Display Caller ID CID 50LD manual
Set Date and time manually if desired. 1. Press and hold the [dial] button until the display show "SET left OR right ". 2. Use the up or down buttons and select "DATE/TIME" andpress the [dial] button to enter.3. Use the up or down buttons to set the hour, minute, AM/PM,month, and day.4. Press the [dial] button to confirm your selections
Nov 28, 2013 | Southern Telecom Large Display Caller ID...
Red Light Inside Is Off and No Caller ID
Hi, usually this red light is a "new message" indicator when it's on, the normal condition should be off. If the caller ID function is not working could be cables misconnected, the connector labeled as line should be connected to wall line outlet, the connector labeled as phone should be connected to your telephone. In the worst of cases if the connections are OK, there's a problem with the line or the caller ID unit.
Jun 11, 2013 | Olympia InfoGlobe Caller ID
After installing new batteries I have lost my time and date on the window display
The date and time is supplied with the caller ID information from your phone service provider. When you get a call, the date and time will be set. (If you don't have caller ID, there's no way to set the date and time otherwise. I've always wondered who came up with such a silly design.)
Jan 30, 2011 | GE 29385GE1 Corded Phone
How ddo I change the date?
The time and date will update automatically when you receive a call as long as you receive caller id from the telephone service provider. Current time and date are part of the Caller ID data stream. Once the time is received the Fanstel unit will keep time from there and it will be updated every time you get a new call.
May 09, 2010 | Fanstel Caller ID Box Phone
Caller ID does not display
CID needs 3 things, a subscription from your phone line provider, a phone to display it, and someone sending it.
If your generic phone is of the single line set variety and it has CID, then check with your provider. If it's a system phone, it may not have the proper equipment installed or not even be available in the phone system. Usually, even if the call is blocked by the sender, you will get a date and time and "unknown caller" or "out of area"
indication when a call comes in.
Carl
May 17, 2009 | Uniden Cordless Phone
Caller ID date and time doesn't show up on cordless phones
Here is a link to the manual for the 756 series of Uniden phones.
http://www.uniden.com/pdf/DCT756om.pdf
You should just have to set the caller ID time and date. Hope this helps.
Mar 29, 2009 | Uniden DCT756-3 Phone
Cidco inc caller id box - model # JA-25A-18
When a call is received it will automatically set the time and date. To change the display contrast hold down the 'delete' button while toggling one of the other buttons. Hold the delete button down until the 'select,mem,mode' is displayed and choose between '25 name & number' or '64 numbers' . Make sure the batteries are good and the batt indicator in top left corner of display is off. I think that is all the features this early model unit was capable of.
Sep 29, 2008 | Home Security
Need owner's manuel
to set the date and time you have to push the store button, then the arow keys up or down to get the right menu, it will go thru several things. to set date and time, ect. the arrows are the buttons by the caller id window.
Jun 23, 2008 | Sakar HT-848CL Corded Phone
Jan 31, 2008 | Uniden TRU8885-2 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
