Question about Polaroid i832 Digital Camera
Outdoor pictures reveal white on LCD screen
For some unknown reason my camera does not show a clear picture after taking an outdoor picture, it shows some outline of the image I took but most of all it is white. When I take an indoor picture it is fine, it shows very clearly on the LCD. I have set all settings on Auto, iso, but still have the problem. I have recently been on holiday's without my camera, and would like to know whether or not I have to buy another camera. Thanks Rob Warden
  • 39 Answers
The sensor for the auto-ISO may be working incorrectly. Try changing the ISO manually for different light modes. You can also try to change the white balance of the LCD. -Setting the white balance: 1. Set the camera to still image mode 2. Press the "Set" button 3. "White Balance" should be the current selection 4. Press the "Flower" button or "Flash" button to move through the available options for white balance 5. Press "Set" again when change appropriately - Setting the ISO: The higher the ISO value, the less light the camera needs to make an exposure, allowing the same exposure to be achieved with higher shutter speeds or smaller apertures. In a digital camera, higher ISO value allows higher shutter speed, at the expense of mottled or grain appearing in the final picture. 1. Set the camera to Still Image mode. 2. Press the "Set" button. 3. Press the "scn" or "timer" button to select ?ISO?. 4. Press the "Flower" or "Flash" button to select the desired setting. 5. Press the "set" button to select. 50/100/200 In the same lighting condition, the higher the ISO value is, the faster the shutter speed will be. I hope this helps.
Posted on Aug 06, 2007
The camera s 730 works poperly in doors but dosent take pictures outdoors ( after taking the picture it show a the picture as a white screen ) pl. help asap as i am with my family for a vacation pl...
Problem with the Samsung Digimax S730 Digital Camera the camera s 730 works poperly in doors but dosent take pictures outdoors ( after taking the picture it show a the picture as a white screen )
Jul 14, 2011 | Samsung Digimax S730 Digital Camera
Yashica ez digital 6032- 6 mp camera.. i got one sparingly used yashica camera... with above spec... which shows trouble when taking stil pictures outdoors... indoor pictures and video indoors n outdoors...
i am using yashica ez digital 6032 camera but while using SD card of 4GB memory, it is not working. it is asking to format. Pl. help me regarding this problem. Shall i format the camera?
Apr 27, 2010 | Cameras
Outdoor pictures give white display on screen
Go to the menus and reset to default or factory settings. Make sure that the white setting in the picture adjustments in the menus are set to zero or you may have to adjust + or - to get the normal effect again.
Test the camera by taking pictures and saving to a sd card. Then put the card in a card reader/writer which is connected to the computer. Copy the pictures or files to the computer and view them to see if they are in good shape or if there is some problem with exposure or the way it looks.
If the computer pictures show that they are good, and they are not showing good on the camera LCD, then the LCD has a problem, and is possibly either cracked or has some other display problem.
These LCD screens are not that hard to change if you are good at working with small items and screws. If you do this, make sure you have a way to remember where you got each screw, as they can vary in size and kind.
Apr 15, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
The lcd screen shows white image when taking outdoor photo
i was taking picturres with my canon A470 digital camera and when i review the pictures that i take, the pics were very bright that you cant view well the pics. what is the problem with it? it just suddenly happened like this.
Oct 25, 2009 | Canon PowerShot A470 Digital Camera
Problem on outdoor daylight picture taking
hi
try the Exposure button [+/-] will generally be disabled in auto mode
try changing mode to 'P' (Program) mode and then change the exposure by pressing the +/- button and then you would generally see a scale on the LCD now press the left button to decrease the exposure
better more is to reset the camera to the default settings this would set the aperture, shutter, Exposure, LCD brightness and otehr settings to defaults and this would save from any unwanted changes than required
cheers
pls rate if it was any help
Jul 03, 2009 | Samsung Digimax L60 Digital Camera
Canon sd900 will only take pictures that don't require a flash
Press the "DISP" button. Button on the top right of the bigger circle control button.
You can turn off the display if you want to conserve battery and use the viewfinder. So you probably accidentally turned it off. You can use that button to turn on/off the LCD display or change between two brightness settings on the LCD.
Hope that fixes your problem.
Apr 19, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
Image in LCD shows mulitple horizontal whie lines
This sure looks like a CCD image sensor failure. If so, you can't fix this yourself. If the camera is less than a year old, Canon will fix this for you under warranty. Call 1-800-OK-CANON.
Jul 08, 2008 | Canon PowerShot SX100 IS Digital Camera
Re: outdoor pics very light
It sounds like overexposure. If you are in Auto mode, you should have your settings automatically so you shouldn't get overexposure and if you are, you may need to have your camera serviced.
Make sure your ISO is not high, make sure your shutter speed is not long and make sure your flash output is not high.
Other than that call Canon and set up service or get an upgrade through their Loyalty program.
Apr 27, 2008 | Canon PowerShot S2 IS Digital Camera
Fogging Picture
try to use the zoom function during picture preview and you will see the horizontal bands. Time to change to a new CCD i guess..or maybe a new camera :-)
Mar 10, 2008 | Casio Exilim EX-S500 Digital Camera
Polaroid i832 Digital Camera Logo
183 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
