Question about Dryers
Dryer not getting hot
Not getting hot
  • Dryers Master
  • 7,482 Answers
Hi dontrice
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or inside of the dryer venting system,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the heating element/thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if you do not read continuity you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
Try to run the dryer, if it runs and heats up then replace the thermal fuse/thermistor/thermostat.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.
But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.
DO THE FOLLOWING TEST:
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check the fuse/thermostat,thermistor for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc. If you have to replace your blower wheel it will remove clockwise as looking at the blower wheel. You will have to hold the belt end of the motor with a vise grip pliers or maybe the shaft of the motor has a notch cut on it for a wrench to fit.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
If you do not have a volt/ohm meter then:
DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me
Bud
Posted on Apr 27, 2013
There is a burned odor when drying my clothes. How do I get lint from inside the dryer out if this is a problem
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 20, 2011 | Miele Novotronic T1515A Electric Dryer
Dryer gets very hot
heatman101
Sep 17, 2011 | Kenmore 72622 Gas Dryer
SAMSUNG GAS DRYER DV 328 RUNS FOR A WHILE AND THEN STOPS . I GET ERROR CODE EO. THE CLOTHES IN THE DRYER ARE VERY HOT. AFTER A PERIOD OF TIME THE DRYER COOLS DOWN AND STARTS TO WORK AGAIN. THE DRYER...
heatman101
Aug 14, 2011 | Dryers
Clothes seem to get too hot
The cycling or operating thermostat is often the problem when a dryer runs too hot, but there are also other things that can make it run hot also.
Clothes Dryer getting too hot
heatman101
Aug 13, 2011 | Maytag Dryers
Dryer is getting too hot
heatman101
Aug 10, 2011 | Whirlpool WED5300S Electric Dryer
Kenmore 800 series dryer gets to hot
heatman101';
Aug 02, 2011 | Kenmore Dryers
Dryer gets hot but shuts off
heatman101
Jul 15, 2011 | Estate EGD4300SQ Gas Dryer
Dryer getting too hot....no lint anywhere....could it be a bad thermostat?
heatman101
Jul 11, 2011 | Kenmore 72872 Gas Dryer
The dryer is working but it smells like it is getting hot. any ideas?
heatman101
Mar 22, 2011 | Kenmore Elite HE4 Electric Dryer
Gas dryer wont get hot
The first thing to check is the thermal fuse. It is located in the back of the dryer, and you need to remove the back panel to get to it, which involves taking out about a dozen screws. To check it, unplug the dryer, pull the wires off the thermal fuse, connect them to each other with an alligator clip lead, plug the dryer in and see if the dryer gets hot.
Jan 11, 2009 | Kenmore 63942 Dryer
Dryers Logo
Top Dryers Experts
