Question about Kodak Ektasound 245 Movie Projector
How or who can fix our old Kodak ektasound projector?
The film does not feed to show the movie. the projector makes a loud cranking noise!
4 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: The "arm" that ejects the slides has jamed on my Kodak projector.
the grease on the moving parts of the mechanism gets sticky with age. when the motor and cam stick, the select and index levers (which the cam moves) will stick. you'll need to remove the top and the whole mechanism and clean it out with wd40, dry it and regrease it. just remember what you removed so as to reinstall it properly.
Posted on Aug 28, 2009
  • 412 Answers
SOURCE: projector broke
Given the age of the projector, chances are the cause of the problem is a broken "Link". The "link" connects the cycle solenoid plunger to the slide change mechanism. The "link" is made of plastic, and over time it gets brittle & cracks, rendering slide change non-functional. Parts are still available (www.micro-tools.com), but this is an involved repair that requires dis-assembly & a service manual - - best left to a factory-trained repair dealer.
Posted on Jan 04, 2011
  • 412 Answers
SOURCE: manual for kodak ektasound moviedeck projector 275
Check with www.micro-tools.com for parts and manuals!! They have an amazing inventory of classic Kodak parts for slide & movie projectors! Good Luck !! Jim
Posted on Jun 25, 2012
My Kodak carousel slide projector 5200 works but makes a loud noise when the slide has dropped into the projector. The problem is in the auto focus. How can I fix it?
My personal suggestion would be to go for these repair catalogs. I know this website reliable-store.com
that i used to buy them from, and they sold online it was very good manual. Go ahead, I bet.
Mar 05, 2018 | Kodak Office Equipment & Supplies
I need a manual for Bell & Howell Lumina MX60 for an elderly person - need instructions how to load film.
Spec says it's auto-load. From what I recall of my own projector, you mount the input film reel on the front 'arm', extending it as necessary to give clearance, switch on the projector, then feed the free end of the film into the appropriate orifice at the front of the projector.
It then takes over, feeds the film through and wraps it around the take-up spool automatically. It may be necessary to cut the end of the leader on a diagonal to feed it in (not each time the film is loaded, just the first time.)
Once the film has fed through, switch on the lamp, focus and enjoy.
Dec 30, 2016 | Bell & Howell Cameras
Will the bell and Howell model 256 dhow super 8 film
No it won't.
http://store.tvedenlampmodules.com/Vintage-BELL-HOWELL-256-AB-8mm-HOME-MOVIE-FILM-PROJECTOR-w-LAMP-CONVERSION-P5123061.aspx
To be crystal clear; This is a Regular silent movie projector. It will not run, or play Super8, or Super 8mm movie films, with or without sound.
Bell howell autoload 8mm projector user manual english
Dec 05, 2016 | Cameras
I have a Keystone K75. The film will not stay in a loop after going through projector so it goes through too fast and you cannot watch the movie. Any ideas of what is wrong?
When threading the projector you must have a loop of film before and after the film gate (the part that swings open). You can also try turning the projector on with no film in it and make sure both upper and lower sprockets are turning. If this is a new problem you might have a broken belt or gear inside. Take it to a camera repair shop and they can tell you more.
Jan 05, 2015 | Office Equipment & Supplies
Threading and showing the film
Usaly means that drive rubber bands have gone bad, Very hard parts to find anymore.
Nov 15, 2014 | Kodak Vintage 8mm Eastman Movie Projector...
I need a replacement "Feed Belt" (like a long spring) for a Bell and Howell Filmosound 302 16mm projector circa 1950
Larry Urbanski at Urbanski Film in Illinois stocks the spring belts for all brands of 16mm projectors.
Oct 17, 2013 | Bell & Howell Bell Howell Filmosound Movie...
? Is the sprocket wheel in the middle of the projector supposed to move? The film seems to be locked up in there, and only the few inches of film in the gentle curve above the lens seems to feed thro
I know this post is old but I found a solution. The axle going to the sprocket is locked up with something sticky. You have take out the two screws holding the white plastic piece around the sprocket. Then loosen the small bolt on the big wheel on the other side. Remove the big wheel. Try to push the axle through to the other side. If it doesn't budge easily, hammer it out. That's what I had to do. Then clean it up real good with solvent, like alcohol. Lube it with grease and put it all back together. Worked for me.
Jul 19, 2012 | Kodak Antique Brownie 300 Movie Projector
Manual for kodak ektasound moviedeck projector 275
Jun 05, 2012 | Kodak Vintage Ektasound Moveideck 265...
Kodak Ektasound 245 Movie Projector Logo
66 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
