Question about Health & Beauty
Windmere prelude missing charging wire
My 1990 prelude will not charge the batt while driving and batt light is on
you will need a new alternator. battery light means there is no charge in the electrical system. always first check the earths and wires before changing the alternator as a faulty earth can also be the main problem.
Oct 10, 2013 | 1989 Honda Prelude
How to charge massager without charger
You cannot charge a battery without a charger. Why not just buy an adaptor that will do the job?
May 02, 2013 | Computers & Internet
Windmere fans parts
It's not worth to buy replacement parts, when portable fans costs from 15 to 20$ :/ take a look and decide Finally charging for our multi device world
Jun 25, 2012 | Dryers
1996 honda prelude non vtec will not go over 3000rpm ,. Begins missing and chugging....have put on new coil ,plugz, wires ,rotor ,distr.cap and distributor .Ecu throwing code 8 (TDC) PLEASE HELP ME...
you need to get a real code scanner and get the real trouble code, it sounds like a problem with your vtec soleniod, check your oil level for starters and let me know what the trouble code is
Jul 31, 2011 | 1996 Honda Prelude
Honda Prelude 2001, 2 codes seem to pop up all the time, P0420 and P0301. What has the to do with the other? Can the Catalytic converter cause a miss fire?
Hello: Sir, the 301 is telling you that you have a mis-fire on cylinder #3, You may have a bad spark plug, or bad wire going to #3 plug or you may have a ignition unit that is not firing #3 cylinder, With the #3 cylinder not firing it caused the 420 code that means the catalytic converter to be below acceptable efficiency for emission standards. Repair the 301 before you replace the converter
Dec 28, 2010 | 2001 Honda Prelude
My 98 prelude wont sttay on.. i replaced the alternator, batterym spark plugs and wires.... everytyme i get a jump it comes on and as soon as i take em off the car shuts off
Well, you seem to have replaced parts that I would have changed in the course of trying to solve a starting/charging problem.
And a tune up problem.
I would recheck the connections at the battery and clean with a wire brush if necessary.
However, the alternator, if working correctly, should keep the car running after you start it with the jumper cables. There's something wrong there, I think.
Jul 30, 2010 | 1998 Honda Prelude
Where is the transmission dipstick on a 1990 honda prelude si
I only know about the dipstick for the automatic transmission.
It is located to the passenger side of center and is burried dwon very deep - you almost have to reach full-arms-length down, between hoses and air duct to reach it. It has a wire loop handle usually covered in orange/yellow rubber. All total it is about 6 inches long when removed. It is so hard to find that I thought mine was missing and bought another one before I found it.
Jul 23, 2010 | 1990 Honda Prelude
1985 Honda Prelude replaced alternator and regulator trouble shooting wires, battery light still comes on
I had an 84 Prelude with a similar problem. I will assume that the car runs just fine as though there is nothing wrong but has the light on. When this happened to me it was just a bad diode in the alternator. If the battery takes a load fine and shows good charge then take off the alternator, take it back to autozone or wherever you bought it and have them test it. I would bet there is a diode bad and they will give you a replacement. Good luck!
Jan 10, 2010 | 1985 Honda Prelude
90 Honda Prelude misses sometimes
Maybe the crank speed sensor is faulty - would confuse ECU and show wierd rev counter results. Any engine check-light (MIL) or stored error codes?
Jun 09, 2009 | 1986 Honda Prelude
Health & Beauty Logo
73 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
