Question about Caterpillar Toys
Cat 315 cl
The swing brake locks up every small movement then let off stick and does same thing I have replaced brake solenoid still does it operates fine if u switch it to manual
SOURCE: shift lock problem
The A/T lock module had a bad lead. The ground was loose.
Posted on Jul 12, 2008
  • 32 Answers
SOURCE: Brake lights stick in the on position. I can turn
on the brake pedal lever there is a wire that goes to it it should be a star screw driver that adjusts the actuater on it losen or tighten depending on problem they loosen with time
Posted on Jun 14, 2009
sscullys
  • 984 Answers
SOURCE: Ford truck shifter locked in park
For the column shifter it is on the left hand side of the steering wheel column behind the knee panel.
For the console shifter it is under the cup holder, think it is still on the left side.
For either of them, the shift interlock solenoid has a white button on it, that you can press and it will release the gear shift lever.
This is for the 2004 New Body style truck, if you have a 2004 Heritage or Lightning, it is slightly different.
Posted on Jan 06, 2010
  • 1244 Answers
SOURCE: 91 honda accord brake lights stay on replaced
are you sure you the adjustment to it is correct the button in the end of the switch has to be fully depressed to deactivate the circuit
Posted on Jan 19, 2010
SOURCE: looking for the switch to change from cat controls
Hey Rawhide.....have a Cat 315 myself and looking to do the SAME thing (just got it yesterday). Talk about confusing. I'm used to JD too, so if you hear.....please let me know and I'm going to try to find out from the guy I got it from 2morrow. I believe that it's a simple and easy fix but you never know. My email is franandnan@netzero.net . Use Cat 315 in the header. Thanks (or anyone else too) Fran
Posted on Apr 04, 2010
D4 light
Either fit a manual gearbox or change the gearbox for a recon unit ,other than that trade it in on plan previa and get 2500E on it against a new car but this time buy a manual .You one has a clutch operating piston failed or a brake band worn out but what ?well without stripping the box who knows
Jul 26, 2013 | 1997 Acura CL
Shift solenoid
Are you referring to the shift lock solenoid?? cant get it out of park?? you should hear clicking noise every time you hit the brake pedal. If no noise is heard, that the solenoid could be faulty, but it also could be other things, such as wiring for it, or brake light switch etc. Have you spilled anything into the center cup holder, such as soda?? that will get into the console and stick your solenoid. the solenoid is located under the shifter indicator. that thing that sais P R N D 2 1. You need to pop the whole thing up and solenoid is under the finisher. Its a part of the shifter mechanism, but it can be replaced separately.
Jul 06, 2013 | 2002 Nissan Xterra
Can't get my car our of park its a 2000 Lincoln ls v6
When you operate the brakes, does the brake light come on?
If not, then check and/or replace your brake switch (located towards the top of the brake pedal).
If your brake light works, then check the gear shift lock solenoid operation. Check for power to the solenoid, when the brake pedal is depressed and check the solenoid movement. Replace if necessary.
Nov 12, 2012 | 2000 Lincoln LS
Shifter is stuck in park. had to remove little cover over hole, by the shifter, to insert key into hole, to get shifter to remove shifter from park. what causes this and is it something i can fix on my...
I believe this vehicle is equipped with a shift lock that necessitates depressing the brake pedal before it can be shifted out of "Park". This is a safety feature designed into almost every car made nowadays to prevent unintended movement of the vehicle when shifting out of "Park". The Shift Lock solenoid is triggered by the brake light switch located near the top of the brake pedal arm. Starting with the "basics", check to see if the brake lights are working (they should illuminate when the brake pedal is pressed. If the brakes lights do not come on. then proceed to check the brake/stop light fuse. Replace if needed. Once the brake lights are functioning, the shift lock should "disengage" and allow you to shift out of "Park" when the brake pedal is pressed. If the fuses are okay, but still no brake lights, then the Brake Light Switch may need to be replaced.
Brake lights working but won't shift out of "Park"? Check for a separate fuse for the Shift Lock Solenoid. Replace if needed. Otherwise the Shift Lock Solenoid may need to be replaced. This will require disassembly of the console to access the part.
Apr 09, 2011 | Kia Optima Cars & Trucks
2000 Jaguar S type 3.0 Blows only cold air on full heat. Just replaced heater control valve with no change. Also flushed and replaced thermostat. Car operating temperaure is fine. Both heater hoses are...
Check the little pump below the brake booster for running and the coolant valve for movement.
Both hoses to fire wall should be hot.
Check for air lock in system.
Blend doors on this vehicle stop working....common complaint.
To verify Blend door movement, turn on ignition with engine off.
Run temp to max and the min..... listen under glove box for ( sliding ) motor noise as door swings from hot to cold.
This is a digital system needing a Jaguar scanner for diagnosis.
Jan 16, 2011 | 2000 Jaguar S-Type
Shifter wont come out of park
the lock mechanism for part is operated by a small solenoid, this solenoid is powered by the brake light circuit, so when the brakes are pressed the solenoid releases the part lock by pulling the electric solenoid plunger back, so if u have no brake light then the car remains locked in park, check and make sure u have brake lights, if not check the brake light switch under the dash above the brake pedal, it should have 12+volts in and out of the switch when the brake pedal is depressed, if no power out of switch but has 12 volts in the switch is defective or out of adjusment.
Sep 29, 2010 | 2000 Cadillac Escalade
Looking for the switch to change from cat controls to john deere controls on a cat 315 excavator
Nov 02, 2009 | Kettler Caterpillar Excavator
My '97 acura cl 3.0 has a brake lamp on, and will not let me depress the shift lever button. I have already checked the engine fluid, and it was full. not sure what to do now. trying to avoid costly...
firstly, there should be a small vertical slot next to the shifter labelled "shift lock". Stick your ignition key in there and jiggle it while you try to depress the shifter button. That should get you out of 'park'. Now, when you say a brake lamp is on, do you mean on the dashboard or one of the actual brake lamps?
Sep 28, 2009 | 1997 Acura CL
Wont shift out of park unless I stick a screw driver in a small hole above gear shifter.
You must remove the console yes, and you need to replace the shift lock solenoid.
May 11, 2009 | 2005 Nissan Altima
Toys Logo
Top Caterpillar Toys Experts
fordexpert
Ted Maxwell
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
