Question about Yamaha RX-A820 7.2-Channel Receiver
How change fixed volume for zone 2 on yamaha rx-a820
  • 151 Answers
SOURCE: yamaha rx-v657 zone 2 volume
Go into zone 2 in menu select the source you want then turn up the volume for zone 2,this should work.
hope this helps.
CABLE CUY.
Posted on Jun 30, 2008
  • 4 Answers
SOURCE: Zone 2 Vol Fix
Try this:
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Hope it helps. It worked for us.
Posted on Aug 04, 2008
  • 8 Answers
SOURCE: No volume in Zone 2
Get the original Yamaha remote, go to Set menu, manual setup, speaker setup, and look for "extra speaker." it needs to be set to "zone 2." This is off the top of my head, so it should be pretty accurate. Get used to doing this, though, as this amplifier assignment to zone 2 is prone to resetting itself in those Yamahas.
Posted on Sep 07, 2009
  • 53 Answers
SOURCE: Yamaha RX-V550 AV Receiver Stuck on Zone 2
You can always do a system reset. there should be instructions in the handbook
Posted on Nov 07, 2009
dunnbiker
  • 8546 Answers
SOURCE: Yamaha RX- V 663 - unable to change volume on Zone 2
Page 111:
PROBLEM: Zone 2 speaker settings are not available in "SET MENU".
CAUSE: "EXTRA SP ASSIGN" is set to a setting other than "ZONE2".
REMEDY: Set "EXTRA SP ASSIGN" to "ZONE2".
See Page 85
Posted on Mar 13, 2010
Testimonial: "Hi it certainly pointed me in the right direction. Thank you. A few more steps would have been useful and page number suggestion was not correct p33."
I cant get zone 2 to work on my yamaha rx v673. They are 2 outdoor speakers.. please help
I had a similar problem where I could not increase zone 2 volume - Page 100 in the manual notes that 'power amp assign' must be set to "7 Ch + 1 zone" before zone 2 max volume can be changed. Try that.
Jul 08, 2012 | Yamaha RX-V663 Receiver
When I try to turn up zone 2 the display reads fix. Is there a short or an ohms problem?
Look on page 99 of the manual. It's a parameter you have an option to change to Variable. Fix lets Zone 2 or 3 have a Fixed volume level independent of the volume control on the Yamaha. Variable makes them dependent on the control.
Aug 18, 2010 | Yamaha RX-V1600 Receiver
I have a Yamaha RX V665 and I am unable to change the volume
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jun 07, 2010 | Yamaha RX-V663 Receiver
Page 111:
See Page 85
Mar 13, 2010 | Yamaha RX-V663 Receiver
No volume in Zone 2
Sep 05, 2009 | Yamaha RX-V661 Receiver
Zone 2
If you are using an external amp, "fixed" is what you will see on the Yamaha's display when you want to change the volume. If you are using the power of the Yamaha's Zone 2 outputs, you need to go into the "Menu" then "Manual Settings" then "Options or Zone 2" and set it for "Int" That will solve your problem.
Jun 23, 2009 | Yamaha RX-V663 Receiver
Yamaha RXV661 Receiver has Zone 2 Vol Fix error message
i have the same problem. i have a rx-v661. i goto the zone 2 settings and try to change the volume and it says VOL FIX. I cannot hear anything out of zone 2. It takes the current volume that is in zone 2, but i cannot hear anything. it has been working fine for at least a year.
Jun 10, 2009 | Yamaha RX-V661 Receiver
On zone 2 of my yamaha rx v663 receiver it says fixed when I try to adjust the vlume and won't let me cut it up or down.
Check the setup menu of the receiver on zone 2 settings most likely the error is a fixed volume setting for this zone. If not found, reset factory settings and try to setup everything again. If the problems persists, contact your vendor if still under warranty.
Apr 12, 2009 | Yamaha RX-V663 Receiver
Yamaha rx-v657 zone 2 volume fix
hope this helps.
CABLE CUY.
Jun 29, 2008 | Yamaha Audio Players & Recorders
Yamaha RX-A820 7.2-Channel Receiver Logo
98 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
