Question about John Deere Garden
John deere x310
Can't lower deck
SOURCE: replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Posted on May 25, 2009
SOURCE: john deere 111 mower deck. Lift is in stuck in highest position
Looked up detailed isometric diagram w/ parts denoted on John Deere website. FixYa website was a litele misleading. I did not realize that accessing a question posted "for free" would cost me something to get the answer. It's kind of like askin a neighbor as a neighbor to give you a hand and then he sends a bill.
Thanks but no thanks
Posted on Jun 26, 2009
  • 10865 Answers
SOURCE: i need a deck belt diagram for a John Deere 170
I recommend that you go to any john deere dealer and get a john deere replacement belt. What you will find if you go with a generic is that it will not be quite as good, and will not last.
Posted on Sep 14, 2009
mowerman1857
  • 389 Answers
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
Posted on Sep 18, 2009
  • 5 Answers
SOURCE: need john deere stx38 mower deck belt diagram
Go to http://outdoorpowerinfo.com/repairs/deere_stx38_gear_drive_belt.asp
for pictures and descriptions of drive belt and deck belt on John Deere STX38 and STX46 tractor with black deck
Posted on Oct 22, 2009
I cant lower the mower deck below 2.5 inches without the belt coming off, it's a 2007 John deere LA130 48" deck
try to adjust the deck. sounds like it is not level. if it is level you may have a bent pulley
Oct 22, 2016 | John Deere Garden
My John Deere D110 is cutting the grass to short on the highest deck level. How can I fix it.
level the deck off as a tilted deck will cut lower on the low side
adjust the deck mounting bars or deck pilot wheels
check that the cutter/pulley spindles are in good condition and not falling down
Sep 15, 2016 | John Deere Garden
Blades wont engage when deck is lowered on John deere L111. They will engage when the deck is at the highest point.
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 27, 2016 | John Deere Garden
I have a probably 20 year old John Deere 130 lawn mower the mow deck is stuck in the highest setting and will not lower, how do lower it, Thanks
a 130 that's 20 years old , does this one have a black deck or a yellow deck , the black deck ones used a hydraulic cylinder (commercial model) and the yellow deck models used a grab bar just infront of the seat , you need to squeeze the handles together to get catch to release , then it should just fall down to it's lowest setting , that is if it's not rusted in place , a few squirts of soaking oil will do wonders on this
Mar 24, 2015 | John Deere Garden
I have a John Deere X304 that mows unevenly.
Make sure that your gauge wheels are not running on the ground during mowing,they should only hit the ground when you engage a high spot on one side.also when you level the deck the front should be a 1/2" lower than the rear.
May 12, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Adjusting John deere ''Sabre'' model deck
Move machine to flat/level surface,with deck raised put a 2x4 between rear of deck and ground.Make sure that the 2x4 goes all the way under deck from one side too the other.Once that is done lower deck all the way and make sure lift lever is all the way forward.Then on the rear top side of deck loosen bolt that holds arm to deck bracket,pull bracket as far down as you can then retighten bolt.This is also the point where you can level deck side to side.
May 03, 2010 | John Deere Tractor 1020, 1520, 1530,...
I have a John Deere model# LA105 , and it is cutting uneven because one blade sets lower then the other,the blades are not bent.
I have a John Deere lawntractor, 105. Won't start. Gas getting to the carb, but not getting into carb. Is this a common problem. Has been setting for a year. Any suggestions on problem
Sep 11, 2009 | John Deere Garden
The deck tilts down forward so the guide wheels are always in contact with the ground. how can i level the deck so it raises and lowers equally front and rear?
a mowing deck is suppose to be lower in th front than the rear usually 1/2" to 3/4" difference however if you need to adjust your deck you can go to www.deere .com and search for your owners manual and the procedures will be in the owners manual
Aug 29, 2009 | John Deere Garden
John deere 111 mower deck. Lift is in stuck in highest position
Jun 25, 2009 | Garden
Garden Logo
106 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
